Vacuum setup
Vacuum setup
Postby sharkbait » Wed May 10, 2017 6:30 pm
I'm finally getting around to working on my car again and I'm trying to set up the vacuum. The car is a CQ that basically has a 3b in it running off of VEMS.
I have a short runner from Iroz, which has 1 3/8 port, 3 1/8th ports.
Aftermarket N75 valve.
Stock wastegate and stock brake booster.
Tial BOV aftermarket FPR.
With my limited knowledge of turbo cars and no idea how their vacuum works, I know the wastegate(big banjo bolt) goes to the n75 valve.
The Tial bov, brake booster,VEMS, fpr, and n75 valve all connect to a vacuum source.
I'm not 100% sure where to go from here. Should I use a vacuum manifold to supply everything? Do I need some sort of check valve between vacuum sources?
sharkbait
Re: Vacuum setup
Postby ChrisAudi80 » Thu May 11, 2017 2:16 am
There is no vacuum source for the N75. One side connects to compressor pressure, the other to wastegate, third to atmosphere.
Google the diagram.
Other than that, a check valve between brake canister and manifold would be a good idea.
I would not use a vacuum manifold for BOV, FPR and MAP signal to VEMS. Better to give them each a separate nipple on the IM.
Re: Vacuum setup
Postby sharkbait » Thu May 11, 2017 3:48 am
the diagram for the n75 valve had just said "pressure input" so I wasn't real sure.
So best bet would be brake booster to the large portion on the intake with a check valve.
and the rest to the remaining 3 ports on the intake.
Thanks for the input here.
sharkbait
Re: Vacuum setup
Postby chaloux » Thu May 11, 2017 5:38 am
sharkbait wrote:the diagram for the n75 valve had just said "pressure input" so I wasn't real sure.
Exactly. [THUMBS UP SIGN]
DEAD :( - 1996 S6 mit TDI
Re: Vacuum setup
Exactly.
Return to General
