eS2 evolution
Re: eS2 evolution
Postby Afterthought » Fri Jun 22, 2018 9:21 pm
Engine bay looks great. I really hated sanding all that on my URQ !
What’s that master cyl??
1990 Coupe
Re: eS2 evolution
Postby FFF » Sun Jun 24, 2018 6:14 pm
Thanks. Certainly a pain but I wouldn’t have been happy if I hadn’t cleaned it up given how stripped the car is.
It’s a Wildwood from ChaseBay. Found a couple of E30 guys that run them that like the setup.
“They” say that this is the sweet spot for pedal feel and power based on master cylinder piston diameter. I kept the hydro-boost in case I don’t like it...I don’t mind a heavier pedal as long as it is a linear feel.
FFF
Re: eS2 evolution
Postby FFF » Mon Jun 25, 2018 10:39 pm
A little more accomplished.
Front end is close to being reinstalled.
KW Variant 3’s
AKMotorsport 12mm offset top mounts.
FFF
Re: eS2 evolution
KW Variant 3’s
FFF
Re: eS2 evolution
Postby FFF » Mon Jun 25, 2018 10:42 pm
Ok that’s weird, gave me an error on the post and a double post...
FFF
Re: eS2 evolution
Postby PRY4SNO » Tue Jun 26, 2018 8:18 pm
That's Tapatalk for you lol
Man everything is just going in so smoothly, looks minty fresh. How did you remove the old subframe and control arm bushings?
|| Spare parts for sale
Re: eS2 evolution
Postby FFF » Wed Jun 27, 2018 7:40 pm
PRY4SNO wrote:That's Tapatalk for you lol
The control arm bushings I just used a air hammer. The front subframe was super easy because I pulled the from out.
1 1/4 hole saw to drill out the center bushing.
Then an air chisel to pop them out. Maybe 15 minutes in total.
FFF
Re: eS2 evolution
Postby FFF » Wed Jun 27, 2018 7:43 pm
FFF
Re: eS2 evolution
Postby FFF » Wed Jun 27, 2018 7:58 pm
WTF on the double posts. I post, then a notice saying double post. If I cancel, it doesn’t post anything, but if I retry it’s doing it twice?
FFF
Re: eS2 evolution
Postby PRY4SNO » Wed Jun 27, 2018 7:59 pm
That's a tapatalk fail... one of a few prominent reasons I abandoned the platform (personally speaking).
Good call on the combo of the hole saw and air chisel, I think I see some of that in my future. Thanks for the pointers!
Re: eS2 evolution
Postby Afterthought » Wed Jun 27, 2018 9:59 pm
Here’s the secret recipe .
Post (will get error message )
Ignore errors . Hit back button
It will ask if you want to abandon post . Say yes.
It takes you back to your thread and no changes appear . Go back to main forum page then go forward to your thread again. Now the new post appears .
That is what has been workin for me at least. Even though it says the post didn’t work it really did so if you post again it will duplicate , or give you the “top soon” message .
1990 Coupe
Re: eS2 evolution
Postby FFF » Wed Jun 27, 2018 10:38 pm
Perfect, thanks.
FFF
Re: eS2 evolution
Postby the german » Thu Jun 28, 2018 12:08 am
This exchange has affirmed my decision never to use Tapatalk
Re: eS2 evolution
Postby FFF » Fri Jul 06, 2018 3:12 pm
the german wrote:This exchange has affirmed my decision never to use Tapatalk
Really the main reason I use it is I am too lazy to do photos through a hosting service...
FFF
Re: eS2 evolution
Postby Afterthought » Thu Jul 12, 2018 8:33 pm
Yeah it’s a pain, but for me it’s better than uploading each photo to a hosting site and trying to translate the link.
That is Until Tapatalk deletes the photos stored then every thread looks like all the other ones where photobucket was used
1990 Coupe
Re: eS2 evolution
Postby PRY4SNO » Thu Jul 12, 2018 9:58 pm
Honestly, imgur isn't that convoluted.
Re: eS2 evolution
Postby FFF » Sat Jul 14, 2018 8:04 pm
AKMotorsports front track rods installed.
FFF
Re: eS2 evolution
Postby FFF » Sun Jul 15, 2018 9:04 am
Looking for some input - I have a couple of thoughts on this but wondering if others have found a really good way to clean the carpet while out of the car...
FFF
Re: eS2 evolution
Postby DE80q » Sun Jul 15, 2018 10:05 am
Pressure washer with carpet cleaner.
Re: eS2 evolution
Postby FFF » Thu Jul 19, 2018 7:32 pm
Slow progress.
Used Sonix wheel cleaner to clean front calipers. Amazing how well it worked.
Front end back on
FFF
Re: eS2 evolution
Postby PRY4SNO » Thu Jul 19, 2018 10:49 pm
#sofreshandsoclean
Re: eS2 evolution
Postby rallyfreak202 » Mon Aug 06, 2018 12:16 pm
Looks awesome. I didn't know AK made those front tie rod ball/heim joint assemblies. Nice! I have a homebrew setup on the rally car. Love the parts and quality this build is getting.
rallyfreak202
Re: eS2 evolution
Postby FFF » Mon Aug 06, 2018 3:11 pm
rallyfreak202 wrote:Looks awesome. I didn't know AK made those front tie rod ball/heim joint assemblies. Nice! I have a homebrew setup on the rally car. Love the parts and quality this build is getting.
Thanks - I’m hoping to do a little track stuff, 1/2 mile etc (maybe do One Lap of America), play on the streets and am not willing to go at it half assed given the performance I am seeking... have to be able to stop and turn! My main struggle is that I chose to not do a cage... I guess I will see if I change my mind on that later (most likely but...).
FFF
Re: eS2 evolution
Postby FFF » Fri Sep 07, 2018 9:09 pm
Finally getting back to some work on the car, I’ve been travelling a ton for work and trying to get some family time so haven’t done a thing...
I wish I had given a little more thought to doing the rear subframe bushings earlier, I should have waited until I dropped it out. I initially was planning on doing the rear end bushings with the frame in the car but figured it will be easier to do everything with the frame out....
I think I’ll seam weld up the sub frame while it is out... for anyone that has done it any concerns with warping if it’s not bolted in car? Way easier on a bench...
FFF
Re: eS2 evolution
Postby Afterthought » Fri Sep 07, 2018 10:10 pm
Bad ass .. you’re not leaving anything untouched
1990 Coupe
PreviousNext
Users browsing this forum: Repaair and 14 guests
