VEMS injector settings Siemens 630cc
Postby ChrisAudi80 » Thu Aug 25, 2016 10:12 am
Hi all,
Been searching a lot about this and cannot find the information. I have two spec sheets for the Siemens Deka 630cc injectors, but cannot make out how to use the information. What do I put here as indicated in the picture? Is it correct already?
Injector settings 630cc.jpg (60.62 KiB) Viewed 13327 times
Re: VEMS injector settings Siemens 630cc
Postby UrSobsessed » Thu Aug 25, 2016 9:02 pm
This is what mine are. They are working well, but might need some tweaks on your car. HTH.
Req_fuel is: 4.6ms.
UrSobsessed
Postby ChrisAudi80 » Fri Aug 26, 2016 9:29 am
UrSobsessed wrote:This is what mine are. They are working well, but might need some tweaks on your car. HTH.
Req_fuel is: 4.6ms.
:ty:
I run req_fuel 5.9 due to E85. How did you get to these numbers? I used the simplified table in VEMS with the numbers sheet from Siemens but the motor ran junk.
I used the attached values for offset, but I guess I needed to multiply by some factor.
Postby UrSobsessed » Sat Aug 27, 2016 12:48 am
I got them from zeet on QW and then tweaked them a bit to my system.
UrSobsessed
Postby ChrisAudi80 » Sat Aug 27, 2016 9:51 am
UrSobsessed wrote:I got them from zeet on QW and then tweaked them a bit to my system.
Don't know who zeet is. How much tweaking did you do?
I have kept the settings that were in the ECU since I got it and that seems to work OK.
Postby UrSobsessed » Sat Aug 27, 2016 11:43 pm
I didn't mess with them too much. Mostly the voltage cells that the car most commonly operates in. Even then, I didn't move the values more than maybe +/- 100us. It's been a long time since I messed with them. The traditional settings work pretty well, but I found I was able to get better results in fuel and idle tuning with the simplified settings.
You can try this method with deadtime calculation also: http://www.vemssupport.com/forum/index.php/topic,2240.msg24790.html#msg24790
UrSobsessed
Postby ChrisAudi80 » Mon Aug 29, 2016 2:11 am
UrSobsessed wrote:I didn't mess with them too much. Mostly the voltage cells that the car most commonly operates in. Even then, I didn't move the values more than maybe +/- 100us. It's been a long time since I messed with them. The traditional settings work pretty well, but I found I was able to get better results in fuel and idle tuning with the simplified settings.
Good information. :ty:
Postby ChrisAudi80 » Mon Nov 14, 2016 8:27 pm
Changed my injector effective rampup to 240us, from 1008us. Big difference. Much better injector response that required a complete retune of the VE table had to go 10-20% up almost everywhere.
Postby quattrobros » Sun Jan 05, 2020 2:53 pm
anyone have a known working traditional settings for these injectors?
I'm about to get some but cant find any reliable information.
quattrobros
Postby ChrisAudi80 » Sat Jan 11, 2020 2:45 am
quattrobros wrote:anyone have a known working traditional settings for these injectors?
Nah, just go simplified. I have the settings for that.
See attached.
Deka 630cc latency data 3bar.jpg (182.28 KiB) Viewed 1534 times
Postby quattrobros » Sat Jan 11, 2020 4:14 am
Yea looks like simplified is the way to go in this case.
Thanks for the settings!
quattrobros
