Crusty injectors...
Crusty injectors...
Postby type85 » Thu Mar 23, 2017 10:09 pm
Installed new about 2 years ago, about 5k mi. running E85, the rubber o ring has some white deposits, almost like a white powder, it's only on the end that's inserts into the fuel rail....
type85
Re: Crusty injectors...
Postby Mentosman42 » Fri Mar 24, 2017 8:41 am
Aluminum fuel rail?
95.5 ur-S6
83 20vt urQ
Mentosman42
Postby type85 » Fri Mar 24, 2017 9:20 am
Mentosman42 wrote:Aluminum fuel rail?
yes
type85
Postby Mentosman42 » Fri Mar 24, 2017 11:44 am
Might be a silly question but is it just corrosion?
From what Ive read(and I may be 100% wrong) ethanol corrodes aluminum, not bad enough that it is going to eat through a tank or fuel rail but a small amount of surface corrosion is possible.
95.5 ur-S6
83 20vt urQ
Mentosman42
Postby type85 » Fri Mar 24, 2017 3:02 pm
most likely, from the aluminum rail and fittings.....
type85
Return to General
