01E swap into B3
Re: 01E swap into B3
Postby Lucky » Wed Jun 27, 2018 9:27 pm
Yes you can use the b3 slave. I'm currently using the metal b4 one in my fyf 01e. I just unbolted it and let it hang until I reinstalled the transmission, no bleeding that way.
1988 audi 80, 1994 Urs4, 2005 Ranger
Lucky
Postby quattrobros » Thu Jun 28, 2018 1:55 am
can you not use a b5 slave?
quattrobros
Postby Grillage » Thu Jun 28, 2018 5:46 am
quattrobros wrote:can you not use a b5 slave?
It has a different fitting for the hydraulic line. At least what I received does.
CURRENT
1995 90 Quattro 20VT
1994 Cabriolet - 5 speed
PAST
Grillage
Postby the german » Thu Jun 28, 2018 9:59 am
Yes, slave is the same between 01a and 01e
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
the german
Postby Grillage » Thu Jun 28, 2018 10:22 am
Thanks gentlemen
CURRENT
PAST
Grillage
Postby vt10vt » Thu Jun 28, 2018 1:31 pm
Grillage wrote:What slave cylinder do I want to use? Can I use the b4 01a slave?
Slaves are the same 01A/01E but I'd look for a metal 01E version if you have to replace it anyway.
Postby Grillage » Thu Jun 28, 2018 1:36 pm
I ordered another 95 90Q slave - the B5 S4 slave I bought is definitely different and getting returned:
https://www.autohausaz.com/pn/SH6142
CURRENT
PAST
Grillage
Postby vt10vt » Thu Jun 28, 2018 3:12 pm
Grillage wrote:I ordered another 95 90Q slave - the B5 S4 slave I bought is definitely different and getting returned:
Is it just because of the hard line fitting? Everything B5 (01A and 01E) is the same slave, but I guess the B3/B4 chassis might use a different kind of fitting. Other than that there literally can't be any differences dimension ways; they're the same trans as a B5 after all.
Postby the german » Thu Jun 28, 2018 3:49 pm
correct. B5 and later is typically plastic and uses a different style of fitting. B3/B4 are typically metal and use an M10x1 threaded fitting.
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
the german
Postby A1QSHIP » Mon Jul 02, 2018 2:30 pm
the german wrote:correct. B5 and later is typically plastic and uses a different style of fitting. B3/B4 are typically metal and use an M10x1 threaded fitting.
For the B4 metal slave cylinder.
M12X1.0 on the inlet hose fitting from the clutch master to the clutch slave.
M10X1.0 on the bleeder screw fitting.
Nulla tenaci invia est via
A1QSHIP
Previous
Return to Projects
Users browsing this forum: Majestic-12 [Bot] and 14 guests
