Rear Coilovers for 1991 Audi 200
Do It Yourself!
Postby 20VAvant » Thu Jun 20, 2013 10:55 pm
I want this to used with Chris's write up for the T44 coilover setup. Addresses a few of the issues/trouble I had.
I list the places I personally purchased items, google and find lower prices/alternatives!
1991 Audi 200TQ Uses a 12mm Upper Nut on the shock | Spring rates are personal choice
Parts
    Description | Part Number | Supplier | Quantity | Cost
  • Snap Ring 2" | 1400-200 | Akron Bearing | QTY: 2 | $6.30
  • Spring Coupler | EIB-SPACER250 | Summit Racing | QTY: 2 | $41.90
  • Eibach Spring 6" x 2.5" - 550LB | EIB-06002500550 | Summit Racing | QTY: 2 | $131.90
  • Bilstein Shock Rear | 24-020664 | PartsGeek | QTY: 2 | $257.05
  • Coilover Nut for 2.5"ID Spring | A1-12460 | A1 Racing | QTY: 2 | $25.74
  • Coilover Top Hat for 2.5"ID Spring | BRP603 | Bicknell Racing | QTY: 2 | $30.80
  • 5" Coil Over Sleeve Rear 1.980"ID | A1-12451 | A1 Racing | QTY: 2 | $31.06
  • Take Up Spring 2.5ID x4" 25LB | HYPCS100 | A1 Racing | QTY: 2 | $60.00
Total Cost for Part for Rear Coilovers: $584.75
I will update with a photo step - by - step for assembly at a later date.
Step #1: Replace factory Bilstein circlip with Akron Bearing Snap Ring Part#5100-200.
Step #2: Assemble coilover parts
I assembled mine as sleeve, perch, helper spring, coupler, spring, top hot, then reused the setup minus top spring perch off stock.
Here it is on the car
Order websites:
http://www.A1Racing.com
http://www.SummitRacing.com
http://www.akronbearing.com
http://www.bicknellracingproducts.com
http://www.partsgeek.com
-2014 Lexus IS350
-2015 Yamaha FZ-07
20VAvant
Re: Rear Coilovers for 1991 Audi 200
Postby loxxrider » Fri Jun 21, 2013 6:50 pm
Good work! Looking forward to more. You're a great addition to this community! :)
Postby 2.5TYPE44 » Sun Aug 04, 2013 9:15 pm
I want to see this sitting on the ground with wheels and tires. Not bad for the price. I want to do that.
2.5TYPE44
Postby amd is the best » Sun Aug 04, 2013 9:29 pm
I have found that an untouched Bilstein sport strut isn't a great match to the 550lb spring. They bounce a bit at least in my car.
Awesome writeup, looks great!
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best
Postby 20VAvant » Mon Aug 05, 2013 7:28 pm
2.5TYPE44 wrote:I want to see this sitting on the ground with wheels and tires. Not bad for the price. I want to do that.
This is as low as I can go without bottoming out and without adding more camber. With two passengers in the rear it rubs on small bumps.
amd is the best wrote:I have found that an untouched Bilstein sport strut isn't a great match to the 550lb spring. They bounce a bit at least in my car.
I feel this way also, it kills the previous set on there which compressed and never rebounded after they were taken off, however. I still feel like it is super bouncy compared to what I was expecting.
-2014 Lexus IS350
-2015 Yamaha FZ-07
20VAvant
Postby loxxrider » Mon Aug 05, 2013 9:32 pm
That is definitely the nature of the Bilstein sports. The truth is, they are really not valved for more than about 350 lb/in in stock form. Of course, they can be re-valved to your liking. Its either that, Koni yellows, or some custom Konis.
Postby 20VAvant » Tue Aug 06, 2013 11:08 am
loxxrider wrote:That is definitely the nature of the Bilstein sports. The truth is, they are really not valved for more than about 350 lb/in in stock form. Of course, they can be re-valved to your liking. Its either that, Koni yellows, or some custom Konis.
How do you go about getting them revalved? Just send them in? What is ideal for revalving for the Bilstein sports on this setup?
-2014 Lexus IS350
-2015 Yamaha FZ-07
20VAvant
Postby loxxrider » Tue Aug 06, 2013 10:10 pm
Yep, just send them in to Bilstein. Make sure to insure them though... they lost mine somehow and tried to blame it on the mail (yeah right, I know they received the package because it had delivery confirmation)... I fought with them for months and had to make threats that I'd spend every waking minute of my time tarnishing their name all over the internet if they didn't make it right. They finally gave in and sent me some brand new ones. The only problem is that they didn't shorten or re-valve them appropriately and I had to fight with them for another month or two before they gave in again and made it right.
ANYWAY, I'm not honestly sure what damping coefficients they use when they re-valve, but they just ask you the weight of the vehicle and the spring rate and re-valve it accordingly. That is pretty much all of the info they need to do it appropriately (as far as the mathematics are concerned anyway).
Postby k2exoman » Tue Aug 06, 2013 11:08 pm
Are those stock bushings you redid?
Or are the blue sections an aftermarket solution?
k2exoman
Postby 20VAvant » Wed Aug 07, 2013 7:56 am
k2exoman wrote:Are those stock bushings you redid?
The blue bushings came with the upper tie rod bar. The ones for the sub-frame are UrS4 aftermarket Rear sub-frame from Apikol with a new inner sleeve I had made at work to fit the 200.
-2014 Lexus IS350
-2015 Yamaha FZ-07
20VAvant
Postby 2.5TYPE44 » Thu Aug 20, 2015 4:50 pm
was that the shortest shock you could find? It seems that this shock would be close to constantly riding on the bumpstop. I am looking for a solution for the rear of my car. I put the shock in and raised the suspension up the the exact ride height I wanted to make the car level with the front and my rear shock is basically bottomed out. I need a shorter shock body. any suggestions... It seams like the part number you gave is only 1/2" shorter than factory
2.5TYPE44
Postby Henrybor » Mon Sep 25, 2017 1:17 pm
mine is a S1 Ti with rear air. I didnt specify wasnt asked and the wings fit fine.
Henrybor
Return to DIY Write-ups
