Re: Jim Green's 90q 20vt - 636whp 07k
Postby Peters » Tue Oct 24, 2017 9:10 am
the german wrote:videos or it didn't happen ;)
I didn't realize the B6 a4 had an 01E, is it a 4:11 final or did you swap rear ends as well?
I had a back seat ride in the vomit commit at BBQ last year. With 3 of us in the car, it pulled harder in 4th gear at THAT time than any of my cars in 2nd.
That and I haven't seen a fuel gauge go down this quickly since driving some big block V8s
Peters
Postby alxdgr8 » Tue Oct 24, 2017 12:06 pm
Yep, early 3.0 cars, very close to RS2 ratios and flexible shafts like the TDI. Not to mention they're stupid cheap.
Postby alxdgr8 » Tue Oct 24, 2017 12:07 pm
I need to get a ride this year! Come to think of it, I haven't ridden in any of the 07k cars, they all keep breaking before I get a chance :D
Postby audifreakjim » Tue Oct 24, 2017 12:19 pm
Done!
Postby the german » Tue Oct 24, 2017 6:19 pm
woot! and thanks for the info on the b6 01e; I dont need one now but you never know..
Postby 85oceanic » Fri Oct 27, 2017 4:39 pm
Here yet... ?
Postby vt10vt » Tue Oct 31, 2017 2:44 pm
PRY4SNO wrote:Also, the b6a4 01e was found in the manual trans 3.0 cars.
Only the '02 and very early '03 3.0l cars came w/ the 01E, at some point in 03 they went to the 02X. And not all of them are flexible main shafts, although mine was and Jim's were, I've heard of a couple that weren't/
Postby varia » Wed Nov 01, 2017 11:15 am
check your pm ;)
¯\_(ツ)_/¯
project 2226
varia
Postby audifreakjim » Tue Nov 21, 2017 1:11 am
Roll bar is in!
Took it to the track and trashed the tires. This piece delaminated and ended my day Saturday
Then finished off the weekend on the skid pad.
https://youtu.be/MOz3Cl-IdsI
Postby Afterthought » Tue Nov 21, 2017 6:20 pm
So rad . Did you get any videos of it on track
1990 Coupe
Postby audifreakjim » Tue Nov 21, 2017 6:22 pm
I didn't take any in car.
Postby chaloux » Tue Nov 21, 2017 9:23 pm
Eeeexcellent. This bodes well for 07k longitudinal swaps! Dat rev limiter tho!
DEAD :( - 1996 S6 mit TDI
Postby audifreakjim » Wed Nov 22, 2017 12:35 am
chaloux wrote:Eeeexcellent. This bodes well for 07k longitudinal swaps! Dat rev limiter tho!
Yeah, spent a little too much time on the rev limiter. I️ was having too much fun to care.
Postby the german » Wed Nov 22, 2017 12:54 am
Nice work! Were you able to make the rear bar one-piece and removable?
Postby audifreakjim » Wed Nov 22, 2017 1:25 am
Yes, but I have not unbolted it since welding it up. I need to pull it out and probably re-do one of the strut mount points since there was some shrinkage after welding. Once I pull it out, the links are not going to quite line up perfectly.
Postby Afterthought » Wed Nov 22, 2017 8:47 pm
Man I am so jealous of that car . I would like to do a cage like that for my b3 . I see you left most of the carpet In, is that to keep down the road noise or just for looks ?
1990 Coupe
Postby audifreakjim » Thu Nov 23, 2017 11:43 am
Afterthought wrote:Man I am so jealous of that car . I would like to do a cage like that for my b3 . I see you left most of the carpet In, is that to keep down the road noise or just for looks ?
Both, I like to enjoy driving the car and want it to look nice too :)
Postby WRC » Thu Nov 23, 2017 1:11 pm
Roll bar looks proper. Glad you were able to get it done in time for track time.
Tire casualty like that means they are perfect for skidpad shenanigans.
BTW, I'm on the hunt for an FYF.
Wiley Rankin Coffin
Mine
'87 Alpine White 4KQT e85 Xona - Toy
'16 Deep Black Pearl Golf R Manual - Stockish
Hers
'06 Deep Sea Blue 2.0T A4 APR Stage 1
WRC
Postby audifreakjim » Fri Nov 24, 2017 12:43 pm
WRC wrote:Roll bar looks proper. Glad you were able to get it done in time for track time.
It's rare to have a set of tires ready to trash, a camera, and a legal place to shred them:)
The transmission is great, no more 2nd gear on the track. 3rd, 4th and 5th at buttonwillow now, the way it should be
Postby vt10vt » Fri Nov 24, 2017 3:33 pm
Check car-part.com, not sure what the options around you are like but there's a bunch in the $3-500 range around here. If you're not in a rush I'd be happy to grab one and ship it down/over.
The trans for my next project is going to be a wide 1st 5spd box w/wide 1st, FYF main shaft, Allroad 2nd and FYF 3/4/5/6. Should shorten up 2nd for hillclimbs and auto-x and create a nice even spread throughout the gears.
Postby WRC » Sun Nov 26, 2017 1:48 am
vt10vt wrote:Check car-part.com, not sure what the options around you are like but there's a bunch in the $3-500 range around here. If you're not in a rush I'd be happy to grab one and ship it down/over.
Thanks for the offer, not much here in New Mexico. I'll keep my eyes peeled here and the probably hit you up. I've noticed they are much cheaper in the northeast.
Wiley Rankin Coffin
Mine
Hers
WRC
Postby WRC » Sun Nov 26, 2017 1:50 am
audifreakjim wrote:It's rare to have a set of tires ready to trash, a camera, and a legal place to shred them:)
Perfect storm
The FYF sounds perfect except I do like my taller 6th gear that I could swap in.
Wiley Rankin Coffin
Mine
Hers
WRC
Postby audifreakjim » Fri Dec 01, 2017 12:38 pm
Small update, I didn't unbolt the roll bar before the track event because I knew it would not line up right again at the towers after welding. The joints require a perfect alignment and sure enough, everything had shrunk about 2mm after welding.
I had been wanting to add a strut bar to the rear, so I did this before hacking apart the roll bar mounts and re-welding them. I was kind of hoping it would be able to adjust the strut mounts enough to get the roll bar back into place without stressing anything too much. It turns out, it worked perfect, it pulls the mounts together 2mm just by lightly turning the bar in by hand. It's almost scary how easy they are to move..
The nice thing is that I made the strut bar from spare parts I had accumulated over the years from messing with steering control rods.
Postby the german » Fri Dec 01, 2017 1:12 pm
That worked out nicely. Are you going to pull the roll bar our and get it powdercoated?
From what I've seen these chassis are surprisingly floppy, especially so in the coupes. I wonder if anyone has set one up on a test rig and measured torsional rigidity. The roll bar should help a bit in that regard.
Postby jretal » Fri Dec 01, 2017 2:12 pm
Looks great, Jim.
I'll put $1 on the fact that you'll rarely, if ever actually take that roll hoop out of the car :)
BTW, why harness bar at the back vs. in the main hoop right behind seats? Just curious.
jretal
PreviousNext
Users browsing this forum: Google [Bot] and 13 guests
