Intake air sensor
Intake air sensor
Postby FFF » Wed Feb 20, 2019 2:37 pm
What is everyone using for a replacement intake air sensor 034 905 379B?
thanks!
FFF
Re: Intake air sensor
Postby varia » Wed Feb 20, 2019 3:50 pm
if you go vems, you can use 1.8T or https://shop.vems.hu/catalog/sensor-p-115.html
¯\_(ツ)_/¯
project 2226
varia
Postby FFF » Wed Feb 20, 2019 4:24 pm
Good option, thank you, I was hoping for something that did not require modifying the manifold.
FFF
Postby pilihp2 » Wed Feb 20, 2019 5:38 pm
FFF wrote:Good option, thank you, I was hoping for something that did not require modifying the manifold.
The 1.8T is not a direct replacement. The hole has to be enlarged on the manifold.
05 S4 - "Daily"
Postby type85 » Wed Feb 20, 2019 10:47 pm
I'm running the 1.8T sensor, it sticks up pretty high!
type85
Postby FFF » Thu Feb 21, 2019 12:26 am
Thanks, I’m using a Wagner so it is on the front rather than the top.
FFF
Postby FFF » Thu Feb 21, 2019 11:38 am
type85 wrote:I'm running the 1.8T sensor, it sticks up pretty high!
Did you have to modify the bolt hole that holds the temp sensor in or do you use the factory hole?
Thanks!
FFF
Postby type85 » Thu Feb 21, 2019 2:26 pm
Thanks!
Yes, I had to drill out the manifold, then used gasket sealer to make sure there wasn't a vacuum leak, I think the connector is different as well....
type85
Postby FFF » Thu Feb 21, 2019 6:18 pm
Ok thanks.
FFF
Return to General
Users browsing this forum: No registered users and 9 guests
