TCombs UrS4, Coolant leak, Voltage Regulator
Re: TCombs UrS4, Coolant leak, Voltage Regulator
Postby TCombs » Fri Feb 07, 2020 3:54 pm
Replaced the VR. Now all my lights, interior and exterior pulse, they go dim and bright non stop. I also feel like the car is idling a bit differently now. Is this normal for a new VR and just takes a bit for the "keys" to get a grove ground down in them from being flat as brand new, or did I maybe get a crappy VR?
1994 Audi URS4 Emerald Green
2010 Audi A5 Meteor Gray
2006 Yamaha FZ6
TCombs
Postby ringbearer » Mon Feb 10, 2020 11:43 am
Check voltage!
Postby TCombs » Fri May 22, 2020 6:52 pm
Nothing to exciting happened recently, just some little maintain items. I have had an intake spacer probably longer than I have had the car, if I recall correctly. Thought it would be time to throw that in. As you obviously have to take off the manifold I thought it would also be a good idea to replace and upgrade the thermostat housing. Got a metal one from EFI. It was leaking a little anyway. Seemed a little rusty in there, but got some purple scotchbrite and cleaned it all up nice. I also replaced the coolant reservoir with an OEM from my brother-in-law's old UrS as I believe the old one was leaking coolant form the sides where the two halves meet. With the intake off, I also replaced some breather parts that I have had for years. There was oil residue everywhere under the intake and seemed to be some caked on oil deposits in the runners of the intake. Came off all like glue, but there was no oil residue in the intake house or throttle so must have been coming from the breather. I found a tear in the breather house, but don't know if that was there or if it was from taking the system off.
I still believe there is a little leak somewhere. Not coming from the reservoir or the thermostat as much as I can tell. The top coolant hose was leaking a little while checking for leaks. Put on a new hose clamp and it seemed to fix it but I don't know the age of the hose. Might be worth just replacing that housing (if I can find one) since its an easy swap. I flushed the system several times, but the dye I put in is pretty potent. Not necessarily the worst thing. Will make tracking leaks a little easier, and this way it won't be neon green everywhere. My bro also hooked me up with some intercooler supports for the bottom. Took about two minutes with his CAD and water jet system. Pretty rad. As we were putting the front bumper back on, we noticed that the bottom center grille (LLTek front valance) is rubbing on the intercooler and the driver's side grille is hitting the intercooler piping, preventing the bumper from sitting flush with the trim. I'll most likely will have to take a Dremel and get rid of some material on in the center. Still haven't figured out quite what to do for the driver's grille to help it sit flush. The front valance needs some TLC anyway. (Fibergalss repair, with some aluminum strips on the bottom for support and maybe fiberglass in some nutserts or just nuts in general for making a skid plate later down the line.)
2006 Yamaha FZ6
TCombs
Postby themagellan » Sat May 23, 2020 6:56 pm
Glad to hear it’s going well.
I read a few places the 034 billet checkvalves ballbearing get stuck, might be worth picking up an OEM(ish) plastic one
Postby TCombs » Mon May 25, 2020 10:56 pm
themagellan wrote:Glad to hear it’s going well.
I thought I might have read that somewhere as well. I have one in my box, (OEM-ish, will have to check the brand), but I had spaced it and the 034 parts were all together and already in the parts pile when I installed everything. I'll keep an eye on everything.
Thanks
2006 Yamaha FZ6
TCombs
Postby TCombs » Wed Aug 05, 2020 1:05 am
Finally got some new IC lights in. The left side of the tach always seemed a bit dimmer. I ended up replacing most of the lights and everything is pretty uniform now. It's hard to tell from pictures though. When I first got the car I noticed that the check engine light, airbag light and some others weren't actually on. When I pulled the IC the first time I found that the little tabs on the lights had been broken so the actual bulbs were just sitting behind the housing. I found some replacement holders with wires attached and cut the old bulb and housing and soldered the new ones in. The new wires were just a little bit thicker, but because its not the opposite of the new wires being thinner I should be alright (I think, I am not very knowledge with wiring, I just know enough to get by). One of the big highlights was I got my outside temp bulb replaced. Desoldered the old bulb and installed the new one. Intsall didn't go as smoothly as I had hoped, the dang holes for the new bulb wires are just so small I was having an issue getting it in without bending and breaking the wire. Good thing you only need about 1/8-1/4" of new wire and the bulb wire is about an inch long. I still have the auto check bulb warning (headlights). I replaced that bulb and swapped the rubber cover over the new bulb, but its still not illuminated so I'm not quite sure what is going on there. I "tried" to lobotomize the auto check but its still on. I'll try it again at a later date.
I also figured out why my boost gauge isn't as bright. The oil temp and pressure gauge have a clear plastic surround that goes around the entire gauge to reflect the light from the single bulb, the boost gauge does not have that surround. Going to try and think of some ideas to reflect the light back at the gauge face. Or just go with an electric gauge.
2006 Yamaha FZ6
TCombs
Postby AudiSport4000 » Wed Aug 05, 2020 8:51 am
Looks awesome. Always nice to have bright and uniform cluster lighting.
Postby themagellan » Thu Aug 27, 2020 9:59 pm
Nice upgrade on the dash - the weak boost light could just be due to where you tapped into the 12v, try to find a stronger + wire to tap off or bench test with a good battery.
Previous
Users browsing this forum: Majestic-12 [Bot] and 20 guests
