FS Holset HX35/40, Manifold, Cummins oil Lines
Postby morris400 » Wed Apr 18, 2018 3:54 pm
Hey guys,
I have a Holset HX35 turbo with a HX40 compressor wheel and housing. also has the 12cm Non WG exhaust housing with T3 flange. I picked this up from Goldfarb, it was rebuilt before I got it and is in great shape. I has the housings sand blasted and the comp housing powder coated. $400 Shipped
the injectors are 630cc from Chris. still new in the box and never used. comes with the adapters for the stock connectors. (SOLD)
the manifold is a Ebay tube manifold, I have a T3 flange that would need to be welded on to mount the turbo. this is also new and never used. comes with the gaskets and the studs as well. $ 150 with or without the T3 Flange.
the ecu is a stock urs4 ecu that I was going to send away to be tuned. (SOLD)
I also have a set of 2 Cummins drain lines for the turbo, these are OEM from Cummins. the flanges fit both the turbo and the block. they will require a bit of fab work, but the flange and the ID of the line is what is required by Cummins. $65 Shipped
and I have a Cummins Vband flange and clamp to make a downpipe. the vband on Holset turbos is not a standard Vband so again OEM Cummins was the best way to go. $100 Shipped
also have a 4an braided SS line and AN connectors to make the Feed line, with 034 adapter on oil filter housing. $80 Shipped
Im open to offers.
PICS here http://www.motorgeek.com/viewtopic.php? ... ead#unread
2016 VW Jetta 1.4T Daily Driver Stock.
1994 UrS4 - K24 7400 Vems moving to EFI Experss tune.
2001 B5 S4 Stg 3- ( gone! Dropped valve cyl 4)
morris400
Re: FS Holset HX35/40, Manifold, Cummins oil Lines
Postby morris400 » Tue May 08, 2018 9:32 am
Bump, looking to sell this stuff quick. open to offers. ECU and Injectors sold!
morris400
Postby morris400 » Tue May 22, 2018 5:21 pm
Turbo sold. And all the lines sold. Only the manifold left looking to get rid of cheap...make me an offer willing to trade as well for a cast rs2 REP ebay manifold.
morris400
Return to Swap Meet
Users browsing this forum: No registered users and 5 guests
cron
