The 90
The 90
Postby Afterthought » Thu Jan 10, 2019 2:33 pm
I was looking for a test mule for an engine Im trying to build for my URQ as the urq has body work to be done, needs paint, its fully stripped with no engine /interior/harness/glass so its too far from driving to be a good test car.
I was looking for a 4000 but this CQ turned up with a no start issue. Basically the oil pump failed, engine was bad, car sold as is. It went to a guy who sold the rear seat and some parts to Kirk to the Quattromog. He then sold it to someone else who swapped in a junkyard engine but it wouldn't start, he swapped the distributor and a few things.
So I wanted to be able to drive it and see what issues the chassis and suspension have, make sure the wiring works.
Then proceed with swapping and getting the engine dialed out . Figure out what (or if it) works
the Coupe
Postby Afterthought » Thu Jan 10, 2019 2:36 pm
First step was to re install the distributor, set the timing, reorganize the plugs wires to 1-2-4-5-3. Timing was off 2-3 teeth and the car sounded like a diesel. Set the timing, ran the car for a few heat cycles, changed the oil. And now its running decent. Has a huge exhaust leak (stock exhaust). Only issue I see yet is that i believe it has a bad knock sensor and more importantly I found out that if I rev it to redline the fuel pump fuse pops. Hopefully I can drive it for a bit. Since I need a commuter but soon it’ll come apart
the Coupe
Postby Afterthought » Thu Jan 10, 2019 2:51 pm
Paint is not in great shape but with some help it’s looks decent
Here she is today
the Coupe
Postby Afterthought » Thu Jan 10, 2019 5:31 pm
Here are the engines . I was planning on looking for a newer one due to some changes in the pumps but with how cheap they are it doesn’t really matter what I test fit and what I end up with .
06&07 Engine
GBE 6 speed trans
Oil adapter deal. I still have a way envisioned to run without this but we’ll see..
I used one of them (better one) to test fit the trans and put the other engine in the car engine bay without a transmission so I could make the exhaust and intake .
How’d I get it in there with stock subframe ?
For comparison with my other coupe
the Coupe
Postby Afterthought » Thu Jan 10, 2019 5:41 pm
The exhaust :
There is more trial and error than what’s shows here . 3 different fixture designs just to cut it but after some amount of work I found what works to cut the collector using a band saw.
the Coupe
Postby Afterthought » Thu Jan 10, 2019 5:48 pm
Intake is what I’m currently working on . I’m only just learning how to draw things in CAD so it’s taken a lot of trial and error. I first was going to make a paper copy of the flange then somehow import into the computer in a 1:1 ratio but I could not figure out how to do it. So it just ended up being lots of careful measurement and triangulation .
First I cut just the flange to make sure the bolt holes and ovals were good
This is the design I have right now . I might change it to have about 15 degrees “downturn” on it so that the runners are not pointed up due to the angle of the engine .
One cut left on this which will be the injector holes .
The runners should fit right into it
Re: the Coupe
Postby vt10vt » Thu Jan 10, 2019 6:13 pm
This is awesome and I love everything about it. :hail:
Re: the Coupe
Postby Afterthought » Thu Jan 10, 2019 8:16 pm
It should be good . If not I can apply all this to the tried and true 20V
So next ill need to get a clutch and I ca start looking at the timing cover and the starter .
I can trim the timing cover , and use the holes for alignment . It should need to move “out”.
I thought that I would start with the old school sr10X and see about making a spacer for it but I would figure it how thick I need to go then draw it in cad . Or make it and then write down the numbers .
Re: the Coupe
Postby jbrentd » Thu Jan 10, 2019 8:27 pm
Is this the accidental coupe? Nice start, I’ll be watching its progress.
Re: the Coupe
Postby PRY4SNO » Thu Jan 10, 2019 8:47 pm
Like where this is going, nice to see some more of the fabrication you've been doing.
|| Spare parts for sale
Re: the Coupe
Postby ChrisAudi80 » Fri Jan 11, 2019 5:44 am
Definitely following this one too. Two 07K CQ treads! Ha!
Love the fab work. It's amazing the amount of custom fab work is needed to fit hese engines in an old skool Audi Quattro.
I thought a VR swap was hard, this is another level.
the Coupe
Postby Afterthought » Fri Jan 11, 2019 8:39 am
Well the factory intake is plastic so that’s a no go, but there is one that can be cut apart and used from IE , it’s just expensive, but probably the best /easiest route to go, when you consider the time and resources to make one.
the exhaust, I don’t think that there is any log manifold for any other application that would work (that I know of) . (But who wants a log manifold )
Re: the Coupe
Postby FFF » Fri Jan 11, 2019 1:30 pm
Looking great Pat!!
FFF
Re: the Coupe
Postby Afterthought » Mon Jan 14, 2019 12:29 pm
FFF wrote:Looking great Pat!!
Thanks but remember nothing in my shop is as clean as your project
the Coupe
Postby Afterthought » Mon Jan 14, 2019 12:46 pm
I’ve only had a few minutes to spare this week but I’ve test fit the intake flange last night . I have a couple areas to re do but it’s going to work and the holes and ovals line up perfectly . Injectors are good .
Clearance issue
Here’s a piece of the extrusion , perfect match.
Next thing I need to do is to figure out how to take an extruded aluminum oval tube and bend it . I want to put I think about 15 degrees of bend in it .
I’m considering maybe bringing the entire piece then cut it to equal length pieces . But they all have to be the same so I need to do some thinking on how to bend without crushing it .
This is the “vision”
I’m afraid if the tubes are straight it may put the intake up too high . But I could always try it that way and see how it looks first .
This is the next step is making the plenum end
Re: the Coupe
Postby dougkehl » Mon Jan 14, 2019 1:13 pm
Oh heck yeah. Pat this is sick. looking forward to updates on this. And did you have access to that milling machine to cut that flange yourself? It looks awesome.
dougkehl
the Coupe
Postby Afterthought » Mon Jan 14, 2019 1:15 pm
dougkehl wrote:Oh heck yeah. Pat this is sick. looking forward to updates on this. And did you have access to that milling machine to cut that flange yourself? It looks awesome.
I don’t have a milking machine but I have access to one . The machine was originally a 3 axis that has a 4th added, but I still need some training /practice. Not fully capable of cutting the part myself yet .
At some point way down the road I would like to either wall off a section of my shop or add a small piece where I could have a clean room. A lathe, maybe a mill and a spot to build engines and keep the metal dust out of things .
Re: the Coupe
Postby FFF » Mon Jan 14, 2019 1:52 pm
Hah! That’s only because you have so many cool projects on the go!!
FFF
Re: the Coupe
Postby ChrisAudi80 » Tue Jan 15, 2019 11:12 pm
I don't know if the runners are the same size, but it looks awful close to AEB runners.
You could buy two AEB IMs and cut out what you need.
EDIT: Outside dims: 41x58mm approx.
Re: the Coupe
Postby KTM990 » Wed Jan 16, 2019 1:01 am
Everything is looking AWESOME! I love this so much. Does that oil adapter have a check valve built into it? Have you pulled the pans to confirm they have forged cranks? Also, per Jim Green's path, I also modified a main crank cap to take an AAN thrust bearing to have a full 360deg bearing. I'll put some pics in my post and I think Jim has links to a video of the maching of his cap.
Brendan
'82 UrQ '98 A4 2.0tq
'93 S4 '08 A4 2.0tq
'90 CQ '17 Alltrack
KTM990
the Coupe
Postby Afterthought » Wed Jan 16, 2019 9:06 am
I haven’t even pulled the pan yet on the ‘06 engine! pretty sure it has a forged crank, but I’ll Have to check . I do need the 6 bolt .
The oil adapter that is pictured in the car for fit up is missing some threads but more also there are a couple of ports I don’t see (for example filter bypass) which I think COULD present a problem. don’t know what’s up with it. But the new INA one pictured does have all of the ports I think and it does have a factory check valve in it also
which if I understand it right should keep the head from Draining down .
Re: the Coupe
Postby Afterthought » Wed Jan 16, 2019 7:04 pm
My plan with this intake manifold was to make one that looks similar to my BST one which is in my URQ. The reason for this is looking though all the Audi sport cars they seem to all run dual plenum. Only after I came up with this vision did I realize it’s not going to be very easy to do . I tried the first test today of mocking some things up.
This is what I’m trying to make .
Looks promising but I think the “slot” through the middle for the airflow is supposed be the same the whole way across .
So if I can figure out how to compress the end more and get it to bend around , I’d be close .
Re: the Coupe
Postby dougkehl » Wed Jan 16, 2019 7:49 pm
The slot should be the same the whole way across, otherwise the benefit of the dual plenum is somewhat lost. I'm very very excited to see that manifold come together though. Before I came across my cast plenum I was going to make one. Certainly an intricate piece to make, so hats off to you!
dougkehl
Re: the Coupe
Postby PRY4SNO » Wed Jan 16, 2019 9:07 pm
dougkehl wrote:The slot should be the same the whole way across, otherwise the benefit of the dual plenum is somewhat lost. I'm very very excited to see that manifold come together though. Before I came across my cast plenum I was going to make one. Certainly an intricate piece to make, so hats off to you!
:metoo:
What he said!
Hats off, if nothing else... nobody can fault you for lack of ambition!
Re: the Coupe
Postby alxdgr8 » Wed Jan 16, 2019 9:53 pm
I'm sure you've read Bufkin's pages on the manifolds...you're better off designing a standard manifold for a street car.
Next
Users browsing this forum: No registered users and 15 guests
