Re: Tacos 4KTQ I0vt Swap: The Red Baron - buying parts again
Postby Foscora » Thu May 18, 2017 1:52 am
AngryTaco wrote:Get some BOIIIIIIIIIII
:thumbsup:
Foscora
Postby 85oceanic » Thu May 18, 2017 10:04 am
Hell. yes. I can't wait to hear the derp-a derp noise from that lump at BBQ! LOL
Postby AngryTaco » Mon Jan 22, 2018 4:03 am
So I'm still alive.....just busy.
I recently bought the property the businesses sit on so I'm a bit more situated and have more control over operations now.
This week I dropped the 2.5L crank off at the machine shop for inspection.
The only thing left to get the short block together is order pistons from Wiseco (at this time) and rod bearings from Gerner.
I am going with 9a pistons but am going to request that Wiseco fly cut them to the 2v head. Compression will be 10.5:1
Once I have the pistons, I will have the AAF block drilled for squirters, bored for the pistons, and decked so that the piston is .005 in the hole.
I currently have the welding material to build the block up for the I0vt head (coolant port needs blocked and side of block needs built up)
I will update with pictures probably sometime this week
Postby 85oceanic » Mon Jan 22, 2018 10:06 am
WOOT Let see those updates!
Postby AngryTaco » Wed Jan 24, 2018 7:26 pm
Got the crank back today. Ordered a set of rod bearings from Gerner. Just need pistons now
Postby chaloux » Wed Jan 24, 2018 9:27 pm
Looks purdy
Glad you're back, Taco
DEAD :( - 1996 S6 mit TDI
Postby PRY4SNO » Wed Jan 24, 2018 9:37 pm
Yeah, it's about time!
|| Spare parts for sale
Postby audifreakjim » Wed Jan 24, 2018 9:53 pm
God damn, that crank looks like an anchor.
Postby AngryTaco » Wed Jan 24, 2018 11:58 pm
audifreakjim wrote:God damn, that crank looks like an anchor.
How else do you expect it to handle 1200 ft-lbs of I0vt torque?
Postby DE80q » Thu Jan 25, 2018 12:06 am
:rofl:
Postby ringbearer » Thu Jan 25, 2018 12:51 pm
How many valves again?
Glad you are back Taco!
Postby PRY4SNO » Sat Jan 27, 2018 12:48 am
Pretty sure it's I0 valves... as in Intake-0utlet lolol
Postby AngryTaco » Sat Feb 24, 2018 12:22 am
Update:
Jeff and I are working on pistons right now. Block height measured 9.333-9.335
Techtonic Tuning and I are putting together the valve train. We are converting the hydraulic head to solid everything and 7mm or 6.5mm valves.
Postby audifreakjim » Fri Mar 09, 2018 12:28 am
Tiny valve stems are a good way to get more flow.
Postby 85oceanic » Fri Mar 09, 2018 9:23 pm
Now it's a god damn race to see who is back on the road first. Oceanic is getting blown apart in two weeks and going for the 2.5 short deck build. :D
Postby AngryTaco » Sat Mar 10, 2018 4:13 am
audifreakjim wrote:Tiny valve stems are a good way to get more flow.
We will be converting to the 6.5mm stems from factory 8mm
Postby DE80q » Sat Mar 10, 2018 5:02 am
That should be a significant increase in flow! Just don't bend any this time... :P
Postby AngryTaco » Tue Aug 28, 2018 2:14 pm
Just a quick update. I should know the status of the head and valvetrain later today from Colin over at TT. I have been very frugal recently due to purchasing the property my businesses resides on and also planning to take over a local competitor's shop as well as purchasing a Duplex in the Spring or Summer (thus effecting the speed of most of my projects).
Have patience as stuff is still getting done
Postby AngryTaco » Tue Aug 28, 2018 5:19 pm
So Colin and I figured out what we are doing. 42mm/35mm valves, 7mm stems, port work, under bucket shims, race springs good for 9000 rpm, head clearencing for the cam, custom pinned lifters and some other small insignificant things. Should run around $2000ish for those wondering. Cheap in my opinion but the best money can buy according to Colin. Fast times ahead
Postby DE80q » Tue Aug 28, 2018 11:33 pm
Where the hell have you been! I've text you a couple times now...
Postby AngryTaco » Fri Aug 31, 2018 3:52 pm
DE80q wrote:Where the hell have you been! I've text you a couple times now...
Text me again. I've gone through like 2 phones recently. Same number
Previous
Users browsing this forum: Google [Bot] and 17 guests
