95 A6 manual transmission?
Postby audios » Tue Jun 13, 2017 1:00 pm
which transmission came in the 95 a6 MT? 01e? 016? different ratios for the v6 vs the AAN?
thanks for any info, been searching around and only can seem to find info on the auto's
audios
Re: 95 A6 manual transmission?
Postby pilihp2 » Tue Jun 13, 2017 1:01 pm
that year a6 used the 01a for the manual
Think it was funky gear ratios too like the other v6's
05 S4 - "Daily"
Postby audios » Tue Jun 13, 2017 1:06 pm
manual quattro?
audios
Postby pilihp2 » Tue Jun 13, 2017 1:12 pm
Yep.
This question for a non quattro manual a6?
I didnt even know they had those....?
05 S4 - "Daily"
Postby audios » Tue Jun 13, 2017 1:21 pm
nope its a quattro manual, was hoping for an 01e or 016 not the weak 01a....
audios
Postby ChrisAudi80 » Mon Jun 19, 2017 10:30 pm
audios wrote:nope its a quattro manual, was hoping for an 01e or 016 not the weak 01a....
The 01A is not that weak. What do you plan? 500wheel?
Postby DE80q » Tue Jun 20, 2017 2:10 am
:rofl: I've broken 2 of them already, and I believe #3 is on its way out. I'm only running a 10vt at 18psi now. The first one broke with the factory NG engine, the second one broke with less than 2k miles at less than 12psi. The 01A is plenty weak.
"If you cant find one, make one!"
91 Audi 80q -10vt project
07 Mitsubishi Raider (Dakota in disguise)
Postby varia » Tue Jun 20, 2017 10:54 am
i have a volvo turbo on my cq around 280-300whp, beating that tranny as hard as i can (wanna upgrade to 01E) but nothing
¯\_(ツ)_/¯
project 2226
varia
Postby dana » Tue Jun 20, 2017 2:48 pm
You must just be unlucky, because they are not THAT weak. Myself and a few friends have abused them behind 20vt's at various stages of tune and really only broken a few. I had one survive 20,000 miles behind a 20vt that trapped 124mph.
I dont think yours were failing with a stock NG because of power.
An 01a will handle 250-300whp and moderate abuse if its in good condition otherwise.
-efi 10vt 4kq
dana
Postby vt10vt » Tue Jun 20, 2017 6:48 pm
dana wrote:
DE80q wrote: :rofl: I've broken 2 of them already, and I believe #3 is on its way out. I'm only running a 10vt at 18psi now. The first one broke with the factory NG engine, the second one broke with less than 2k miles at less than 12psi. The 01A is plenty weak.
Tom's car also comes to mind, not because it made any insane amount of power, but because of how relentlessly it was beaten on. Given, that was only a 1.8t, but still, nobody can break things like Tom can and I don't think he ever even broke one.
Postby PRY4SNO » Tue Jun 20, 2017 9:45 pm
Correct me if I'm wrong, but the more modern 01A that came behind 1.8t were a bit stronger (compared to, say, the Cq 01A), and had better gear ratios... no?
|| Spare parts for sale
Postby DE80q » Tue Jun 20, 2017 10:13 pm
The 01A transmission seems to be one of those items that is hit or miss. Some people, like Dana, have had very good luck with them. Others, such as myself, have had horrible luck with them. My first one had a synchro catastrophicley fail, and the brass pieces got lodged between the front diff gears punching out the front of the case. The second one had the input shaft decide to walk into the transmission chewing everything up along the way. The one I have now has lasted the longest, with the most abuse. I have a feeling the spec stage3 clutch I'm running isn't helping things. It's more of an on/off switch.
Return to General
Users browsing this forum: Bing [Bot] and 3 guests
