FRP Land Speed record-holding 1993 UrS4, 2015 season prep
Check out the FRP shop projects
Postby EDIGREG » Wed Jun 03, 2015 10:10 pm
Hi Audi Fans
Getting the old girl ready for one last shot at Speed Week in August. Have a new BW Turbo from my sponsors BW and Area Diesel Service in Carlinville Il. Turbo is an S400SX3 with an 82mm compressor and an 87mm turbine in an FRP ported 1.25 A/R housing.
I have a new set of my FRP Race Gas / E 85 pistons in it with a special ring package that uses a PVD coated tool steel top ring and my usual Gapless seconds from Total Seal and a standard NPR oil ring. The top ring has an extra deep .176 radial dimension and is .0415 thick as apposed to the 1mm top ring I had been using.
I have to run a greatly reduced top ring land diameter to keep the crown of the piston off of the cylinder wall at mile 4 - even with the ceramic coating on the crown. There is just too much heat soak in the extreme B Ville environment. So the deep radial dimension of the new top ring is to make up for the lost top land support.
I have also changed the cam timing for an even wider lobe separation angle with the exhaust advanced 2 degrees to a 115 centerline. This spools the turbo sooner and harder which will help with the thin air at 4000 ft. elevation.
Also new this year was our trip to Kansas City's "heart breaker" Mustang chassis dyno at KC Engines. We had always been on a DynoJet before so I was a very curious to see what numbers the eddy current dyno would give us..
The session went great with Brendan Rudack doing his usual masterful job tuning the Stage 2 C.
We monitored back pressure in the collector and vacuum / pressure in the crank case This was very rewarding as back pressure at the turbine entrance never got close to 1 to 1 and the ring package worked so well that 6 inches of vacuum was maintained at 10K rpm and 26 pounds boost on the waste gate spring.
Once we turned on the boost control and pushed boost to 33 pounds the crank case gage would just barley creep towards zero by 10,300 RPM. Since I am only running 2 scavenge stages on the dry sump and only start with 6 inches of vacuum that is some kind of ring seal! Very Happy.
Anyway she made 955 WHP and 548WTQ on the Mustang dyno. The dyno operator said the only other vehicle that had made that big a number was a twin turbo Chevy LS motor in another guys toy - it made right at 1100 wheel with 6.2 liters of displacement. The Audi is just 2.3 - Ha!
Now I will be adding more ballast to the car and resetting the corner weights. I think it has a chance for a record near 260 mph. Just don't want it try to imitate an aircraft of some kind. Wish me luck!
Cheers.
Jeff Gerner
Re: FRP Land Speed record-holding 1993 UrS4, 2015 season pre
Postby chaloux » Wed Jun 03, 2015 10:17 pm
Holy oh my word. Wow
DEAD :( - 1996 S6 mit TDI
Postby Mcstiff » Wed Jun 03, 2015 11:22 pm
I'm tempted to try and come out to witness the run. My Aug could be busy though.
Postby loxxrider » Thu Jun 04, 2015 5:16 am
That is spectacular! Best of luck this year Jeff. I can't wait to see more!
Postby ringbearer » Thu Jun 04, 2015 9:53 am
Best of luck!
Postby 2.5TYPE44 » Thu Jun 04, 2015 9:57 am
Keep pushing the envelope! Closely watching! Good Luck! I'm thinking 261... I've landed ina jet today half that speed. Next might be wings... :D
2.5TYPE44
Postby dalspaugh » Thu Jun 04, 2015 10:37 am
Best of Luck! Will also be watching closely!
'95 Audi 90Q
'00 Buell X1 Racing Stripe
dalspaugh
Postby PRY4SNO » Thu Jun 04, 2015 10:24 pm
As always, love the technical details of your approach.
This thing absolutely screams on the dyno!!
|| 2010 Golf Sportwagen TDI /// Wifey mobile
|| Spare parts for sale
Postby FRP » Fri Jun 05, 2015 2:50 pm
Thanks to all my HP junkie brothers for the feed back / encouragement. I'll keep you posted on the rest of the car prep
Jeff G..
FRP
Postby 90quattrocoupe » Fri Jun 05, 2015 10:24 pm
Best of luck.
90quattrocoupe
Postby UrSobsessed » Mon Jun 08, 2015 1:38 pm
:thumbsup: :thumbsup: :thumbsup: WOOOOHOOOO!!!! Go Jeff!!!
UrSobsessed
Postby PRA4WX » Tue Jun 09, 2015 7:55 pm
2.5TYPE44 wrote:Keep pushing the envelope! Closely watching! Good Luck! I'm thinking 261... I've landed ina jet today half that speed. Next might be wings... :D
In my current airplane, our rotation speeds are in the 150moh range and that's a max takeoff weight of a little better than 85,000 lbs. 260 plus in a practically stock bodied 3500lb (???) urs4 is a takeoff waiting to happen! As we say in aviation-take offs are optional, landings are mandatory!
Good luck, Jeff! I always watch your project with rapt excitement!
PRA4WX
Postby amd is the best » Wed Jun 10, 2015 1:11 pm
Jeff, would you be running on the 8th and 9th of August? I will try like hell to be there with Matt.
Nick
'15 S3
'91 200 20v
'91 200 20v Avant
amd is the best
Postby Marc » Wed Jun 10, 2015 5:30 pm
indeed. I'd fly out for this to join the fan club.
Proprietor, EFI Express
Postby Marc » Wed Jun 10, 2015 5:49 pm
Just spoke with Jeff, speed week is the 8th-14th of august. hotel rooms go for balistic money, the smart plan is to rent an RV and camp out.
Postby amd is the best » Wed Jun 10, 2015 5:58 pm
I'm down for renting if we get enough goons together
Nick
'15 S3
'91 200 20v
'91 200 20v Avant
amd is the best
Postby loxxrider » Wed Jun 10, 2015 8:58 pm
I have to work, otherwise I'd be so down!
Postby chaloux » Wed Jun 10, 2015 9:05 pm
I wish... That would be awesome. Also lol... 7000-10800rpm of insane power. Nice powerband :)
Postby Einbilden » Wed Jun 10, 2015 10:24 pm
Nice car,awesome work and cool Articles.By the looks of things you will be setting that Record.
But good luck to you anyways.
Mike
Einbilden
Postby Marc » Tue Jun 23, 2015 12:53 pm
Hey guys, just a quick heads up that Jeff could really use our help. Some unexpected replacement parts have been necessary to get the car ready for the event. As you can imagine this is already an increadibly expensive endeavor for him. I've setup a gofundme page at his request. who's in?
http://gofundme.com/xp38zq8
Postby loxxrider » Tue Jun 23, 2015 3:03 pm
Is it tax deductible? Lol
Postby loxxrider » Tue Jun 23, 2015 3:17 pm
That's a no upon closer inspection.
Postby loxxrider » Tue Jun 23, 2015 6:04 pm
Maybe the better question... how much to get my name on the car? :P
Postby FRP » Wed Jun 24, 2015 8:23 pm
I big fat thank you to all of you so generously helping out!
FRP
Postby alxdgr8 » Wed Jun 24, 2015 10:26 pm
FRP wrote:I big fat thank you to all of you so generously helping out!
Wish I could've donated more! The time and effort that you've put into sharing your knowledge on engine building here is worth every penny and then some.
1983 Aud UrQ (20vt swap in progress)
1995 Audi 90QS (Previously 32v V8, now AEB 1.8T)
2010 VW Touareg TDI (DD, tow rig)
2001 Ducati ST4
Return to Shop Projects
