Bill's 200 20v,on the road again
Re: Bill's 200 20v,cyl#2problem
Postby audios » Thu Mar 09, 2017 9:47 pm
At the advice of Marc ( and many others ) i brought the head to the machine shop in rochester. The friend who brought it down to them just called me to tell me that the head is cracked. I didnt have time to get all the details, but I am wondering if that cracking could have been causing what seemed to be blow-by...I will call tomorrow to find out more details on exactly what is wrong with the head and on which cylinders.
audios
Postby WOMBAT » Fri Mar 10, 2017 5:39 am
audios wrote:At the advice of Marc ( and many others ) i brought the head to the machine shop in rochester. The friend who brought it down to them just called me to tell me that the head is cracked. I didnt have time to get all the details, but I am wondering if that cracking could have been causing what seemed to be blow-by...I will call tomorrow to find out more details on exactly what is wrong with the head and on which cylinders.
I'm curious to know as well.... and where the crack is?
Postby audios » Fri Mar 10, 2017 4:13 pm
Kevin at the shop didnt tell me where the crack is but did say that it wasn't leaking but still woudnt want to rebuild it with a crack, as they obviously dont get smaller only larger... i am sending him down my extra 7a head with a few bent valves so he can make 1 out of 2...
audios
Postby audifreakjim » Fri Mar 10, 2017 5:21 pm
Yeah, like the crack they all have between the valve seats.
Postby audios » Fri Mar 10, 2017 5:39 pm
do you think that the head could be good still? this is the shop Marc sends all his heads to.... ill definately be bringing it back home to take a look when this is all over.
audios
Postby WOMBAT » Sat Mar 11, 2017 8:09 am
Or the somewhat typical crack by the spark plugs.
Postby audifreakjim » Sat Mar 11, 2017 11:44 am
audios wrote:do you think that the head could be good still? this is the shop Marc sends all his heads to.... ill definately be bringing it back home to take a look when this is all over.
Have them show you the crack, if it's just between the valve seats then it's not too much of a worry. If they know the heads, then they are probably talking about a different crack.
Re: Bill's 200 20v,head crack evaluation??
Postby audios » Wed May 03, 2017 10:21 am
Got the head back today, here is a photo of the crack. Anything to be concerned about?Image
audios
audios
Postby dana » Wed May 03, 2017 10:23 am
I think thats a pretty normal 20vt crack to me. I would run it, thats just me.
-efi 10vt 4kq
Postby WOMBAT » Wed May 03, 2017 12:42 pm
dana wrote:I think thats a pretty normal 20vt crack to me. I would run it, thats just me.
That's a textbook 20v crack. Apparently I would run it :P
Postby audios » Wed May 03, 2017 2:31 pm
I'm thinking I should put some valve guides in before I throw it back together? What about reusing a head gasket spacer?
audios
Postby WOMBAT » Thu May 04, 2017 7:45 am
Definitely go guides and seals, I never did them. I'd go new HG too, but have heard some people reuse them a bit.
Postby PRY4SNO » Sat May 06, 2017 3:54 pm
That crack is within the Bentley spec, which (*I think) is no more than 3 threads.
|| 2002 Dodge Ram 2500 24v Cummins 4x4
|| Spare parts for sale
Postby audios » Wed Sep 06, 2017 1:58 pm
Per the bently :
"When repairing cylinder heads, small cracks in the head between valve seats or valve seats and spark plug threads are permissible.
Cylinder heads showing such cracks can be reused without reducing engine service life or performance, providing cracks are small.
Cracks may not be larger than 0.5mm (0.019") or cracks in spark plug threads may not be longer than through first coil of threads."
when it refers to not being larger than .5mm is that the width or the length?
audios
Postby audifreakjim » Thu Sep 07, 2017 10:52 am
I think it's the width
Postby audios » Fri Sep 08, 2017 8:19 am
the only other issue i have before sending the head back to get rebuilt is the statement ' may not be longer than through first coil of threads.' is that the first full coil? it definitely seems to go a bit deeper that that....
audios
Postby mrdeye » Fri Sep 08, 2017 10:37 pm
Fix crack before reinstalling. Crack is not going to get smaller. Yes, head is going to crack in other combustion chambers in same areas. Buy unceacked head in near future. Just me. Good luck with project! :beer:
Previous cars:
mrdeye
Postby audios » Mon Oct 02, 2017 7:40 pm
Progress is slow but engine is on the stand@ my house, will tear into it soon....
audios
Postby audios » Tue Oct 17, 2017 6:04 pm
finally got to start with piston #1 tonite. Here are some photos, does the bearing wear look normal? I noticed the top ring and the middle rings were almost on top of one another, could that have caused some of the blow by?
the ring stuff im doing at my house but up at the farm the body is still waiting to come down. I put it on 4 wheels to get ready :) i miss it....
audios
Re: Bill's 200 20v, rebuild underway
Postby mushasho » Wed Oct 18, 2017 12:23 pm
Broken links everywhere...
Looks like you're using Google Photos...
Here's the trick... Select the pics you wanna share(hotlink) from your main Photos screen. Then "create a shareable album"... you could then hot link THOSE pics from the new album created...
It's just that by nature all Photo Pics are private.
Hope that helps
Postby audios » Wed Oct 18, 2017 5:04 pm
ok i tried, thanks for the tip.... here are some more pics of the piston/rod, LMK if they are visable....
audios
Postby mushasho » Wed Oct 18, 2017 9:40 pm
yup... Visible... Might need to do the same for the previously posted pics tho
Postby Marc » Thu Oct 19, 2017 6:21 am
the ring orientation is certainly not proper, but I think you have a catch can layout problem as well.
Proprietor, EFI Express
Postby dana » Thu Oct 19, 2017 6:52 am
I get that rings are supposed to be oriented correctly when installing, but what is to keep them from turning around in the bore once running? Two stroke rings cannot move because the ends of the ring would snag the ports in the cylinder walls, so they put a little pin in the groove to keep them aligned. I always just figured rings on a 4 stroke move around at will??
-efi 10vt 4kq
PreviousNext
Users browsing this forum: No registered users and 8 guests
