Avant 200 version 3.0 new and improved
Re: Avant 200 version 3.0 new and improved
Postby maxnadri » Fri Apr 13, 2018 4:50 pm
Repeat
maxnadri
amd is the best wrote:Intercooler shipped today! Thank you very much man! And thank you Marc for coordinating.
If you need any tips on installing it, just let me know.
I just received it last night after work, came home early so I could stuff it in and yes...if you have a few tips....this thing is MASSIVE to stuff in such a small place lol. ImageImageImage
Sent from my SAMSUNG-SM-N920A using Tapatalk
maxnadri
Postby amd is the best » Fri Apr 13, 2018 5:39 pm
You’ll need to remove the little plastic grill nut in the center and possibly the left grill latch. I loosen the two 13mm bolts on the core support (at the frame rails) and it allows you to pull up the core support enough to slide it into its new home.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best
Postby maxnadri » Fri Apr 13, 2018 7:05 pm
amd is the best wrote:You’ll need to remove the little plastic grill nut in the center and possibly the left grill latch. I loosen the two 13mm bolts on the core support (at the frame rails) and it allows you to pull up the core support enough to slide it into its new home.
Seriously the best advice. Loosened the 2 thirteen mm bolts on both sides, lift up and slipped the downpipe side in first and it slide in so easily! I was told this was plug and play....the hardest part about the instal was getting over my own doubt it was going to fit lol. Excellent work!I am finally the owner of something SHINY [GRINNING FACE WITH SMILING EYES]
THANK YOU ImageImageImageImage
maxnadri
Postby amd is the best » Sat Apr 14, 2018 6:51 am
It’s a tight fit but I wanted it to be as big as physically possible for the stock space. You’ll likely have to remove the black grill clip on the left side to get the cooler into the rubber grommets in the core support. The grill is still pretty secure with only the one clip on the right side. Plus when the hood closes it has nowhere to go. Again, one slight downsIde to building the largest possible stock cooler replacement.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best
Postby maxnadri » Mon Apr 16, 2018 12:22 pm
I will have to look at my back up core support as I did not see any rubber grommets on mine. I may have to go to Fastenal and pick something up. Oh the fun of modifications...I am starting to get excited knowing it could be a week or so before I can start it back up.
maxnadri
Postby amd is the best » Mon Apr 16, 2018 12:37 pm
Those aluminum dowels on the side of the intercooler are supposed to slide into the rubber grommets. Hopefully your spare core has them and the bracket.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best
Previous
Return to Projects
Users browsing this forum: Google [Bot] and 14 guests
