jbrentd's 2nd Chance CQ - 3B Swap/Susp Overhaul In Progress
Re: jbrentd's 2nd Chance CQ - working that punchlist...
Postby DE80q » Mon Mar 16, 2020 12:14 pm
I saw in an earlier pic you have the ISV bracket on the air box. Any chance you would sell it? From what I can tell, it's the last part I need to put my CQ engine bay back to completely stock.
Postby jbrentd » Mon Mar 16, 2020 12:51 pm
DE80q wrote:I saw in an earlier pic you have the ISV bracket on the air box. Any chance you would sell it? From what I can tell, it's the last part I need to put my CQ engine bay back to completely stock.
Sure thing. How soon do you need it? Not sure when I might get some time this week to work in the garage.
Postby DE80q » Mon Mar 16, 2020 1:04 pm
No rush. I haven't even put the engine back together yet.
Postby jbrentd » Mon Mar 16, 2020 1:25 pm
DE80q wrote:No rush. I haven't even put the engine back together yet.
I'll send you a PM when I get it removed.
Postby jbrentd » Wed Mar 18, 2020 9:35 am
Does anyone know if the oil filter housings are different between the AAN and 3B 200?
When I mounted the AC compressor, I noticed that it is coming into contact with the turbo oil supply line flange that connects to the 3B's oil filter housing. It looks like the oil supply line on the AAN housing is at a slightly different angle then the 3B 200 housing (see pics below). Just want to confirm.
If true, I would like to see if anyone has one for sale. I could trade my 3B 200 housing.
Postby morris400 » Wed Mar 18, 2020 8:30 pm
Im not doing AC so this is not a concern of mine, however...would making a custom AN line help you? Not ideal as its more $$ but it may solve your problem.
2016 VW GTI DSG Daily Driver
1994 UrS4 - K24 7400 EFI tuned ( EFR build in progress )
2001 B5 S4 Stg 3- (Gone)
morris400
Postby jbrentd » Wed Mar 18, 2020 8:37 pm
morris400 wrote:Im not doing AC so this is not a concern of mine, however...would making a custom AN line help you? Not ideal as its more $$ but it may solve your problem.
I don’t think so. It’s the placement of where the supply comes off the housing that’s the issue. That wouldn’t change if I made my own. However, in retrospect, I should have built my own return line to the oil pan.
Postby PRY4SNO » Thu Mar 19, 2020 12:32 pm
How comfortable are you using tubing benders to fix your return-->pan clearance issue? Swagelock fittings are good for 10k psi, and a couple fittings plus some stainless tubing won't break the bank.
Postby jbrentd » Thu Mar 19, 2020 1:30 pm
PRY4SNO wrote:How comfortable are you using tubing benders to fix your return-->pan clearance issue? Swagelock fittings are good for 10k psi, and a couple fittings plus some stainless tubing won't break the bank.
On the return to the pan, it’s all clear since I sourced the S2 3B oil return pipe.
Postby jbrentd » Thu Mar 19, 2020 10:38 pm
Here are a couple of pics showing the interference with the AC compressor and the 3B oil filter housing. As some have confirmed on the FB page, an AAN oil filter is different and necessary to run AC in the 7A stock location. It’s also right in the S2/RS2 section of the ersatz S2 site. http://www.20v.org/s2/home.html
I also got some parts mounted up.
Postby morris400 » Thu Mar 19, 2020 11:51 pm
Thats beautiful man. Really like the colour.
You have an AAN oil filter housing you can Swap in?
morris400
Postby jbrentd » Fri Mar 20, 2020 7:57 am
morris400 wrote:Thats beautiful man. Really like the colour.
Thanks
I don't, but am on the lookout for one. Let me know if anyone has one.
Postby jbrentd » Sat Mar 28, 2020 5:11 pm
With the exception of swapping out the oil filter housing (got one inbound from Issam), I think I’m just down to running vacuum lines.
Working on making room in the coupe. Im thinking about removing the engine and transmission together. What’s your preferred method? Is it best to drop it with the subframe and all the suspension? Or other? I do plan to refresh all brake parts and bushings while it’s apart.
Postby jbrentd » Mon Mar 30, 2020 9:17 pm
Just to follow up on the AC compressor interfering with the 3B oil filter housing, here are some pics with the AAN oil filter housing and AAN oil supply line installed. No more interference issues. And about 1/2 to 3/4” more space between the filter and compressor, to boot.
And some comparison pics between the AAN (right) and 3B (left).
Postby jbrentd » Sun Apr 05, 2020 10:14 pm
Progress is a little slower than I’d like on the coupe, but I was able to get some of the suspension torn down this afternoon.
I’d like to find a set of brake dust covers, but won’t hold my breath. I’ll probably just knock down the rust and apply the 3-step POR15 products. Thinking about using that stuff on a decent amount of the suspension and steering parts.
Postby PRY4SNO » Mon Apr 06, 2020 2:22 pm
Things are coming along nicely!
Looking forward to your results with POR15. Heard nothing but positive reviews.
Postby jbrentd » Mon Apr 06, 2020 4:03 pm
PRY4SNO wrote:Things are coming along nicely!
Thanks. I have used their engine paint kit twice and liked the results. I'll probably just use their satin black base coat for the control arms, subframes, strut mounts, axle shafts, and tie rods. Most everything else will be new.
Postby morris400 » Tue Apr 07, 2020 1:27 pm
Did you ever manage to figure out the dip stick?
morris400
Postby varia » Tue Apr 07, 2020 1:47 pm
its just pressed in
¯\_(ツ)_/¯
project 2226
varia
Postby jbrentd » Tue Apr 07, 2020 1:54 pm
morris400 wrote:Did you ever manage to figure out the dip stick?
Not yet...it’s going to take more than me just grabbing and pulling on it.
Postby jbrentd » Mon May 18, 2020 7:42 am
Stupid Question Alert!
The coupe is on jack stands, the front brakes and suspension are torn out, and all 4 alxes are still bolted up to the differentials. So, the ground and brakes are not available to me. What's the best way to break the CV joint bolts loose? Put the car in gear and attach the crank lock tool to keep the engine/drivetrain from rotating?
Re: jbrentd's 2nd Chance CQ - 3B Swap/Susp Overhaul In Progr
Postby jretal » Mon May 25, 2020 9:29 pm
Impact gun. Just make sure the allen key is well seated, and they buzz right out.
jretal
Postby jbrentd » Thu May 28, 2020 6:15 pm
Thanks Justin.
Good times working on the rear suspension/braking tear down. Both rear ABS sensors were stuck. Got sticker shock on replacements until I was pointed in the direction of the big truck’s sensor options.
Postby PRY4SNO » Fri May 29, 2020 11:22 pm
Re: sticker shock, are you saying there's a replacement sensor we can repurpose for cheaper, or that the cost of a similar unit on a big truck is vastly higher so it seemed less dear by way of perspective?
Postby jbrentd » Sat May 30, 2020 10:42 am
PRY4SNO wrote:Re: sticker shock, are you saying there's a replacement sensor we can repurpose for cheaper, or that the cost of a similar unit on a big truck is vastly higher so it seemed less dear by way of perspective?
Yeah, that was poorly worded. The truck replacements are around $30 - $40 versus $200 replacements that I found on rock auto.
Meritor/Wabco ABS Sensor Kit R955341. Lots to choose from on eBay. Only thing is the wires are longer and will need to be zip tied.
PreviousNext
Users browsing this forum: Google [Bot] and 14 guests
