VEMS voltage
VEMS voltage
Postby 88a5tq » Sat Dec 03, 2016 10:32 am
Is it enough to measure voltage at the battery while running for battery voltage calibration of VEMS? I realized I did it that way long ago. Never measured at the ecu harness :hide:
Anybody done it that way? Should I even probe the ecu while motor is running?
Sitting here in the exhaust shop lobby bored lol. Getting the last half of thr exhaust made of straight pipe. Keeping other half with muffler for inspection :D
Have to pay in cash too hah
Janitor at large
$500 butt-hurter
Re: VEMS voltage
Postby ChrisAudi80 » Sat Dec 17, 2016 10:51 pm
88a5tq wrote:Is it enough to measure voltage at the battery while running for battery voltage calibration of VEMS? I realized I did it that way long ago. Never measured at the ecu harness :hide:
What you can do is measure batt voltage while running on the battery terminals. Then shut off, disconnect the ECU and measure resistance between positive battery pole and the +12v pin in the ECU connector. Same for batt GND. If 0 ohm, you can use the voltage you measure at the battery and match it up when calibrating. That's the way I did it.
Re: VEMS voltage
Postby 88a5tq » Sun Dec 18, 2016 12:40 am
Oh nice approach thanks for chiming in Chris! I'll try that.
Janitor at large
$500 butt-hurter
Re: VEMS voltage
Postby ChrisAudi80 » Tue Dec 20, 2016 5:30 am
88a5tq wrote:Oh nice approach thanks for chiming in Chris! I'll try that.
No worries, but keep in mind when you calibrate the voltage in VEMS that you just have the key in ON position not running, otherwise the voltage is not stable.
Re: VEMS voltage
Postby 88a5tq » Sun Aug 13, 2017 10:46 am
:ty:
Janitor at large
$500 butt-hurter
