Sam's 20vt CQ - Red and Broken
Re: Sam's 20vt CQ
Postby SEStone » Mon Aug 17, 2015 1:08 pm
Keeping at it. Driver's side is basically done. It just needs some minor clean-up on the panel edges and tape lines. Haven't made a ton of progress the past week due to work and the insanely hot weather we've been having...record high temps all week around/over 115F.
I got a new battery and fired the car up yesterday. Fired off and ran nicely after about 5sec of cranking. Going to redo much of the passenger side with the same materials/techniques I learned on the driver's side. Also need to prime and sand all of the trim as well. Hoping to have it ready to go off to paint after the next two weekends, which I think is totally doable.
((\/)) Evolution Motorsports
SEStone
Re: Sam's 20vt CQ
Postby A20V200 » Mon Aug 17, 2015 5:53 pm
Are you still going to try and make Battle Born..? With or without CQ?
A20V200
Re: Sam's 20vt CQ
Postby All_Euro » Mon Aug 17, 2015 10:12 pm
SEStone wrote:...Going to redo much of the passenger side with the same materials/techniques I learned on the driver's side....
Awesome commitment to quality :beer:
Work - Houzz / linkedin
Play - Haldex Swap
All_Euro
Re: Sam's 20vt CQ
Postby audifreakjim » Tue Aug 18, 2015 12:41 am
Your best panel will always be your last. You can't redo all of them :) looking good though!
Re: Sam's 20vt CQ
Postby jretal » Tue Aug 18, 2015 12:38 pm
audifreakjim wrote:Your best panel will always be your last. You can't redo all of them :) looking good though!
:metoo:
but at the same time, nothing feels better than dusting off the last panel and realizing you're done and ready for the color!
jretal
Re: Sam's 20vt CQ
Postby SEStone » Tue Aug 18, 2015 1:55 pm
A20V200 wrote:Are you still going to try and make Battle Born..? With or without CQ?
Yup, planning on it. I'm going to spray the bumpers this weekend with flexible primer and sand them. I told the body guy I would have everything ready for him first week of September. As long as the super hot weather and work commitments stay away, I think that is entirely doable. Using good materials (primer and sandpaper) makes the whole process soooooo much more efficient. I'm using SEM primer and Mirka sandpaper now, which are the easiest to work with I've found by far. U-Pol sucks, Matrix is ok (I think most of my issue was spraying it with too small of a nozzle), but this stuff goes on like butter and sands off very easily and consistently.
SEStone
Re: Sam's 20vt CQ
Postby pkw » Thu Aug 20, 2015 9:55 am
looks good. shows determination which is the name of the game in bodywork. I paid a pro this time around and I think every day about how my paint is not up to my standards. maybe I could have paid more but that could have gotten me the same paint job for more money.
:mad:
viewtopic.php?f=11&t=1534
pkw
Re: Sam's 20vt CQ
Postby SEStone » Sun Aug 23, 2015 11:59 pm
I got a decent amount done this weekend, but the hot weather and recovering from the week meant I could have done more.
I've spent the last ~4 weeks or so stressed out about a work project that was running a bit behind. It was an epic 997.1 Turbo build, and the hammer was down to get it wrapped up while the owner was available to drive it this season. My techs put in 12 hours days for a week straight in the dog days of Summer and got it cranked out. We got it done, but an issue caused it to be a day later than the customer was available to fly in and drive it home from Phoenix to Park City, Utah, so I 'volunteered' to deliver the car as soon as it was ready. That one really took a lot of convincing...
I intended to leave before noon on Wednesday, as it was supposed to be an 11 hour drive. We had some tuning to finish and a lot of trim to wrap up on the car. After a stop by our detailing shop to get the car spotless, I left the gas station on the way out of Phoenix at 6:50pm. I was piloting a beast...
2007 997 Turbo
3.8L Built Motor - 102mm bore, rods, head studs
EVT775 Kit - 65mm Billet VTG turbos, full bolt on intake/exhaust components, etc.
~650whp, ~650wtq, spool hits like a switch at 3300rpm
Fresh trans w/ Hollinger 60/80 LSD
Short Shifter + Billet Shift Linkage
JRZ RS-Two Dual Adjustable Monotube Dampers
GT3 Adjustable Sway Bars F&R
RSS Control Arms all around, full monoballs, adjustable everything
'Full Retard' Canyon-carver alignment and damper setup
Brembo GT 380mm Brakes F*R
Michelin Pilot Sport Cup Tires
Huge sound system by Audio Gallery in LA
Radar/Laser Detection Built In
The owner spared no expense or cut any corners with the build. It's the first 'start stock, end ultimate' build of this caliber I've done, having driven basically the same package on the Imola shop car years ago. Still, that was not nearly well sorted in terms of suspension setup as this started at (years of experience and good support from my JRZ guy), and didn't have that 3.8L engine lighting the wick on the turbos.
Long story short, this turned out to be the most incredible driving experience of my life. I have driven a lot of these cars. The power, speed, and handling are nothing new to me. But most of these drives are maybe 15-20mi at a time on cars that are not as complete as this was. This time, I had 675mi to go, late at night, through the mountains of Arizona, southern Utah, and Northern Utah, with no real traffic to get in my way. On the very windy two lane highways, I hung out wherever possible between 90-100mph, and was able to hammer the car through sweeping corners to tighter switchbacks.
The engine and drivetrain were amazing--that much power with the width of the powerband pretty much lets you do whatever you can dream of. 3rd and 4th gear go by in a heart beat, a second or two of throttle when trying to pass someone puts you easily past 110mph. But the real impressive part was the suspension. The car was running 650/750lb spring rates, which are about four times what stock is and three times what most commercial coilovers available for the car run (Bilstein PSS10, etc.). Even with the damping cranked up, the ride is arguably better than stock, and the way they handle bumps at speed is amazing. Hwy 89 in northern Utah is not a great road. Lots of frost heaves, uneven pavement, damage from washouts/rock falls, etc. Yet at 95-100mph, speeds which would make my lowered Mk5 GTI crash into the bumpstops and skip over bumps, this was supremely planted and stable. Laying hard into the 380mm Brembos to scrub off 20-30mph over a choppy surface would not generate any ABS intervention, something simply impossible with lesser suspension. The JRZ typically shave a couple seconds off laptimes coming from other coilovers, and this is a perfect example of why.
I spent 6 hours hammering up state highways before chilling out on I15 doing the speed limit for a couple hours avoiding troopers. I finally ended the trip at 5:30am after a 100mph run up the highway following the Provo River near the Deer Creek Reservoir. I knocked back one Red Bull and didn't stop to eat on the whole trip...simply fuelled by the adrenaline of the amazing thing I was experiencing. I spent a couple days in Park City, hit up Miller and talked shop with Jerry Tatum of Tatum Racing, saw my friend Andy Lee getting ready for the Pirelli WC race this weekend, and flew back on Friday.
On one hand, it's motivating, as the CQ will be the fastest, most capably-handling car I'll probably drive for a similar length of time on similar roads in the foreseeable future. But it's also somewhat gratifying, though depressing to know that it may be decades or longer before I get an opportunity to do something similar again in such an amazing, well-rounded machine. A McLaren 12C, Gallardo, R8, or 458 would not live up to the same level as this car over that type of use.
Anyways, back to reality and this project. Saturday, I went to my friend Val's and we shot some flexible primer on bumper and trims. He is putting an E46 M3 back together, so I brought the supplies and we used his tools and garage to knock all of our stuff out at once. We sprayed my trim first, and had to sort out the gun and air pressure settings needed to spray the primer smoothly in 105F AZ summer heat. He found some settings, and combined with thinning out the paint a bit, we finally got it to lay down nicely. I started working on some of the trim today, and have some spots we sprayed early on that have some issues (uneven spray, porosity, etc.), but the bumper should turn out better. I just need to spend the time and make the mess to fix these now.
Until next time...
SEStone
Re: Sam's 20vt CQ
Postby Mcstiff » Mon Aug 24, 2015 12:38 am
Sounds like fun!
Re: Sam's 20vt CQ
Postby SEStone » Thu Sep 10, 2015 8:47 pm
Got down to brass tacks with the body shop. Plan was to finish my business with the car this weekend and drop it off this coming Monday. I gave them a bunch of information on the project, and they shot back a number about $1000 above what I was expecting...the number I'd been quoted before apparently was just labor, no materials. After a slow summer and just sinking $1k in maintenance and tires into my DD, it makes this a real stretch on the finances.
I've been fucking with this for over a year now, and want it done and done right, ideally to go play with it and my friends in Las Vegas in five weeks. However, like almost everyone here, I'm not made of money. I have the friends and resources to DIY this, but I've been down that road now and know it is a not-inexpensive and very labor intensive one.
Fuck.
SEStone
Re: Sam's 20vt CQ
Postby chaloux » Thu Sep 10, 2015 11:06 pm
That Porsche story is great. I've re-read it a few times. I wish I could have done that!
Body work is crazy to me. I don't have the patience to do it, but of all things I'm concerned about, it's down near the bottom. Like there's always something else that could use that money... Sucks. I think the thing is that I just need more money lol
DEAD :( - 1996 S6 mit TDI
Re: Sam's 20vt CQ
Postby Afterthought » Fri Sep 11, 2015 12:50 pm
In regards to the Porsche that 3.8L must be great. I love the twins and how quick the spool can be. Great to see the use of VGT turbos in cars. I havent done much research but it seems like one could have a really cool set-up. The VGT turbo in my dodge is bad-ass and the exhaust brake is pretty cool too.
Great to see the progress on your project. I want to get my coupe painted like yours I'm just afraid to dissassemble it that far!
1983 Ur Quattro Amazon Blue / Zebra MC
GMC 2500HD
Re: Sam's 20vt CQ
Postby SEStone » Fri Sep 11, 2015 4:57 pm
Afterthought wrote:In regards to the Porsche that 3.8L must be great. I love the twins and how quick the spool can be. Great to see the use of VGT turbos in cars. I havent done much research but it seems like one could have a really cool set-up. The VGT turbo in my dodge is bad-ass and the exhaust brake is pretty cool too.
The Porsches are super impressive in their power and how it is delivered. Has to be felt to be believed. That being said, what Hank has done with some of the EFRs and the 07k is really not far off what the dyno shows a Porsche doing. And they're going into these little old Audis that put down power better than even a 911 does. Some, like Jim's and Sean's cars, are sorted enough that the power doesn't overwhelm the chassis. That is pretty fking cool.
I've had some helpful conversations with other people who have been in my shoes. Currently thinking things over and deciding how to get this done. I need to register for BBQ and get a hotel room this weekend.
SEStone
Re: Sam's 20vt CQ
Postby SEStone » Fri Sep 18, 2015 1:24 am
I've been working on the passenger door for about a week now, for absolutely no reason other than I suddenly can't seem to properly spray primer. It's going on too thick and I'm getting solvent pope. It's pretty ridiculous and getting annoying now that I'm on my third prime/sand/inspect sequence. This time it looks ok in that regard so I might be over that hump.
I signed up for Battle Born and are ordering the suspension parts I need to finish that job. I'm starting to think about what I need to fix my header and a nagging coolant leak, and see if I want to add my BBK to the list of last minute things to do. We'll see how it pans out, I need to order now to have everything ready once the car is red.
SEStone
Re: Sam's 20vt CQ
Postby audifreakjim » Fri Sep 18, 2015 9:28 am
Full Monty, nice Sam
Re: Sam's 20vt CQ
Postby SEStone » Sun Sep 20, 2015 11:22 pm
I reviewed all the other panels I sanded with this particular type of primer and they all show the same condition I've been fighting. There are tiny bubbles in the primer underneath a hard shell. It is likely caused by the outside coat flasting over before the solvent on the bottom layer of primer has evaporated. This has been killing me trying to sort out, I've tried different brands of paint and being completely anal about my prep work. I finally found it's probably due to the high temperatures here in Phoenix, as the paint flashes off too quickly. Spraying from a gun would allow the mixture of primer and hardener to be changed and slow the paint down.
I've sanded, observed, and painted over this stuff. It sands flat per the guide coat and reflection. The guide coat doesn't absorb into the bubbles. I'm debating just leaving it be and going for it, but not sure if I should risk $800 in materials. The alternative is sanding all the primer off of a good portion of the car, which would suck.
Painting cars is the worst thing ever.
SEStone
Re: Sam's 20vt CQ
Postby loxxrider » Mon Sep 21, 2015 12:24 am
Lol thanks for reminding me that when doing body work, it's best to just throw money at it and let someone else deal with it! I would imagine that your paint problem is indeed the heat. I would personally just wait and get it *right*.
I too loved the Porsche story. Porsche really do make some great cars. The quality is above and beyond anything else modern (in their price range and below). However, I dare say the quality of our old Audis compete quite well. Of course, there is nothing like the feel a Porsche can give you! I must contest one thing you said though... Do you really think a 458 would not be a better car? I guess it depends what you are using it for. As a GT car, you're right. The 911 Turbos have become essentially GT cars these days! They are so packed full of luxury and speed. For serious driving though, either in the canyons or at the track, I'd say the 458 is damned near unbeatable. I haven't driven the Porsche you're talking about, but I have driven a 458 at the track and dammit that thing is INCREDIBLE. I'm not even sure if I could ever fully master it's capabilities. 560 hp NA in that chassis is PERFECT! <3
Re: Sam's 20vt CQ
Postby SEStone » Mon Sep 21, 2015 1:04 am
The 458 is a car that doesn't really seem at home unless you're going balls out, 10/10ths. The interior sucks, it's built like shit, not refined, and the engine has hair trigger response and is basically useless under 3500rpm. A great performance car, but not something I would look forward to driving every day, and not something I would enjoy taking cross country.
The Mclaren 12C and 650S are an interesting middle ground. In terms of design and engineering, it makes the 458 look like the Flintstone mobile. Some of the technology makes it a better and worse experience than the 458, but it feels like a much more refined and sophisticated car. It uses a carbon fiber tub with aluminum space frames bolted on, and weighs in under 3000lb with low fuel. It also has a screamer of a 3.8L twin turbo V8. 616hp stock, and between that, the weight, and the aero it is a fast car bone stock. 10.5sec@135 1/4mi, mid 6sec 60-130, etc. We built a turbo kit that uses larger Xona Rotor turbos. Current development has it putting down 730whp, and it runs deep into the 9s at 143-145mph. Mid to low 5sec 60-130. Really fun to drive, the noise it makes is pretty awesome. It sounds like a Cosworth DFV F1 engine from the 60s.
The 911 Turbo will always be the king of the practical supercar. On the highest level, they are the most comfortable, easiest to drive, and most reliable super cars out there--by far. But that really sells the performance short on them. The 996 and 997 are capable of incredible performance on the stock motor--650whp/650wtq with a super fat, meaty powerband. The chassis, with the engine in the back and AWD puts it down without breaking a sweat. The 991 drives like it is propelled by a railgun...dramafree 2.5sec 0-60 every. damn. time. All that performance in something that is super docile to drive like any stock block turbo engine, and without terrific amounts of lag either.
The 996 and 997 left something to be desired in terms of handling. Doing all the goodies mentioned on the car above basically completely cure that, and shy of a built motor Z06 on Michelin slicks there isn't much for streetable cars that will hang with one of these in the corners, braking zones, and straight aways. The 991 is superhuman. I didn't exactly hang the tail out on the new Turbo S I spent time in, but it blew me away with how nimble, responsive, and composed it was with anything I could throw at it. I repeatedly thought to myself, 'there is nothing more I could ask from a car than what this is giving me'.
SEStone
Re: Sam's 20vt CQ
Postby loxxrider » Mon Sep 21, 2015 2:44 am
I guess I didn't spend enough time in the 458 to care about the interior, but I thought it was pretty damned nice at the time! I definitely think you're right in terms of everyday practicality. The 458 is just such a precise weapon on the track though... I don't think there is a 911 that can really compete with the turn-in/nose feel and such in the 458. You might say there aren't many people who use the 458 for its intended purpose then... but come to south FL and watch as people beat the 300k car around a track every weekend! :)
The Mclaren's have never really caught my interest. I guess they just seem too... tame. Also, I'd much rather have a Cayman than a 911 to be honest and that's for the same reason I am not too interested in the Mclarens. The Cayman just seems like the true bread and butter car for a company like Porsche. They aren't a supercar company, but 911T and up are damned near supercar money! I think right around 100k (plus or minus 20-30k) is right where Porsche fits in best. If I was going to spend more than that, I'd want it to be something REALLY special (like a used 458).
OK, back to your car. We can discuss further in another thread if you want!
Re: Sam's 20vt CQ
Postby SEStone » Sun Oct 18, 2015 11:39 pm
Fell a little behind on updates, but cliff notes...
Full story sometime later.
SEStone
Re: Sam's 20vt CQ
Postby PRY4SNO » Mon Oct 19, 2015 9:47 am
Looks great Sam!! Must feel amazing to have a car that's all one colour after all that time.
Which red did you go with?
|| Spare parts for sale
Re: Sam's 20vt CQ
Postby SEStone » Mon Oct 19, 2015 4:44 pm
PRY4SNO wrote:Looks great Sam!! Must feel amazing to have a car that's all one colour after all that time.
LY3D 'D' code, which is the darkest of the six shades listed. It was the best match for the unsanded trim pieces I brought in, and happened to be like $175 cheaper/gal than the standard color code. I did Matrix Premium Base basecoat and Matrix Euro clear. The clearcoat is rock hard, requiring lots of work to sand/buff after it dried for 1.5wks before we went about color sanding.
SEStone
Re: Sam's 20vt CQ
Postby SEStone » Fri Oct 23, 2015 2:51 am
This is a full project post I made on another board. It has the entire project start to finish on it, including BBQ6. Enjoy...
I've owned my '90 Coupe Quattro for around four or five years. It was bought as a replacement for my old 80Q, which had begun to fall apart after years of hard use and a 20vt engine swap. It received the rebuilt motor from that car, along with the standalone EFI, coilover suspension, upgraded brakes, and a host of other goodies. I made it fast but it definitely wasn't pretty. The driver side door and fender were mangled together from the previous owner. A beat up B4 hood was installed, and a tattered fiberglass RS4 bumper made its way for a bare plastic Rieger RS2 replica.
I moved down to Phoenix two years ago, and shortly after out of boredom and wanting to do something, I swapped on a straight driver side door and fender. The fender was pearl white, and the door was faded OEM single stage tornado red. A step up, but the car was now five different colors and that needed to go. Quotes from body shops to repair and respray everything came in at $4-5k, which was just unrealistic given the position I was in at the time (and frankly, still am).
Thankfully, I became very good friends with two people shortly after moving down. I had known Jason for more than 10 years off of the corner-carvers.com message boards, and had met him once prior on a trip to Phoenix years ago. He is an Audi nerd and a very smart guy. He had recently done some major collision repair to the quarter panel on his low mile '99 Mustang Cobra, which turned out to be a better finish than the rest of the car. After getting to know Jason, I got to meet Val and Savannah Ivanitski in the search for Coupe parts. They're a young couple who met racing the Pikes Peak hill climb, with Val running in a 4.2 A4 and Savannah running a 20vt CQ the year prior to meeting them. They had just moved to AZ as well, and sold the COupe so I bought some leftover parts. Val owned an UrQ in need of some rust repair and paint work, so I volunteered to get dirty to learn the process and bond with my new friends.
A couple months later, the UrQ was patched up and had been resprayed in his garage. Between the two of them, they owned the sundry tools needed, and the actual process itself was fairly straight forward to pick up. Prep is important, keeping clean is important, and you can fix the inevitable defects later. Sold! In June 2014, I went to a local auto body store (Space Age Paint in Mesa, AZ...open late 7 days a week!), bought a few sanding blocks and a bunch of sand paper, and went to town.
Based on the UrQ, I went around the car opening up things that seemed questionable. Areas of rust, paint that had flaked off, weird body lines. I knew this car had been repainted before after finding some accident damage.
I immediately found two big areas of filler. One I never would have guessed in front of the drivers rear tire. I found the backside of this panel, and verified that there was probably a skim coat of filler filling a small wave of damage. Sanded down to metal to get rid of any rust and this was good to go.
ImageUntitled by sam stone, on Flickr
The other on the rear pan in the dead center back of the car was going to be a huge pain. The body line always looked funny, and rust had begun to creep out of the top. I found filler after sanding through the paint. And more filler. And more. Finally I got a wire wheel and assaulted the rear of the car, striping down to metal. There was 3/8" of filler covering up a hackjob repair of a big dent. Someone had tried to pound the dent out with a pick, making matters worse as it stretched an easily repairable dent into a big mess of metalworking.
This was going to be interesting...
I removed all of the trim, and hit the rest of the car with 180 grit to knock off the outer layer of paint/clear/whatever to get to a solid substrate to begin applying new stuff. The hood was in rough shape, with some rust, rock chips, and heavily damaged paint, so I ended up sanding the entire thing down to bare metal. All of this was in late July into August in Phoenix, so progress consisted of 60-90min at a time sweating my ass off in a 105F garage after dark sucking in paint dust. The angst, and colossal mess began here...
I picked up a book 'The Keys to Metal Bumping' and a $25 hammer and dolly set from Harbor Freight to begin work on that back panel. It turns out that if you're in far enough to be going paint work, fixing metal is not too difficult and actually pretty enjoyable. There are some relatively simple principles to it that involve learning how the dent was formed, and then working your way out from the 'last' damage to the 'first' damage. With that and a couple hours' work, I began to make some great progress flattening out the rear of the car.
I got bold enough to lay a skim coat of filler in preparation to spray the car with high build primer last September.
Jason graciously volunteered his garage, so on Saturday I went over there with a few hundred bucks in supplies and a couple quarts of high build primer to apply to the car. This was an eye-opener into just how much work is involved in spraying a car. I thought I had the car ready to go shy of 1-2hr of work, but almost 12hr of work went by until we had everything masked and were ready to spray.
First down was etching primer over the hood and any other bare metal areas. This primer has acid in it that helps it bond directly to bare metal and give a solid substrate for subsequent primer/paint to adhere to. We sprayed this from U-Pol cans.
Finally, at something like 1am, we began shooting primer. High Build Primer is basically liquid body filler. It is primer designed to lay on thick, depositing enough material that minor suface imperfections can be simply sanded out and leaving a smooth, solid surface designed for paint to adhere to. It's very thick stuff, and unfortunately we ran into issues spraying it. With everything we had invested to that point, I decided to forge ahead and do the whole car, which may or may not have been a good idea. Regardless, we got it done, and at 4am I had a car that was a solid color for the first time ever.
The issues we had spraying had left us with an uneven. The primer was spraying on in particles rather than as an aerosol liquid, so the surface had a texture like sand paper. I forged ahead, applying a guide coat and then wet sanding with 320->400->600 on a block to smooth things out.
The guide coat is meant to give a contrast to let you know when you have sanded all of the low spots out. It can serve to indicate low spots like dents, waves, or scratches, but with my rough primer finish it indicated porosity in the primer. You've gotta sand until all the black specs are gone, even if it means going all the way through the primer...
This sanding process went on forever. It was very tedious, messy, unrewarding work. I spent probably six months working on-and-off on the car just sanding down all of the original high build primer. As I gained experience, I got better and better at detecting and fixing issues. They say your best panel is always your last, and for a while I was basically working in circles around the car trying to improve upon earlier work I had done.
Around late June, I began to get a goal in mind. Battle Born Quattro is an annual event held in mid October in Las Vegas. Hosted largely at my good friend Hank Iroz's shop, it is attended by several long time friends and dozens of old school 5cyl Audis. My friend Jim Green was working on a 07K 5cyl swap into his widebody B3 90Q, and he and Hank supplied some solid motivation. I had to make the event this year...
Based on this new experience, I revisited the back panel I had metalworked, filled, and primed. Block sanding had revealed that there were some low spots, and more significantly some high spots in my work--ridges in the metal were poking through the layers of filler and primer. I ended up sanding this completely down to metal, working things out, filling, and sanding this a couple of times over before I was happy I finally nailed it though, with a very fine layer of glaze filler and no high or low spots on the block.
I also began to go over the other parts of the car with new layers of primer, trying to give a consistent substrate I could lay paint over. I was worried about different color substrates bleeding through the basecoat giving a patchy appearance, and obsessed about minute details of surface finish. Since I didn't have an air compressor, I was spraying automotive primer from spray cans. This actually worked out ok, depending on conditions, but caused my lots of problems later on. I spent a week or two and probably $80 in primer getting this side perfect, with no red bleeding through.
I went to repeat the process on the passenger side, which had been 'done' for 4-5 months. I wanted to cover up the red, and had some major work to do smoothing out some minor defects.
All of this sanding is done 'wet' to keep the sand paper from loading up with dust. You take a spray bottle and fill it with water and a drop of plain dish detergent. The dish soap lowers the surface tension of the water, allowing it to 'flow' better and cleaning the paper and the sanding surface better. It soaks up all of the sanding dust from the primer, causing it to run down to the ground in a big muddy puddle. These puddles then dry out and form all kinds of dust if you rustle them with your foot or move the plastic around. Microfiber towels work best for wiping down panels, but quickly get soaked in muddy water, which dries and turns to dust. Picking up a towel after it's been soiled with dust makes a dust cloud.
This dust and mess was by far the worst part of this project. Painting a car in a garage is not a big deal because you can just wrap everything in plastic and you're done in a day or two--your stuff is no worse for the wear. This dust gets everywhere and sticks to the floor. I started the project in an apartment garage, where I just let it run onto the concrete floor expecting to be able to sweep it up later on. Which was a problem, because you could never really sweep or blow it clean--I probably would have had to pressure wash it. They seal coated the apartment parking lot while I was working on this, and I would walk out of the garage at the end of the night and leave perfect grey footprints for a solid quarter mile back to my apartment. Those footprints wouldn't even wash off of the nice new blacktop when it rained...oops. We moved to a house in late 2014, and I put a big tarp down on the garage floor before I started anything. This worked great, and made clean up super easy.
ImageCoupe Quattro Refinish Project by sam stone, on Flickr
I started to have big problems (or so I thought). It was mid to late August at this point, with daytime temps over 110 and nighttime temps when I was working of 100-105. I was having problems sanding through my primer and running into a very weird porous texture underneath. I was dealthy afraid of that porous texture absorbing basecoat, resulting in a ghost image of the porous area being visible.
I repeatedly sanded this all the way down, and reprimered and sanded. I tried different brands and types of primer. Finally I came to realize that the hot weather was causing the issue. The primer was drying so fast when it sprayed that the outer 'shell' would seal over before the solvents had time to evaporate from the deeper layers of primer. The solvents form voids and eventually disperse over a longer period of time. The only real solution I had available was cooler weather. Thankfully, in early September we had three cool nights below 90F where I made some hay and got a solid surface down. This issue probably cost me 1.5-2wks of work and $150 in materials and gas running to the store to try and fix it.
Somewhere along the line, my RS2 replica bumper received some flexible primer and got some rock chips filled before being wet sanded perfectly smooth.
The door trims also got block sanded smooth. It was shocking to see how uneven these were. They were also a pain in the ass, because they're made of some kind of plastic core coated in fiberglass or paper mache or something weird. They tend to flake apart around the edges, requiring the damage to be picked apart and sealed with glaze or filler to keep them from coming apart further.
Finally, with three weeks to go before BBQ6, we hit zero hour on the paint project and it was time to go. I had actually debated having a pro shop spray the paint to make sure that project went well. However, I got a couple quotes for over $2k labor and materials to spray a prepped car brought to them. I'd gotten quotes earlier in the project for 1/2 to 2/3s that amount, so it seemed high and I simply hadn't budgeted that much, so I stuck with the DIY route, expecting more work to be involved on the back end fixing imperfections.
I went to Space Age and picked up a gallon of Matrix Premium Basecoat along with a gallon of Matrix MS-52 Euro clear. I did the factory LY5D tornado red color, with the shade matched to an original piece of trim off the car. With some fresh 3M respirator inserts, everything came to around $850 for paint, clear, and the associated hardener/reducers.
Val and Jason rolled over early in the day on Sunday, and we got to work prepping the car and masking everything off. We cleaned the car, moved it outside to clean the garage, moved the car in, and cleaned it again. The garage got masked and an air flow scheme devised using 3x box fans and some HVAC filters to control overspray and fumes outside.
By about 3pm, we were ready to begin spraying basecoat.
Image12019941_10103490739132693_6045026430885103708_n by sam stone, on Flickr
We got through two or three coats of basecoat when we realized we had some issues to take care of. There were some runs and some areas reacting oddly with something in the primer. Not wanting to risk all that prep work for a substandard spray job, I pulled the plug for the day to let things cure and allow some work to be done before we finished spraying later that week. It's worth noting that it was 105F that day, and we were standing in a garage full of 1200w halogen lights wearing Tyvek suits. We sweat gallons of fluids out...
The next day, Psycho Sanding Sam began block sanding some problem areas in the hood, driver's door, rear quarter, and wing/decklid. I delicately block sanded these with 600, getting them flattened out and ready to respray. As the social media ribbing crept in that I couldn't paint something without sanding it off immediately thereafter, I may have gone a little Braveheart in pursuit of a smooth finish...
I dare someone to replace the MNAudi front page picture with that.
Since we had passed the recoat time for the basecoat (meaning the paint had cured enough so that subsequent coats could not chemically bond to it), the entire car got hit with a grey Scotchbrite pad to rough up the surface. On Wednesday night, Val came over and we finished the job.
Four total coats of base and four coats of base later, the car was painted. I almost couldn't believe it. Finally!
I had to let it sit for a few days while work events took my attention. Once that was done, I could take a closer look at things. The car had some issues with runs, dirt/bugs, and fairly severe orange peel over many sections of the car. While I was happy it was red, and had anticipated the need to fix imperfections, this seemed like another huge task. Regardless, I hadn't poured so much time, money, and effort into something just to get mediocre results, so it had to be done.
With two weeks to go before BBQ6, I spent the week taking care of some mechanical issues with the car. I replaced the coilover sleeves and perches, as the old ones had seized with an uneven ride height that was prone to causing tire rub. 245/40r18 Sumitomo HTRZIII tires went on as well. They're competent and dirt cheap, which was what I was after having spent so much money on the refinishing project, and uncertain of the condition of the suspension/setup in the near future. I ended up having to roll the front fenders slightly to clear them. Clearances were tested by installing the suspension with no spring and compressing it until the bumpstop was bottomed out. Check out my stance, yo.
My QRS spherical front top mounts got moved to the rear, and camber/caster adjustable offset mounts went in at the front. Along with that went new tie rod adjusters, to facilitate an alignment done at work by my friend Nick. We got the car leveled and corner balanced. I was only able to hit around -1.6deg of camber in the front, but got to 3.25deg caster on each side which is a big upgrade from before. If I track the car it will probably need more camber for tire wear and grip, but for now on the street the car has a great front end on it.
I also fixed a couple coolant leaks, fixed a radiator mount, and welded up a header crack. It got an oil change as well. The car ran like a top after mostly sitting for over a year. With this all done, I put the front end together for the first time. This was pretty special, I walked around grinning for a long time when this started to go together.
On the Sunday before BBQ6, I went over to Jason's with the goal of working out the defects in the clearcoat. In his very well-lit garage, we saw we had a lot of work to do and got down to it. The hoot and roof were first, being the largest flat panels. We initially went over these with a progression of 1500, 2000, and 3000 grit sand paper on a block before moving on to rubbing compound with a foam pad on a DA. The sand paper levels out the orange peel and runs, and the DA polishes out the scratches and gives you a clear reflection. This was getting results, but was extremely labor intensive. Jason whipped out a rotary buffer with a coarse wool pad and rubbing compound. This was super effective at taking care of sanding scratches, saving a huge amount of time. It enabled us to sand the car with 1500 and then buff the remainder out before polishing, skipping a number of steps with nearly identical results. We went through the process on these two panels and got some stunning early results. After arriving at 10am, I got home at 12:30am.
Monday night was a similar story, 6pm to 12am after work. Tuesday night was off, but we were back at it Wednesday after my good friend Brian May arrived into town for the weekend. That night stretched on until I arrived home at 4:30am Thursday morning. We started to make major inroads and the car was looking really, really good and the finish line was in sight.
Thursday night, we were at it again at 6pm. It was supposed to be an early night, sanding and polishing the bumper and some other things. It turned out to be a great night, albeit way too long once again. We not only polished the car, but installed all of the trim and most of the interior panels. After 60+ man hours of work that week, the final results were truly stunning. I was completely over the moon.
Brian and I headed back home around 3am and got a few hours of sleep before waking up to head out to Las Vegas. It was really warm and humid Friday morning while we cleaned the car and packed up.
Image12079657_10106803738979480_2435081994337664979_n by sam stone, on Flickr
We hit the road around 11, and found ourselves in heavy winds and rain about 90 minutes outside of Phoenix. The car ran and drove great with the exception of the windows being adjusted poorly in the door seals, causing major wind noise at speed. Annoying, but we did ok and made it to Vegas in a little over four hours.
Friday night was spent as a meet'n'greet at Iroz. I got to say hi to a number of familiar faces I've talked with online for years and years, and check out their cars. There were a trio of GTX30R-powered Coupes there, including the cleanest old Audi build I've ever seen in Nate S' pearl white car. Brian and I packed it in early to try and catch up on sleep.
Saturday morning was a group drive from the Aliante Hotel to Cars and Coffee in Henderson. It was so cool being in a convoy with a bunch of old Audis for once! CnC was a bit dead, but after an hour or two we rolled over to get gas and hang out at Audi Henderson for lunch and another gathering. We took on 4gal of race gas at the pump, and turned up the boost and timing a little for the afternoon drive. Good times were had at the dealer, and we headed over to the Valley of Fire for what I thought was the coolest part of the event.
If you're ever in Vegas, I highly recommend taking a trip through the park. Not only is an escape from the hellscape of Las Vegas, but it's also an awesome scenic tour. I believe we ended up driving over 50 miles through the park over a couple hours' time. We spent the first part of the tour following two UrQ and Alex's 7A Coupe GT. I had to remind myself, 'when is the next time that is ever going to happen?'.
Fast 4000s were the featured marque apparently. Wiley's, Jeffs, and Ben's are all serious cars and were very patriotic in their color schemes.
Brian and I were just getting going as the lone B3 on the drive.
After a pitstop for group photos, the pace began to ratchet up a bit as the big power cars consolidated together in line. Fun times were had with Philip's 20vt 5ktq, Ben's 20vt 4ktq, Wiley's 20vt 4ktq, and Jeff's 20vt 4ktq. Jeff lost an intercooler hose clamp, which brought the drive to a halt as repairs were made.
We made a few pit stops in the stunning landscape to chat and let everyone catch up and cool down.
After that, I ended up at the head of the group and it was ON. We got a bit separated from the rest, but Ben and Wiley stayed close behind for the last 10-15mi as we hammered through the twisty roads out of the mountains and into the valley. I collected a few rock chips after trading the lead off to Ben, but I'll take them as battle scars from one of the most fun drives I've ever done. At this point I was over the moon. Beautiful landscape, great roads, awesome handling car with tons of power and no issues...what a great day!
Saturday night was a banquet, which we dipped out of early to go see the Monster Energy Cup supercross race which happened to be in town. We got into that free as we got there towards the end, and saw a good race on a ridiculous course.
Sunday, we slept in and hung out at Iroz for a couple hours. I contemplated Hank's offer of throwing the car on the rollers to do some tuning and see how it stacks up to the others, but all I saw from that was dollar signs, horsepower, and broken 01A when 300 miles from home. I'll be back, for sure. We left around noon and made a pit stop at the Hoover Dam. Brian had never been, and it blows me away each time I visit. We went back home via Flagstaff, a couple hours out of the way but I wanted to try making the Black River Canyon north of Sedona before the sun went out. We didn't get there in time and headed down the mountain back to Phoenix.
I cleaned the car this week and did a post mortem after the event. I've got a rear diff leak and something from either the transmission or my catch can leaving some drips on the ground. All in all, if that's all that's wrong with my 25 year old car that I let sit for a year, then beat the hell out of for 1500 miles in a week, I'll take it.
Maintenance aside, the car is far from done. There is more work to be done polishing out the paint. I have some things I'd like to do to the front bumper, adding some black vinyl to continue the trim line and installing grilles. The list goes on and on, who knows if this car will ever be 'done'. But in the meanwhile, I'm looking forward to participating in the active Arizona car scene, getting out and enjoying the wonderful roads and landscapes this part of the country has to offer.
Lastly, this project would absolutely not have been possible without the help of a few people. Thank you to Val and Jason for all of your massive efforts and gracious contributions in tools, materials, beer and pizza to this. Thank you to Heather for putting up with this for a year and a half. Thank you to Brian for taking a week out of your busy unemployment schedule to come stay up late working your ass off on my car before hanging around with a bunch of old Audi nerds for three days. Thank you to Nick M. for the alignment. Thank you to Chris at Elite Auto Finishes for the advice, and bunch of people at Space Age Paint for advice and materials to get this done.
SEStone
Re: Sam's 20vt CQ - Painted! Summary and BBQ6 Inside
Postby ringbearer » Fri Oct 23, 2015 9:12 am
Woah, reading it all at once sure puts it into perspective.
Congratufukinlations!
It is beautiful and you earned it, well done!
Thanks for the BBQ update as well
Postby pilihp2 » Fri Oct 23, 2015 10:29 am
Awesome post, Sam.
The work you put into paint is crazy, and it really shows. The thing is gorgeous.
Awesome job!
05 S4 - "Daily"
PreviousNext
Users browsing this forum: Google [Bot] and 6 guests
