How big can you go with a 07K?
Postby paracaidista2.7t » Fri Mar 08, 2013 7:29 pm
Displacement wise? I know there aren't any stroker cranks, but how big can you bore it, realistically, for a turbo motor? Also, has anyone tried this swap in a B5 or C5? I am intrigued by the VR6, but the 5cyl. just freaking sounds cool.
paracaidista2.7t
Re: How big can you go with a 07K?
Postby alxdgr8 » Fri Mar 08, 2013 7:32 pm
I don't think there's any room to bore, maybe 0.5-1mm from when I was looking at it at Iroz. Maybe offset grind the crank but not sure about block clearances.
Postby glibobbo21 » Fri Mar 08, 2013 8:33 pm
def .5. 1mm is getting sketchy.
Postby Hank » Fri Mar 08, 2013 9:45 pm
These are still short deck 220mm blocks, so 2.5L is probably as big as it gets. As others have said, 83mm is as big as I would want to go.
Postby paracaidista2.7t » Fri Mar 08, 2013 10:18 pm
So, about 2540cc. I doubt that the extra 60cc or so would be worth the compromise, IMHO.
paracaidista2.7t
Postby All_Euro » Sat Mar 09, 2013 12:02 am
Eurospec says this about their 5 Cylinder Billet Crankshafts, "Fits all inline 5 Cyl Audi and VW Petrol engines."
http://www.eurospecsport.com/products/c ... shafts.htm
True in this case?
Work - Houzz / linkedin
Play - Haldex Swap
All_Euro
Postby Hank » Sat Mar 09, 2013 12:40 am
No, the old five cranks would not work.
Return to 07k Swaps
