10vt B3 (The Bandit)
Re: 10vt B3 (The Bandit)
Postby DE80q » Wed May 17, 2017 2:16 pm
This truly is how my luck goes... I'm loading the bandit so I'm not rushing around tomorrow to get to the bike ride. I go to lock the doors after closing the trunk, and nothing. Well, I shouldn't say nothing, the driver's door locked. Everything else says open. I figure I must have hit something in the truck knocking off the main power wire or something. No such luck. I go to the passenger door, and it activated the vacuum pump. Looks like I'm back where I started when I first got the car. Using the passenger door to unlock it. :bangshead:
Postby PRY4SNO » Sat May 20, 2017 9:38 am
Ugh. My 80q does this too... Haven't figured out if it's the tumbler or something else since it's not my daily. I feel your pain.
Postby DE80q » Sat May 20, 2017 12:45 pm
The messed up part is the next day it worked fine... I really don't know what happened!
Postby elaw » Sat May 20, 2017 12:53 pm
Did you forget to say "Simon says"? :lol:
Eric Law
elaw
Postby DE80q » Mon Jul 24, 2017 11:26 am
First thing, yes, none of my pics work. I'm working in getting my photos hosted somewhere else, as I'm not willing to pay $400 to host them.
So it has been a while, and maybe that's a good thing. The car has been running quite well for a while now with no real hiccups. About a week ago I tried to once again put my daughter in the car, and it wouldn't start. Not only that, it back fired pretty bad. I honestly thought I might have blown up the exhaust. The next day after talking about it with Eric, the car starts and runs fine... Still not totally sure what happened. I guess it's possible the car dislikes my daughter as much as she it haha.
Anyways, on to the better stuff. With everything going in lately, Eric has managed to get the car to not knock, and AFR's to be very good the whole way through the RPM range even on a fully heat soaked engine on a hot day. I still need to make up heat shielding and replace the motor mount insert though. Hopefully I can do that this coming weekend if Georges garage is free. With everything looking good at 18psi, we are looking at turning up the boost to 20psi. I'm still using a K24, and was told I should be good to about 23psi. I wanted to see what others think about this. Seems like a solid # and the turbo seems healthy enough. I have a tune file ready to go for this as well. Let me know what you guys think.
Postby DE80q » Sun Aug 27, 2017 8:58 pm
Went to do an oil change today, and it took much longer than I ever expected.
It finally happened! The plug would not move in the 7A pan. I was using a 6 point socket on it, and it stripped! I couldn't believe it! Had to put vise grips on it, and beat them with a hammer to finally come loose. I inspected the threads, and they look great, on both the plug and the pan. I was warned about this happening with the large thread aluminum pans though. I'm glad I had a spare plug in the tool box!
After that was all taken care of, I decided to finally take car of my now nearly completely red hood. I picked up a couple cans of black primer and semi gloss black paint. First, I had to strip all the old primer off. A 100 grit sanding sponge that that job very well
I then did the primer and paint. Came out pretty well for a non painter like myself. There is some tiger striping, but honestly, look at the rest of the car haha.
I'm happy with it. Looks much better than the burnt off black primer on a red hood. If I were to color sand it, and buff it some, it would probably look a lot better. Maybe later... this is how it looked when I got home, all unwrapped and parked...
Postby DE80q » Sun Nov 05, 2017 10:25 pm
Winter is fast approaching! I thought it would be nice to be able to drive this thing in the snow this year... So, as I had planned to do last year, I now have a new set of winter meats to put on.
These are Nexen winSpikes, which get really good reviews. Hopefully I'll be able to got some winter time shenanigans in this year! They were handed over to a friend of mine with the old Ronal 15' wheels to mount and balance. Should be some fun times ahead!
Postby DE80q » Mon Nov 06, 2017 1:14 pm
YAY!!! got all my pics working again! What a PITA that was...
Postby DE80q » Sun Nov 12, 2017 1:22 pm
Picked up my snowies on Friday, all mounted balanced and ready to go!
Winter mode is now engaged!
I'm looking forward to some winter time shenanigans!
Postby PRY4SNO » Mon Nov 13, 2017 12:42 am
Always loved those wheels on the small chassis cars.
Looking forward to some hooning vids in snowy parking lots or ski hill roads.
Postby DE80q » Thu Nov 30, 2017 10:34 am
I'm running 35psi on all 4 corners, and these snow tires look low on pressure to me. I'm also used to performance tires, so that could be the problem.
I also forgot just how "squishy" snow tires are. It's been probably 15 years or more that I haven't owned a set. Good news is, they are saving my spine and kidneys on the rushed for winter road work they have been doing around here...
Postby DE80q » Mon Jan 01, 2018 2:13 pm
Happy new year everyone!
well, for the first time in a long time, I have been driving the car in the winter. Due to this, there has been a lot of condensation build up in the breather line. This has turned into quite a bit of nasty oil foam. like this
Because of this, I have decided to build a pretty basic oil catch can setup. The tank was originally built with another purpose in mind, but with some modification, should work really well as a catch can.
Image Image
I picked up some stainless scouring pads to use as a filter below the perforated plate. It will be safety wired to the plate to keep it in place.
Hopefully this will help keep the water and oil foam from getting into the intake track. I'll post pics when its installed. It is about 15 degrees outside, so probably wont be doing it today...
Postby Afterthought » Tue Jan 02, 2018 8:36 am
Nice that looks like it will be a nice setup.
I guess you could always try venting it to atmosphere if you’re worried about that foam and oil in the intake . But I think they smell quite a bit when done that way
Postby DE80q » Tue Jan 02, 2018 8:50 am
As of now, it is being put directly into the intake track, so pretty much anything will be better.
Unfortunately, the can I made is too tall for where I want to put it. I will either have to mount it on the DS behind the radiator, or make up something different for the PS. I always forget how little room I have on that side.
Postby Afterthought » Tue Jan 02, 2018 9:46 am
I had to shorten mine too. The last car I had done one in (4000) I put it behind the radiator between the brake master cyl and coolant expansion tank. It is tight back there by the firewall .
I am running that breather puck that marc sells , that goes into the block . That nice CNC piece has a packing in it and maybe would help to knock out some of the liquid on its way out before it gets to the catch can.
Postby DE80q » Tue Jan 02, 2018 1:06 pm
I saw those when they were being produced, pretty nice piece.
The only problem I have with mounting the catch can on the DS is that being a 10v, everything else is on the PS. I would have to run so quite long breather hoses.
Postby dana » Wed Jan 03, 2018 1:02 pm
id be a bit concerned about that catch can freezing up and blocking the venting if you are getting cold anything like we are. Things are freezing shut around here that you would never expect.
I saw a wood stove chimney on my road with icicles hanging off it while it was burning this morning.
-efi 10vt 4kq
Postby DE80q » Thu Jan 04, 2018 10:46 am
dana wrote:id be a bit concerned about that catch can freezing up and blocking the venting if you are getting cold anything like we are. Things are freezing shut around here that you would never expect.
This is something I have thought about. We have been getting to around 5° with this week hitting around -20° wind chill. I'm sure it has been much colder up there, as Eric has told me about -10° before wind chill in Mass. Freezing anything under the hood is not a good thing. Definitely things to think about. I'm not a fan of the crap getting g into my intake track, but would probably be better that than no breather system.
Postby ringbearer » Thu Jan 04, 2018 1:59 pm
What about wrapping it with tubing that has coolant flowing through? May be a pain but it would stay warm.
Postby Nateflix56 » Thu Jan 04, 2018 2:20 pm
What about finding a diesel fuel filter heating element to place inside the catch can? You could wire it up to a manual switch, or relay it to a thermostatic switch.
Something like this:
http://www.fordiesels.com/ford-powerstr ... gLI3_D_BwE
90 CQ - 07k Swap Pending
01.5 B5 S4 (Sold)
98 Jetta VRT (Sold)
Nateflix56
Postby DE80q » Sat Jan 06, 2018 9:20 am
ringbearer- That was something I was looking at. It would be a PITA to wrap tubing, but it would do the trick once the engine was warmed up.
Nateflix56- That is definitely interesting. I'm thinking it would be a bit large, and probably overkill, to keep a small catch can warm.
Something else I was looking at was an industrial strip heater. We use them in a lot of the electric motors we rebuild that are used in the elements. It wouldn't be "hot" but would make things warm up enough to not be frozen. I talked to a couple of the mechanics at work, and there are versions of them that run off of 12v, so it would be a possibility.
Postby PRY4SNO » Sat Jan 06, 2018 6:52 pm
Do you have a block and or coolant heater?
We get much colder around here routinely, and a frozen cc is pretty rare. There's got to be a simple fix that hasn't been broached just yet... I'd like to think.
Also, if there's a way you could mount on the passenger side as high up as possible on the firewall that would be the ticket. The exhaust heat would help keep it at a good temp to make sure any moisture is emulsified and doesn't freeze.
Re: 20vt B3 (The Bandit)
Postby AngryTaco » Mon Jan 22, 2018 3:57 am
Where are my anti-lag videos?
Also, send me a text. I got a new phone and I've been extremely lazy in updating it
Postby DE80q » Thu Jan 25, 2018 3:42 am
I spent this last weekend up in CT getting the 3" turbo back exhaust built and installed on the bandit. It was an interesting precess, but it worked out well in the end. Lots of cutting, fitting and welding turned a lot of straight pipe and a couple bends into an amazingly quiet exhaust.
Here is the downpipe, this was the first 3" 10vt downpipe Tim had ever built, so it was quite a bit of trial and error.
This was the final test fit before the WG was welded on. It's quite tight in there.
Here is the final install of the downpipe. All wrapped up and air gap heat shield installed.
Here is the section from the downpipe to the rear subframe. The is a vibrant resonator and half of a borla muffler. The entire borla muffler was too large to fit where we wanted it, so we cut it and recapped the end.
The over axel pipe was a rear PITA! Anyone with a full 3" system know just how little room there is in that area...
And, due to having to leave in a hurry, I forget to take a finished pic of the rear muffler... Here is one while time was welding it. It's a dual 2.5" in/out "X" magnaflow muffler. Tim made an awesome 3" to dual 2.5" "Y" to connect it.
And for fun, I tried to take some pics through my welding helmet. This was the best one I got while he was welding on the rear muffler.
The system sound great! It actually sound "like a turbo car"... Much different sound than the 2.5" system had, and amazingly quiet when on the highway. I can't thank Tim enough for figuring this system out!
Postby elaw » Thu Jan 25, 2018 7:04 am
That's awesome! Sounds like it was worth the time and the trip.
Can you post a video so we can hear it?
Eric Law
elaw
PreviousNext
Users browsing this forum: No registered users and 18 guests
