Change/bug log
Non-automotive discussion
Change/bug log
Postby EDIGREG » Thu Feb 28, 2013 4:11 pm
This topic will serve as a change/bug log for admins.
If you find a bug/error, please contact me directly via PM.
If you have a forum suggestion/request, please post it in the Forum Suggestions.
2/26/13
-Software installed/configured
-Domains registered, DNS configured
-Base forums created
2/27/13
-Forum moved to new server
-Database migrated to mysql
-Set up SMTP server
2/28/13
-Extended session timeout to 7 days
-Changed TapATalk domain
-Installed custom smilies
-Created Off-Topic and Gathering forums
-Discovered login bug when using irozmotorsport url
-phpBB debugging turned off
3/3/13
-Increased posts per page to 25
3/4/13
-found SQL error on certain DB inserts. issue appears to be caused by incorrect table definitions that came in as a result of mssql db import. table rebuild appears to fix this issue, will schedule for the evening. (edit - done: awaiting any further sql error reports)
-Resolved login issue with forum.irozmotorsport.com
-Added registration security question
3/6/13
-Created SEM ECU config archive
-added the ability to attach .vemscfg and .vemslog files
-fixed avatar permissions
3/7/13
-automatically go to the first unread post when clicking on topic link
-set external links to open in new tab/window
3/8/13
-modified internal/external post link colors
-removed day & time from joined date
-added online status indicator to viewtopic, memberlist, viewmessage pages
To-Do
-Forum index announcement
-Vendor feedback system?
-Fabrication forum?
-Multi-quote
-Gather list of permitted SEM ECU config/log file extensions
Return to Off-Topic
cron
