Random trigger errors at full tilt
Postby 88a5tq » Sun Jun 11, 2017 5:16 pm
I have been seeing this very randomly and rarely in my logs during WOT pulls. The trigger indicator boxes go red above 5500 rpm and stay read until rpms drop more off throttle or I shift and pull again. It's sort of rare and very intermittently.
I have new bellhousing sensors but they are eBay ones on the cheaper end. As far as I know the machinist DID NOT balance the new rods lol. He says "oh it's so minute it doesn't matter and also carbon buildup throws it off eventually anyway" and this is the guy who's crew destroyed my oil check valve and left me no pressure reading after the engine refresh!
Anyone think it's the poopy sensors?
Thanks for reading :)
Janitor at large
$500 butt-hurter
88a5tq
Re: Random trigger errors at full tilt
Postby 88a5tq » Sun Jun 11, 2017 5:48 pm
Don't worry I've already made adjustments to my fueling. This is the hottest the cars been out in so far. Doing some ironing :D
It's the primary trigger.
Janitor at large
$500 butt-hurter
88a5tq
Postby ChrisAudi80 » Mon Jun 12, 2017 1:19 am
If it's any consolation, I have the same thing in my AEB when flooring it.
Postby 88a5tq » Fri Jul 21, 2017 8:08 am
Thanks Chris. We can both hold out for advice now lol. It has mostly stopped unless I'm not logging when it happens. I'm not sure the cause yet..
Janitor at large
$500 butt-hurter
88a5tq
Postby audifreakjim » Wed Jul 26, 2017 11:57 pm
Ign noise can cause this. Make sure your shielding on the trigger wires is good and away from the plug wires. Also run resistor plugs if you are not. Most factory are but the NGK 8 and 9 heat range plugs are not.
Postby 88a5tq » Thu Jul 27, 2017 6:17 am
Oh dang good point! I'll see what my plugs are thanks Jim :)
Janitor at large
$500 butt-hurter
88a5tq
Postby ChrisAudi80 » Tue Aug 01, 2017 6:08 am
88a5tq wrote:Thanks Chris. We can both hold out for advice now lol. It has mostly stopped unless I'm not logging when it happens. I'm not sure the cause yet..
I found some causes of my trigger errors. My DIY PnP adapter.
The VR signal wire and cylinder 1 ignition trigger had a bad solder. Fixed.
However, still have a secondary trigger error at times when dropping below 600rpm or so.
Postby 88a5tq » Tue Aug 01, 2017 7:26 am
Well dang. I'll have to see if I have any similar issues... However, I have an inspection coming up too lol
Janitor at large
$500 butt-hurter
88a5tq
Users browsing this forum: No registered users and 3 guests
