Magellan's 1991 Audi 200 Quattro 20v - Fuel is for the tank
Re: Magellan's 1991 Audi 200 Quattro 20v - Spring 2015
Postby lucidmatt » Tue Jan 12, 2016 1:35 pm
loxxrider wrote:Add material to what?
I assume solder?
Good to see you back mage!
lucidmatt
Postby PRY4SNO » Tue Jan 12, 2016 10:51 pm
I assume solder?
Yeah, sounds like he means he just reflowed the soldered joints to reestablish the connection.
|| Spare parts for sale
Postby mushasho » Tue Jan 19, 2016 5:50 pm
Nice to see how giving you a little sh!t has motivated you ... now... while you were there, did you do what I think you did with that last minute hiccup we encountered?...
Postby chaloux » Tue Jan 19, 2016 7:55 pm
Hold his breath? Drink vinegar? Do a headstand?
DEAD :( - 1996 S6 mit TDI
Postby mushasho » Wed Jan 20, 2016 1:04 pm
In an effort to get you into a decent exhaust, I recommend one of those 2003 2.0 Turbo WRX jobs that UrS guys can make fit... I'm not sure if C3 chassis would accept it though...
exhaust 001.jpg (184.66 KiB) Viewed 7705 times
exhaust 003.jpg (144.22 KiB) Viewed 7705 times
exhaust 004 (1).jpg (162.36 KiB) Viewed 7705 times
Postby pilihp2 » Wed Jan 20, 2016 2:02 pm
bumper exit spot on t44 and c4 look to be very very very close, everything else under there should be the same.
05 S4 - "Daily"
Postby lucidmatt » Fri Jan 22, 2016 3:40 pm
mushasho wrote:In an effort to get you into a decent exhaust, I recommend one of those 2003 2.0 Turbo WRX jobs that UrS guys can make fit... I'm not sure if C3 chassis would accept it though...
TANABE EXHAUST GOOOOOOOOOOO
lucidmatt
Postby themagellan » Sun Jan 24, 2016 2:43 am
mushasho wrote:Nice to see how giving you a little sh!t has motivated you ... now... while you were there, did you do what I think you did with that last minute hiccup we encountered?...
Haha!!!! You know me way too well....
The exhaust looks really amazing, I'm going to look into the wrx stuff but ultimately will probably contact you for the turbo back contact (in the meantime I might come up to visit our friends with a few glass packs for a sticker) :hide: as there are some better investments happening on the car right now :)
Hope to see a rubi update!
Thanks for all the love everyone
Postby themagellan » Sun Jan 24, 2016 2:45 am
Also if you have an eBay link to that 2003 wrx exhaust please link!
Postby themagellan » Sun Jan 24, 2016 2:52 am
PRY4SNO wrote:
I assume solder?
Yes!
Postby themagellan » Tue Jun 12, 2018 4:05 pm
Long time update - Car is still being used very often for short trips and has seen a lot of rest, relaxation, and garage time (131,070 on the clock)
Here's a quick run down:
- New ISV (I chased this issue for about a year (hot-start issue)
- Fixed parasitic battery drain (Leaking After-run pump running forever)
- New Battery (Correct size - WOW!)
- New ATE Master Cylinder
- Upgraded front brakes (4 Piston Porsche with A8 Rotors/034 Brackets/Apikol SS Lines)
- Upgraded rear discs & Apikol lines
- Bled Brakes with High temp Fluids
- 17" OEM Audi Wheels + 20mm Spacers & Long Bolts to clear brakes (Fresh All Season UHPs (17/45/225)
- Upgraded Exhaust Full 2x 2.25" with new cats and an OEM Muffler (Loudi is dead but I can drive it without making a scene).
- 1/2" Copper elbow to bypass After-run pump :hide:
- Changed belts
- Made a vent cut out for boost gauge that looks OEM (In my humble opinion)
- Upgraded to Bosch 040 Pump (Thinking I had a check valve issue)
- Upgraded Injectors to Volvo Red Tops (Thinking I had a fuel injector leak)
- New Distributor
- New Plug Wires (3rd time replacing)
- New G28 & G4 (Bought actual OEM ones that work excellent)
- Installed Transmission Mounts
- Rebuilt passenger side axle
Probably a lot more but that is what I can remember off the top of my head.
Probably going to start thinking about the T-Belt/Waterpump, The steering can be a little vague on center (Damper?), The paint could use a little love, Have an AAN ecu to put in with a harness from Marc (Still need to contact you about this), Probably going to keep the k26/T04E out of it until I do the Tbelt, I need to upgrade to Samco hoses too as mine have started deteriorated again but hold boost well, I also need to install a new brake pressure accumulator or convert to Vacuum.
Here is a picture of how it currently looks and a low res pic of the brake upgrade.
The car is a real hoot and completely back to sleeper mode. It's the best its been since owning it for ~7 years or so.
Oh... It still doesn't have a headliner or radio :idunno: :hide:
Cheers!
Re: Magellan's 1991 Audi 200 Quattro 20v - 2018
Postby Aktapod » Tue Jun 12, 2018 11:42 pm
Yes!! Love seeing updates to my twin. Glad you've been treating her well in your absence on the forum.
I've got the same issue with dead on-center steering. Not sure if damping would solve the issue, but I remember reading something about adjusting the rack preload in the Bentleys. I'm probably gonna have my rack rebuilt (cause it's leaking like a sieve) and then I'll mess around with that. Oh, and add a shitload of caster.
Now get those Euro lights installed!!
- 1991 200 20vt
- 1992 Audi V8 5-speed swap
Aktapod
Postby themagellan » Thu Aug 16, 2018 3:37 pm
Spent a half day cleaning 4 years worth of grime off the car.
Image (Yeah yeah coolant reservoir blah blah I know haha)
Finally installed the euro lights after 4 years of hoarding. It's all been done with spade connectors, so future removal for work will be easy to do.
Since I haven't seen this answered anywhere and the reflectors are NLA / hard to find I came up with a solution that uses the stock corners and retains blinkers.
Simply take a mini hacksaw and cut a pilot hole on the corner. After that just cut through the sides evenly.
Still need to find some chrome clips to replace the lame ziptie.
I also repaired my cracked wiper fluid reservoir and cleaned up some wiring terminals.
Found a nice venair replacement IC hose too since 034 one was junk for a third time in 20k miles.
Currently doing a deep cut and claybar will see what I can polish with my DA.
Keywords for the homies:
Stock Audi 200 t44 reflector euro lights C3 mod
Re: Magellan's 1991 Audi 200 Quattro 20v - 2019 the
Postby themagellan » Mon Jan 21, 2019 1:09 pm
Car had been enjoying the PNW weather and lack of salt. It runs and drives excellent and I am really pleased I have kept with it over all these years. It's still <135k miles and doesn't get used much since I now have a new daily (f150 SCrew)
Also got some dent removal tools and have been fixing everything possible, starting to look good!!
Ended up buying the correct euro light reflectors which I enjoy big time.
Might have some plans to build some more power this spring, might just keep enjoying it as it is.
Enjoy!
Re: Magellan's 1991 Audi 200 Quattro 20v - 2018 (Euros are i
Postby themagellan » Sat Feb 23, 2019 5:46 pm
I decided to replace the feed fuel line and I am glad that I did. After seeing the line from under the car it was apparent it was past it's prime.
Probably the easiest repair I've had to do to the car, definitely not the easiest to find a good replacement part.
Also added a new 710 valve and drove it a few hundred miles - it's a little over 135,000 now.
Previous
Return to Projects
Users browsing this forum: Majestic-12 [Bot] and 14 guests
