eS2 evolution
Re: eS2 evolution
Postby FFF » Fri Apr 20, 2018 6:02 pm
Spent some time today prepping for wiring. Shrink wrapped what stuff is so that it is easier when working on/in the car. I think all of this tedious work will speed things up when I actually start!
And my helper... not really, but he likes hanging out in the car.
FFF
Re: eS2 evolution
Postby Grillage » Sat Apr 21, 2018 8:28 am
This project is great!
on the subject of Electric Power steering - I used a later MR2 pump when I did my old V8 coupe. You can see the progress here:
viewtopic.php?f=11&t=1219&start=350
It was a good - not great solution.
certainly had power steering but it was a little heavy and the pumps are noisy
CURRENT
1995 90 Quattro 20VT
1994 Cabriolet - 5 speed
PAST
Grillage
Re: eS2 evolution
Postby FFF » Sat Apr 21, 2018 8:41 am
Grillage wrote:This project is great!
Good to know on the noise and heavy steering, I did look at the mr2 pump when doing my preliminary research but wanted to install a new more modern pump. I still haven’t 100% decided on the electric pump route. If I do it I think I will be putting the pump in the back (under) the car... going to spend some time on the fuel system this weekend I think to figure out space. I’v also looked at upgrading the bomb to a modern lightweight accumulator...
All of this could be a phase II / next winter as I would really like to have it running before next winter!!
FFF
Re: eS2 evolution
Postby FFF » Sat Apr 21, 2018 11:59 am
Moving parts around so thought I would throw a couple of snapshots up. Certainly not the first time Hanks work has been posted but it’s hard not to stare at the art.
And old vs new (Xona 8267)
FFF
Re: eS2 evolution
Postby Afterthought » Sat Apr 21, 2018 5:39 pm
FFF wrote:Moving parts around so thought I would throw a couple of snapshots up. Certainly not the first time Hanks work has been posted but it’s hard not to stare at the art.
Manifold looks nice. I’m convinced that these cars sound so much cooler through a tubular manifold !
Decent sized turbo !!!!
In the wires that looks really good . I need to find something like that for my 83. You print on it and then heat shrink the labels ?
1990 Coupe
Re: eS2 evolution
Postby FFF » Sun Apr 22, 2018 7:22 pm
It just a Dymo label maker, then you buy dymo shrink tube that is in the cartridge and print away. Quite reasonable and makes life with wiring much better later. If the wires are in a really harsh environment I throw clear shrink wrap overtop so that the labels don’t get destroyed.
FFF
Re: eS2 evolution
Postby FFF » Sun Apr 22, 2018 7:28 pm
So we finally got some decent enough weather for me to get 27 years of grime mostly off. About as good as I’m going to get it without a complete disassembly and a steam cleaner and hoist.
Looks better in person... and some stuff just wasn’t coming off regardless of how hard I scrubbed.
FFF
Re: eS2 evolution
Postby Afterthought » Tue Apr 24, 2018 11:57 am
The underside looks really good . I always thought that the cars up there suffered .
I don’t know if you mentioned it already but if you plan to do anything with that brake bomb , do it now ! Easiest time to work on the rack and stuff
1990 Coupe
Re: eS2 evolution
Postby ringbearer » Tue Apr 24, 2018 12:02 pm
So fresh and so clean!
Re: eS2 evolution
Postby FFF » Tue Apr 24, 2018 11:14 pm
Afterthought wrote:The underside looks really good . I always thought that the cars up there suffered .
Miraculously the bomb is leaking... I am however looking at keeping the hydraulic assist - currently looking at a few different composite accumulators to replace it with - also looking at an electric power steering pump, need to decide sooner than later...
FFF
Re: eS2 evolution
Postby FFF » Tue Apr 24, 2018 11:15 pm
FFF
Re: eS2 evolution
Should say isn’t...
FFF
Re: eS2 evolution
Postby FFF » Sun Apr 29, 2018 3:52 pm
Working on replacing rear subframe bushings... maybe I should have done a search first but I didn’t.
So after trying a few techniques the one that worked by far the best was as follows:
Loosen all 4 bolts holding the subframe.
Remove bolts and lower whichever side you are doing to give access to the top.
I used an air chisel to remove the rubber on the top of the bushing as shown
Then a floor jack under frame, 18 mm socket between car and bushing and then use the car weight as a press.
A couple of hits with the air chisel under neath and it presses itself out...
FFF
Re: eS2 evolution
FFF
Re: eS2 evolution
Postby FFF » Sun May 13, 2018 6:40 pm
Engine bay cleanup /spray. Ready to start running wire, although I still need to replace front subframe bushings...
FFF
Re: eS2 evolution
Postby FFF » Sun May 13, 2018 6:43 pm
FFF
Re: eS2 evolution
Postby FFF » Tue May 15, 2018 8:57 am
Getting modules mounted for running wiring.
FFF
Re: eS2 evolution
FFF
Re: eS2 evolution
Postby PRY4SNO » Thu May 17, 2018 7:18 am
Lots of double posts with Tapatalk, eh?
What's that 034 module... IIc?
Did the carbon fibre backing plate come with the Infinity Box?
|| Spare parts for sale
Re: eS2 evolution
Postby Lucky » Thu May 17, 2018 8:56 am
PRY4SNO wrote:What's that 034 module... IIc?
Looks one of the relay/fuse panels. I have one in my 80.
1988 audi 80, 1994 Urs4, 2005 Ranger
Lucky
Re: eS2 evolution
Postby FFF » Sun Jun 03, 2018 9:27 am
PRY4SNO wrote:Lots of double posts with Tapatalk, eh?
Just the fuel pump relays to run these...
FFF
Re: eS2 evolution
Postby FFF » Sun Jun 03, 2018 9:28 am
Oh and no the carbon fibre plate was leftover from another project
FFF
Re: eS2 evolution
Postby FFF » Thu Jun 21, 2018 6:56 pm
Slow progress...
Fuel pumps mounted before I hit the road again, duel 044’s in 1 litre surge tanks.
Nice box of goodies when I got home from Gatebil in Mantorp, Sweden last night...
FFF
Re: eS2 evolution
Slow progress...
FFF
eS2 evolution
Postby FFF » Fri Jun 22, 2018 9:08 pm
Moved to the front end tonight, I have more cleaning and some POR15 paint to apply before I start putting stuff back together.
Definitely prefer the cleaned up topside view.
FFF
PreviousNext
Return to Projects
Users browsing this forum: No registered users and 14 guests
