Page 6 of 8
Re: Andy's 91' 80q
Posted: Sun Jul 18, 2021 11:02 pm
by rennenmsports
My new air filter box mold. Making it out of high quality fiberglass. But I think everyone cuts them out. If your interested in one let me know
- C4EB263C-456A-45D1-9B48-57C7EE33ACA3.jpeg (129.59 KiB) Viewed 75992 times
Re: Andy's 91' 80q
Posted: Mon Jul 19, 2021 8:11 pm
Oh boy, that's a nice tactic. Adapting the Sport quattro concept has been on my mind a long while.
Is there ducting into the scuttle panel / rain tray?
Velocity stack?
Re: Andy's 91' 80q
Posted: Mon Jul 19, 2021 8:42 pm
by rennenmsports
Thanks bud! I made a plate with a 3 inch tube to cover the hole in the bottom of the battery tray. Then since I’m not running ac I attached a 3 inch silicone hose pushed through the firewall to draw air from inside the cabin. Found spectre 4 inch duct flanges. One on the inside for a 4 inch turbo gaurd air filter. There is a few slots going into the rain tray from factory making up for the 1 inch difference. There is room for a velocity stack as well.
Re: Andy's 91' 80q
Posted: Mon Jul 19, 2021 8:47 pm
by rennenmsports
- 0B7F968E-B481-4583-9347-C93FA8C80FED.jpeg (115.92 KiB) Viewed 75962 times
- 5CC3DC9F-7303-42CC-B75B-810C86BD562C.jpeg (118.53 KiB) Viewed 75962 times
- 1401354B-B32B-46B4-806A-89FA2514A26E.jpeg (114.05 KiB) Viewed 75962 times
Re: Andy's 91' 80q
Posted: Tue Aug 03, 2021 4:56 pm
by rennenmsports
- 4E0A2643-A498-4D38-9B04-9252DC3A8E81.jpeg (29.07 KiB) Viewed 75773 times
The mold is coming along nicely. I’m still debating on what to make the real one out of. A lot of heat will be generated under it.
Re: Andy's 91' 80q
Posted: Sun Aug 22, 2021 8:14 pm
http://www.extremeheatprotection.com/hi ... satin.html
Something like this looks alright... I'd guess basically any fibreglass rated for high heat will do the job nicely. If you were so inclined you could use gold foil to reflect heat away from the airbox, and/or a thin OEM-like aluminum shield as well.
Re: Andy's 91' 80q
Posted: Fri Sep 10, 2021 8:36 pm
by rennenmsports
That looks good! I’ll look into it further. I have a bunch of different things on the car pending. I’m running aluminum fuel line from the front midway up the firewall to under the back seat right now. Almost done. But need about 5 ptfe lined flexible hoses to finish the fuel system to hopefully be able to idle it on its own now. I’m getting there. Got everything mounted. Just need to plumb everything up
Re: Andy's 91' 80q
Posted: Sun Oct 31, 2021 10:07 am
by rennenmsports
Finally got the plug made. I’m about to make the piece that actually goes onto the car. It’s going to have a boost logic universal 4” air filter
- 891D4F93-57C2-44B2-B081-6F62C4E9AE30.jpeg (112.42 KiB) Viewed 70506 times
- F164F827-6703-4BAA-8D0F-AC0D7EA36CD6.jpeg (92.3 KiB) Viewed 70506 times
Re: Andy's 91' 80q
Posted: Mon Nov 01, 2021 2:28 pm
by rennenmsports
- E8307F2A-B9CA-4E6E-8E0D-1CD300FB928A.jpeg (50.12 KiB) Viewed 70452 times
Re: Andy's 91' 80q
Posted: Mon Nov 01, 2021 6:04 pm
by rennenmsports
It fits
you can see the flange on the filter inside the first layer of glass
- 5ABD3683-D59B-4341-BB8A-BF092989C2B4.jpeg (107.68 KiB) Viewed 70448 times
- CB29EA43-A729-441F-B3DE-2688DCF65810.jpeg (180.67 KiB) Viewed 70448 times
Re: Andy's 91' 80q
Posted: Thu Nov 04, 2021 7:39 pm
by rennenmsports
- 47A65F24-FB5D-423C-8349-E7E30B06597E.jpeg (160.46 KiB) Viewed 70288 times
- 44A728C2-577C-49F0-9442-7CC89E3BBCD2.jpeg (115.74 KiB) Viewed 70288 times
Re: Andy's 91' 80q
Posted: Sat Nov 06, 2021 2:52 pm
by rennenmsports
Now that I know everything will work out. It’s on to the next one made out of something I found that can handle up to 1100 degrees F and make it thicker.
- 0D11BEAF-A267-4B1B-803D-BCB5D734BBBE.jpeg (130.15 KiB) Viewed 70219 times
I failed miserably using this. Gonna try something different
Re: Andy's 91' 80q
Posted: Sat Dec 11, 2021 8:30 am
by rennenmsports
Well. She finally runs on her own after 17 years
I tried to post the video but it didn’t work. It would probably be sideways or upside down anyway
What a sigh of relief!
- 93420BF8-7D42-41B7-A857-AF7CF27E0DFB.jpeg (140.72 KiB) Viewed 69243 times
Re: Andy's 91' 80q
Posted: Fri Dec 17, 2021 7:15 pm
by rennenmsports
Hahaha. It fit. No dash removal
- 20370AAE-35DF-4AF0-8F76-052E853C5677.jpeg (85.35 KiB) Viewed 69056 times
Re: Andy's 91' 80q
Posted: Sat Mar 12, 2022 4:58 pm
by rennenmsports
- 3B64B4B1-8CBC-478D-94B6-EF012EF3BAAE.jpeg (83.02 KiB) Viewed 66450 times
Re: Andy's 91' 80q
Posted: Tue Nov 15, 2022 9:13 am
by rennenmsports
- C62E4300-68FA-4C1D-A7C6-35CC86F39346.jpeg (130.85 KiB) Viewed 60281 times
- 5946A282-DE12-4524-9950-3DEDF0878EEF.jpeg (150.75 KiB) Viewed 60281 times
Re: Andy's 91' 80q
Posted: Mon Dec 05, 2022 2:54 pm
by rennenmsports
- F03ABC8A-4E6E-425B-9065-F39B724742CA.jpeg (953.89 KiB) Viewed 59621 times
Re: Andy's 91' 80q
Posted: Sat Dec 10, 2022 10:09 am
by sayoda
Looks like it's getting there!!
Sent from my E7110 using Tapatalk
Re: Andy's 91' 80q
Posted: Tue Jan 17, 2023 7:23 pm
by rennenmsports
Slowly but surely
- 4DF3674E-F72B-4813-9A66-A54F711387E4.jpeg (146.26 KiB) Viewed 58053 times
Re: Andy's 91' 80q
Posted: Fri Jan 20, 2023 1:04 am
by JH87
rennenmsports wrote:Slowly but surely
Looks great!
What’s the part number for that timing belt?
Re: Andy's 91' 80q
Posted: Sun Jan 22, 2023 1:43 am
by rennenmsports
T137RB. But it’s for the AAN. Different tensioner setup then the 3B
Re: Andy's 91' 80q
Posted: Thu Jan 26, 2023 11:01 pm
by JH87
rennenmsports wrote:T137RB. But it’s for the AAN. Different tensioner setup then the 3B
Gotcha… uses the spring tensioner instead of the water pump?
Re: Andy's 91' 80q
Posted: Sun Jan 29, 2023 5:34 pm
by rennenmsports
Yes. But no spring in mine
- DD524DEB-B71F-4A90-8A47-1D98738B3A5A.jpeg (118.22 KiB) Viewed 57287 times
Re: Andy's 91' 80q
Posted: Sat Mar 04, 2023 7:52 pm
by rennenmsports
- 19F53220-4000-44F8-A272-F289017273B3.jpeg (143.49 KiB) Viewed 56012 times
To get the front urs hubs and bmw wheel bearing to fit the outer cv joint into the 80q’s rear knuckles
Re: Andy's 91' 80q
Posted: Sat Mar 04, 2023 10:38 pm
by rennenmsports
- DB3FFF23-FE7F-4601-A617-2D7C3F1116B6.jpeg (127.96 KiB) Viewed 56004 times
