Eric's V8 CQ
Re: Re: Ben's V8 CQ - MR2 pump en route
Postby Grillage » Tue Apr 26, 2016 6:55 pm
Got the pump from the UK today finally.
I found some great info on this install. There are people with all kinds of cars using these things.
Firstly, here's the pump (cleaned up). Complete with pigtails for the harnesses:
I have had a couple hoses made for my existing pump and I now have hard fittings on the rack and the pump with a hose in between - all connecting with 6 AN fittings.
So I found a fitting that uses 6AN for my existing hose and 16mm x 1.5 for the pump:
http://www.summitracing.com/parts/rus-670531
I also bought a 90* fitting so I could route the hose down:
So now I will get it wired up and try to install. I found these diagrams for the wiring:
I bought this relay kit and hope to get everything working this weekend:
http://www.amazon.com/Fastronix-Weather ... ge_o01_s00
Lastly, it occurs to me that with the PS pump eliminated, I will have eliminated my Viscous Fan, Power Steering Pump and AC Compressor.
The Fan pulley and AC Compressor are currently on the engine as rollers but I now will just have the alternator on the serpentine belt. I'd love to get rid of the extra stuff and make some more room for air movement.
See here:
I can pretty easily get rid of all the stuff in the Red X's but the Blue one is tougher. I'll need to figure out how to tension the serpentine belt by likely moving the tensioner.
I will need to cut off the little bracket that the timing tools fit into so I guess I'll just source another belt cover if I ever decide to change the timing belt again.
CURRENT
1995 90 Quattro 20VT - 1994 Cabriolet - 5 speed - 1987 Porsche 924S - 1986 Coupe GT
PAST
Grillage
Postby Grillage » Tue Apr 26, 2016 8:46 pm
Found Marc's solution to the same problem on his V8TT Coupe:
This would be PERFECT.
A turnbuckle as a tensioner.
CURRENT
PAST
Grillage
Postby Dan McBoost » Tue Apr 26, 2016 9:52 pm
Thats a great idea for sure. You could always get a machine shop to make something up more OEM like if need be.
Dan McBoost
Supras: ● 88T ● 87T ● 87T ● 85P
Other: ● 06 XC90 V8 ● 04 Evo8 ● 99 V70R ● 91 Celica Alltrac ● 90 JDM MR2 GT ● 78 Toyota Pickup
Audis: ● 04 A8L ● 97 A8Q ● 91 200 TQA ● 90 CQ ● 85 4000Q
Dan McBoost
Postby kieron_32v » Wed Apr 27, 2016 4:05 am
I ran mine with the factory tensioner and kept the fan pulley as an idler. Will post up a pic.
kieron_32v
Postby kieron_32v » Wed Apr 27, 2016 4:11 am
http://rs1052.pbsrc.com/albums/s459/che ... 0&fit=clip
kieron_32v
Postby Grillage » Wed Apr 27, 2016 6:46 am
Thanks Kieron,
Your Pic:
You are using the viscous pulley though- I'd love to omit that too. My fan sits right on it. If it were gone I'd get a pretty big increase in airflow.
CURRENT
PAST
Grillage
Postby Grillage » Wed Apr 27, 2016 9:21 pm
Kieron, do you happen to know the belt you used here? I may well use this setup until I figure out a way to omit the other pulley
CURRENT
PAST
Grillage
Postby Grillage » Thu Apr 28, 2016 1:31 pm
The more I look at this, I think I can do it without relocating the pulley like Marc did in his pic above.
If I use the yellow line routing, I just need to turn the tensioner into a pusher rather than a puller which can be done with a turnbuckle!
I have a lot of work to do this weekend to get ready for Carlisle.
The MR2 Power Steering Pump
re-routing the serpentine belt and removal of the AC compressor, PS Pump and two other pulleys
install of an 80* thermostat
swap of the carpet, door cards and headliner out of my new coupe
CURRENT
PAST
Grillage
Postby audifreakjim » Thu Apr 28, 2016 2:20 pm
That will not work well, the tensioner needs to be on the slack side of the belt right before the crank pulley. You have it on the drive side where it will just compress and everything will slip. Marc using a solid turnbuckle would not have this problem
Postby Grillage » Thu Apr 28, 2016 2:57 pm
I'm going to use a turnbuckle too. but it will still be on the drive side
CURRENT
PAST
Grillage
Postby Grillage » Sat Apr 30, 2016 5:57 pm
Made some progress today
Got the 80* thermostat installed. It has no hole - I know some people swear by the hole and even drill a small hole in thermostats that come without. What do you guys think?
Also, got the serpentine belt re-route done. It was right at 100cm
How tight should I make the belt with the turnbuckle?
I also got the euro bumper fitted up finally
I have almost everything ready for the MR2 PS pump install. I need a couple AN fittings and he bracket to mount it and I'll be good.
I hope to wire it all up tomorrow in advance.
CURRENT
PAST
Grillage
Postby viridia » Sat Apr 30, 2016 7:17 pm
The belt in the B6 S4 is kinda similar, and the tension pulley doesn't have a spring of any sort. That application you just make it taught with your hand strength and then tighten the adjustment bolt.
87 4k, 90 f350, 91 v8, 93 v8, 04 s4
viridia
Re: Re: Ben's V8 CQ - MR2 pump install
Postby Grillage » Sun May 01, 2016 7:07 pm
I made some more headway today.
Got the Power Steering Pump wired and relayed. Tested it and it fires up. I have it triggered by the ignition switch so it will be always on.
From what I understand about this later version, it senses the resistance on its own and dials back the pressure when it's not called for anyway.
I decided to drill a 1.8" hole in the thermostat and got it all back in there. Loaded it all up with coolant and bled the system and ran it a bit.
The Alternator and new serpentine belt seem to be working just fine.
Unfortunately, The Euro Bumper isn't going to work on this car. It was fitted up yesterday with the radiator out and with it back in I would need to do a lot more cutting than I want to.
So back goes the old ugly bumper.
I did finally get around to figuring a way to install the strips below the headlights. With the large radiator in this car I had to cut off the ends of the headlights that hold them in.
I cut the ends of the strips off and put a screw through the little tab on the bottom into the headlight itself.
Small victory I guess, but a victory no less.
Once the fittings for the PS hose and a bracket I ordered show up I hope to be done screwing around with the engine bay for a while.
CURRENT
PAST
Grillage
Postby PRY4SNO » Mon May 02, 2016 7:28 pm
Looks great with the trims! And of course nice work on the belts, interested to see the long term results.
Seems like you'll have to go R/S2 or Euro V6 for your bumper needs if the Euro Coupe is no good?
Postby Grillage » Mon May 02, 2016 8:23 pm
Thanks!
That's what I'm thinking too. Since this car is really an ugly duckling, I'll likely just leave the NA spec bumpers on it.
I made more progress today on the PS pump install.
The bracket I ordered showed up today from a guy in Montreal that made a few:
I painted it Tornado Red (with my trusty paintscratch.com spray can) and put it in place:
It's a little close to the exhaust manifold for my taste so I took some spare sheet metal and cut out a little heat shield. It's a little hard to see as it got dark:
I'm all done other than a couple fittings to finish the install. They arrive tomorrow and I hope to god this works.
CURRENT
PAST
Grillage
Postby the german » Mon May 02, 2016 11:35 pm
cool! I'm interested to see how it works. Maybe you said this earlier, but given that you got a bracket that was pre-made I'm guessing someone has done this before for this application?
Postby Grillage » Tue May 03, 2016 7:22 am
I know some people have used the earlier version of this pump that doesn't have a reservoir on their cars - (Marc, Greg W).
The writeup I used for info and the source of the bracket was this guy who was installing it into an Acura I think: http://www.k20a.org/forum/showthread.php?t=58599
I'm guessing he makes the brackets. From that thread, It looks like he had some kind of pattern for it.
CURRENT
PAST
Grillage
Postby 90quattrocoupe » Tue May 03, 2016 11:38 am
Grillage wrote:I know some people have used the earlier version of this pump that doesn't have a reservoir on their cars - (Marc, Greg W).
Actually, I don't have one in my car. Jim Green does. I know Marc used one due to limited space with the twin turbos. Jim Green uses one to eliminate the need for making a bracket off the motor. If I am not mistaken, I think Petar used one too.
Greg W.
90quattrocoupe
Postby Grillage » Tue May 03, 2016 11:40 am
That's right! Sorry!
CURRENT
PAST
Grillage
Postby Marc » Tue May 03, 2016 6:30 pm
that bracket is pretty sweet. nice find. let us know how the turnbuckle setup works out for ya.
Hope to see you at Carlisle. we're working hard on a customer project hoping to have it ready for the show.
Proprietor, EFI Express
Postby Grillage » Tue May 03, 2016 9:16 pm
Will Do. Can't wait to see everyone's new projects
I hope to bring this to Carlisle assuming everything is working well. It's a 7 hour drive and I REALLY don't want to get stranded in between here and there. If it's being difficult I'll have to bring the Cabriolet again.
CURRENT
PAST
Grillage
Postby the german » Wed May 04, 2016 12:52 am
:thumbsup: Nice! thanks for the info
Re: Re: Ben's V8 CQ - MR2 pump Success!
Postby Grillage » Wed May 04, 2016 5:25 pm
It all works!
I finally got the last piece I needed today. I ended up going to a local hydraulic shop and having them make a long hose that would replace my existing hose and an 8" extension for the hose in the car rather than a whole new line. I didn't want to make two trips if one approach didn't work.
I ended up using the extension first because I didn't want to pull the intake manifold and all associated stuff again to get to the other end of the hose.
After a quick bleed (all with the engine off too!) I was good to go!
It's a little stiffer steering than stock but no noise and very smooth!
Makes a BIG difference in the way the car drives. Carlisle here I come!
CURRENT
PAST
Grillage
Postby audifreakjim » Wed May 04, 2016 5:51 pm
Sweet! Looks great down there, the integrated reservoir is nice. I'll have to explore that route if mine ever dies.
Postby Grillage » Wed May 04, 2016 5:58 pm
Thanks! That little heatshield works too! I measured 160* on the manifold side and 50* on the pump side with my laser thermometer just now. Crazy!
CURRENT
PAST
Grillage
PreviousNext
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 20 guests
