amd is the best
Post by amd is the best »
Everything is back together now other than the two axles. I should have a new CV tomorrow to get the passenger side axle installed.
Today I wired up the reverse lights and used the 016's transmission harness. There was a sensor int the rear of it (near the center diff) that I assumed was maybe a neutral sensing switch for cruise control, but it never had continuity (gear, reverse or neutral). Any ideas? The 01E does not have this switch/sensor and since it was always open, I left the two wires open. Was it maybe on older 016's for center diff locking?
I didn't get to the launch control yet today cause I couldn't find a 5 pole relay to "invert" the clutch switch. I'll do some more searching tomorrow.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best
Blinker relay in:
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
sweet, looks like it wasn't very hard
amd is the best
Courtesy/Komfort Blinker retrofit Audi 200 (and other old au
Quick write-up of the courtesy blinker/komfort blinker/"tap to pass" retrofit.
Part needed:
000-998-229 (000-998-229A can be used too) - comes as a kit with a relay, harness, splice connectors and a zip tie.
Next, remove all items necessary to access your hazard (four ways/emergency blinkers) switch. In the 200's case I had to remove the steering wheel, upper steering column cover and the knee panel thing. Next, unplug the harness from the hazard switch and splice in the wires from the komfort harness. By splice I mean add the new wires in parallel to the existing ones. Here's the connections I made for my 1991 200 (I assume other ancient Audi's and VW's use the same colors however no guarantee):
Komfort harness --> vehicle harness
grn --> blk/grn
blk/wht --> rd/bl
wht --> blk/wht
wht/gr --> blk/wht/grn
brn --> chassis ground
I popped out each of the terminals I was splicing into and soldered my wires to them rather than cutting up my factory harness. I can always unsolder if necessary. You slide the brown portion of the connector and you can remove each pin. I tinned each of the terminals and each of the bare wires, attached them and reinstalled. Then slide the brown portion of the connector back to it's original position to lock the wires back into place.
Completed "splices":
Just ground the brown wire from the Komfort harness and you're all set! Put everything back how it was!
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best
EDIGREG wrote:sweet, looks like it wasn't very hard
Looks even easier for your car: http://www.audic4.de/komfortblinker.html (us Chrome for translate).
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Wow nice, good find. Thx
Post by vt10vt »
Less of the amenities, more of the go please :P
Seriously though, that is a cool little mod, definitely adds to the highway-cruiser element of the 200
amd is the best
Today I dropped off the D2 S8 calipers I purchased for my B5 to be powdercoated and I think I have decided that I'll install them on the 200 instead. It deserves the parts more.
Now, what rotors are normally used. I think I recall ur20v saying that I can use B6 S4 rotors. Does that sound correct?
EDIGREG wrote:Wow nice, good find. Thx
:thumbsup:
vt10vt wrote:Less of the amenities, more of the go please :P
Lol, I agree! The car is complete other than the drivers side axle then the car will be out ripping again!
And it's the little additions that really make me happy...like an extra gear will be nice. lol
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
323x30 d2 a8/s8 rotors... If building a custom bracket anyhow, I'd opt for d2 345mm disc if your 17's could swallow it...
Sent using Tapatalk for Android
Shortened axle in route! Should have it Friday afternoon
amd is the best
Hank wrote:Shortened axle in route! Should have it Friday afternoon
:hail: :hail: :hail: :hail: :hail: :hail: :hail:
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Damn you guys and your fast national shipping... !!! gah
amd is the best
You're looking at the first running and driving 01E T44 in the states (as far as I know)!!! Probably one of a handful ever.
Quick clip coming soon!
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Woot woot. Give me some feedback on the axle length
2.5TYPE44
Post by 2.5TYPE44 »
That's great! I'm happy for you I'm sure all of your trial and error/ research will save us a lot of time and money.
Win!
TPIWWV!
amd is the best
Hanks masterpiece:
All assembled:
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Teh awesome! Mine will follow soon :)
32vquattro
Post by 32vquattro »
amd is the best wrote:Today I dropped off the D2 S8 calipers I purchased for my B5 to be powdercoated and I think I have decided that I'll install them on the 200 instead. It deserves the parts more.
:thumbsup:
Nick, contact Doug at Apikol. He has brackets on the shelf to fit the d2 s8 calipers and 345x30 rotors to g60 strut housings. Just finished mine up here-- > http://motorgeek.com/viewtopic.php?f=6& ... ead#unread
That axle is far more true than when it came in. Looked like it had been launched a few times :) It was out about 1/2" over the span of 18 inches. Pretty normal for hard launching on stock axles. I can straiten them out pretty well by setting them up in a press fixture and rotating them once welded to get them within 1/8" or so. Probably feels a little smoother at speed now.
Glad it worked out.
News Flash: I saw it in the wild...
WOOT WOOT! Congrats Nick!
Man I've been looking for this on their site monthly even after I pieced together my kit out of mere curiosity. But alas the only bracket I had available was OEM RS2. So I had no choice but 323. Once my rotors need replacement this will be the next logical upgrade path... thanks for posting...
Sent from my KFTT using Tapatalk HD
Post by vt10vt »
:hail: I'd love to have an 01E'd 200 in the future, guess I should see if/how fast the 20v can eat 016's first
