engine break in procedure?
Postby type85 » Sat Feb 02, 2019 12:08 am
The stats:
7A
New rings, bearings, hone, valve job done on head.
Running Castrol GTX20/50
How should I run in the engine?
30min initial start up fast idle?
How hard to I drive it?
This is a track car, so i can't drive it on the street too much, I can do some quick runs up and down the local freeway.
type85
Re: engine break in procedure?
Postby mrdeye » Sat Feb 02, 2019 9:25 am
Not that I’m an expert engine builder but when I rebuilt the engine in my coupe I put the engine under load as soon as possible. When I knew the cooling system was operating correctly I drove the car around the neighborhood. In a low gear I let the idle of the engine move the car around and then took it out to get the rpm’s up. Considering where I was, I started to drive it for what it was intended for. I did that until I had a chance to take it out to the track and miss use it. Changed the oil after the track day. Unfortunately the car has sat for awhile. Only have 2 or 3 track days on the engine.
Good luck with it! :drive: :flag: :beer:
Mr.
Previous cars:
mrdeye
Postby varia » Sat Feb 02, 2019 10:07 am
¯\_(ツ)_/¯
project 2226
varia
Postby PRY4SNO » Sat Feb 02, 2019 2:13 pm
varia wrote:http://www.mototuneusa.com/break_in_secrets.htm
:metoo:
Especially for a track car. Might be best to get it out on some secondary highways if possible.
Postby type85 » Sat Feb 02, 2019 3:47 pm
Thanks! now if it would only stop raining.................
type85
Postby mrdeye » Sat Feb 02, 2019 4:34 pm
:metoo:
https://youtu.be/zNCrMEOqHpc
:beer: :P
Mr.
Previous cars:
mrdeye
Return to General
Users browsing this forum: No registered users and 9 guests
