AAN manifolds flange 07k same????
Postby RPNJ82 » Sat Sep 08, 2018 9:05 pm
Are the manifold flanges the same on both engines?????
RPNJ82
Re: AAN manifolds flange 07k same????
Postby PRY4SNO » Sat Sep 08, 2018 9:55 pm
Intake side of either block:
07K
AAN
|| Spare parts for sale
Postby vt10vt » Sun Sep 30, 2018 4:49 pm
The flange won't work due to the injector recesses in the AAN/3B/7A head you can clearly see above. However, the port spacing is the same, as is the 1.8T, which happens to share the same injector mounting setup, port shape, and bolt pattern (albiet with the 07K only having about half as many threaded holes from the factory).
Postby vt10vt » Sun Sep 30, 2018 4:51 pm
Also, based on all your posts it seems like you're trying to do some sort of longitudinal 07K on the cheap, and just as an FYI unless you can fab pretty much everything (and don't count your own time), there isn't really a cheap way to do it.
Postby elaw » Tue Oct 02, 2018 2:09 pm
Also the 07K intake ports are substantially wider... I can't remember if they're also taller. On the exhaust side, the "old school" 20V engines had the ports unevenly spaced, whereas on the 07K the spacings are even. So an old exhaust manifold won't work.
Eric Law
elaw
Postby RPNJ82 » Fri Oct 05, 2018 10:16 pm
i am ....trying to keep the cost down. Its not fun to spend it all for basic performance results
RPNJ82
Return to 07k Swaps
cron
