VEMS Bluetooth adapters now in stock
EFI-X Product development and new product releases
Postby Marc » Fri Mar 29, 2013 10:10 am
VEMS bluetooth serial adapters are now in stock so you can rock your VEMS via wireless communication to your laptop or Android enabled tablet / smartphone. Nothing says kick-ass-awesome like wireless tuning and fully configurable high res motorsports gauge pack :)
Proprietor, EFI Express
Re: VEMS Bluetooth adapters now in stock
Postby Hank » Fri Mar 29, 2013 11:10 am
Dude, ping the developers for dual outputs!!!!!! I must have this!
Postby Marc » Fri Mar 29, 2013 11:30 am
Hank wrote:Dude, ping the developers for dual outputs!!!!!! I must have this!
looks like there is quite a lot to do to make that work. what it would do is repurpose the serial interface that is currently used for the GPS feature in vems, but its currently RX only.
What you *can* do, is take your current serial setup you are using for your AIM, remove the TX pin, and 't' the ground and RX, wired to this bluetooth module. that will allow two AIM stream devices to talk at the same time without messing up the stream. For instance for your MXL and an android display simultaneous.
Postby Hank » Fri Mar 29, 2013 12:52 pm
Now that would work. It would just be a matter of alternating Bluetooth duty between a laptop and the android device to tune right?
Postby Marc » Fri Mar 29, 2013 1:00 pm
Hank wrote:Now that would work. It would just be a matter of alternating Bluetooth duty between a laptop and the android device to tune right?
yes.
There is a possibility you MIGHT be able to get your laptop without switching by giving TX to the bluetooth adapter, and using that to comm with your laptop. you'd have to shut down your android device first, since it only works paired to one device at a time.
Postby loxxrider » Fri Mar 29, 2013 2:53 pm
This is teh awesome! I can't wait to utilize this :)
Postby amd is the best » Fri Mar 29, 2013 8:45 pm
Tempting! Maybe I'll scoop one up at Carlisle from you.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best
Postby UrSobsessed » Sun Jun 23, 2013 7:34 pm
I'm interested in this! Will something like http://www.bestbuy.com/site/Rocketfish%26%23153%3B---Micro-Bluetooth-USB-Adapter/8820886.p?id=1207351932175&skuId=8820886 be enough to link with my PC?
Also, how is the connectivity with this? Anyone else running it?
UrSobsessed
Postby EDIGREG » Mon Jun 24, 2013 7:50 am
I've been running this and it works very well. I hard wired it so the connection is always there - it's nice to be wireless.
That adapter should work fine if your laptop does not have Bluetooth.
Postby UrSobsessed » Mon Jun 24, 2013 2:41 pm
When you say hard wired, are you referring to the usb port you put in the center console, or just the power controls?
UrSobsessed
Postby EDIGREG » Mon Jun 24, 2013 3:03 pm
power to the bluetooth module.
You can power it via 5v/1A USB port (from your laptop, for example), or it has a small power supply that you can wire to 12v for a permanent install.
Postby UrSobsessed » Mon Jun 24, 2013 6:13 pm
Ok. Thanks.
UrSobsessed
Postby mushasho » Mon Aug 19, 2013 1:36 pm
The possibilities...
UglyUr 2.5L 95mm Stroker
Postby chaloux » Mon Aug 19, 2013 1:43 pm
Fer srs
Postby pilihp2 » Mon Aug 19, 2013 2:40 pm
And now I need to own a tablet.
Postby chaloux » Mon Aug 19, 2013 2:49 pm
I have one bit I think wife would not be happy if I threw it in the 4k permanently
Postby loxxrider » Mon Aug 19, 2013 5:47 pm
chaloux wrote:I have one bit I think wife would not be happy if I threw it in the 4k permanently
You could mount some kind of case with a quick release in the dash, and then you wouldn't have to have it permanently mounted... like how some head unit face plates pop off.
Postby Mcstiff » Mon Aug 19, 2013 6:01 pm
Yeah, easy enough. It'd be cool to have it rise out of the dash :hail:
Postby Fundahl » Wed May 28, 2014 11:14 pm
Tested the software demo on Galaxy S4 and works great! How much for the kit in USA?
95 S6, 05 FZ1, 91 300ZX, 05 LJ Rubi
Fundahl
Postby Marc » Thu May 29, 2014 7:54 am
Fundahl wrote:Tested the software demo on Galaxy S4 and works great! How much for the kit in USA?
$79
http://www.efiexpress.com/catalog/product_info.php?products_id=113
Return to Product Development
