Re: I took the BLUE Pill. Engine bay painted
Do NOT, I repeat, DO NOT ride in this car unless you are prepared to spend 5-10k.
Freak.
I had finally driven my car with 450+whp and a wavetrac rear diff. Was all smiles after Hank showed me how to drive it properly. My car is wicked fast. I literally stepped out of my car and then went for a ride in Sean's.
580whp
525wtq
25psi.......It's a rocket ship.
Freak.
580whp
525wtq
I have it as ~$7k for parts (inc built bottom end) in my build workbookAudilard wrote:Do NOT, I repeat, DO NOT ride in this car unless you are prepared to spend 5-10k.
Sounds like the perfect engine for a sub-3k lb RWD chassis like my 968Audilard wrote:Do NOT, I repeat, DO NOT ride in this car unless you are prepared to spend 5-10k.
Freak.
580whp
525wtq
Now to start collecting parts.
Ok, ready for my pickup tube so I can finish mine now.
Any ideas on pump gas limits for the poor folks like me where the closest E85 pump is about an hour away?
I'd look at APR stage 3 pump gas tunes as a good indication of what could be done on pump with 9:1 lower compression pistons. Yes, no GDI, but you would have slightly lower compression to maybe equal it out. I think they are getting close to 500whp on pump with a gtx3576r which is just slightly smaller than the turbo on Seans car
^^^ pump
100 octane ^^
Sean's car could really rev to 8000 if it wanted to, but the turbo is going to be done at around 7500 judging by the data out there, and the results we have got so far. If a guy wants to see 9000rpm the 07k is capable with just springs and cams, 67mm turbos will probably be needed. Bonus is that they will be 850whp setups at that point.
Want.Hank wrote: If a guy wants to see 9000rpm the 07k is capable with just springs and cams, 67mm turbos will probably be needed. Bonus is that they will be 850whp setups at that point.
Are cams available yet?
well this just became one of my new favorite projects.
Hmm, so dad's car will be around 8k then for a 64mm. Crazy. Honestly if we break 500whp on pump 94 at around 26psi I'll be happy. We did 465 on a stroker at the same boost so I think it'll be possible. With a single 044 and ID1000s? We'll see...
Know what would be cool? One of these in an E46.
As far as i know still no cams to the public unless they are test cams. I have a bucket that I'm collecting my drool in, from my car and Seans. Hoping this will supplement my lack of e85 availability for fuel consumption.
If i see 400whp on 93 with 18-22 psi on the super 40 turbo I'll be tickled. Anything above is just a bonus.
I'm planning to only go to 25ish psi on the 4kq chassis until I get more tire under it.
Dont you dare take this engine out till BBQ. See you there with mine(doubtful itll be an URQ yet)?
Can't certain companies do cheap custom cams, aka Eagle?
There is whole bunch of giggling and tire smoke I assure you.
I don't need assure....i need a sure video....of tire smoking and Hank giggling in the back ground spouting spool targets with the 07K's new world head design.....that's what I NEED!audifreakjim wrote:There is whole bunch of giggling and tire smoke I assure you.
There are a couple vids but you can't embed FaceBook (getting hard to directly link these days).
https://www.facebook.com/photo.php?v=10200974701208285
https://www.facebook.com/photo.php?v=10200974671647546
You can get a regrind though Delta in tacoma. There is a company down in california that can regrind any camshaft to ANY spec.....but it's pricey. They told me $750 for a 5-cylinder camshaft but it would be whatever I specified them to make.PRY4SNO wrote:Can't certain companies do cheap custom cams, aka Eagle?
Or you can contact a company back east (name slips me at the moment) that will build you a camshaft out of billet
I'm sending off a NOS urq camshaft to be reground into a hydraulic spec camshaft.
Gaaaaahhhh Facebook videos!
I love the progress. Those graphs comparing the K26/VR6 034 Setup to the 07K HTA combo is awesome. This is the reason I like to mess around with cars. That is the fact that people like you guys will put these motor and turbo combonations together and test, and compare and test some more to see whats best. The results are amazing, just sucks now because less people will be building 1.8Ts, 3Bs and even VRs, haha.
Great work.
Great work.
1988 Audi 90Q 1.8T swap
2003 VW Jetta TDI
1978 GMC High Sierra
2015 Touareg Lux
http://dubsinthebuff.com
2003 VW Jetta TDI
2015 Touareg Lux
Congrats on the European Car COVER! I need to get my hands on one...
https://scontent-a-lax.xx.fbcdn.net/hph ... 0882_n.jpg
Kudos for the car mag feature!
Looks impressive from every angle, I really dig those wheels
So awesome, congrats, all the hard work really paid off!
The car is mega. Accolades we'll deserved. Congrats, guys!
