Aarons RWD car - 5-26: more tin and racing saturday
- ringbearer
Re: Aarons RWD car - 12-14: driver side floor done, now fire
We are here, just sort of speechless.
This is so far over the top it is hard to fathom.
Keep it up and continue with the updates if you will. I really enjoy this build!
I hope to get to see it in the flesh someday.
- speeding-g60
so it was written, and then shall it be done.
we shall catch you all up to this day.
1-4-15: Got some more tin work done over the holidays. Spent more time pouring a slab and installing a new hot tub though.
And do keep in mind I only get down there on Saturday's usually to work on it for the day.
Had a friend pull a mould from my S2 rear bumper and build me a couple. Shaved the exhaust port as it is not needed.
Back on tin.
Back on tin.
- speeding-g60
and yesterdays post.... from Saturdays work.
1-31-15: More work done. This is a lot of detail work. No wonder he said the average tube chassis car takes 7 grand for just this sheetmetal and tin work.
- ringbearer
Re: Aarons RWD car - 2-2-15: tunnel sheetmetal work
Awesome sheet metal work! I've done a bit but never anything close to that. Impressive skills
- speeding-g60
random update. i guess i never posted pics of my 3rd member...... it came from this car, it was his backup and not the proper ratio for him at our elevation. it would work great for him in Vegas, for instance.
Strange aluminum 3rd member, with a Pro Gear lightened ring gear, lightened steel spool, yoke loop, forged yoke, 40 spline, 4.30 ratio.
by calculations with this final drive ratio, if i crossed the line at 9000 rpm its 186 mph on the drag radial and on a 32" slick at 9k rpm its 199 mph.
its really not a bad starting point.
this is the car it came from. Rodney won a Wally last year, too, which is an honor and a feat. this is the same level of build, just in an import body with an inport motor setup. this car is in the 700 cubic inch motor range. and that rear tire will be the same i use when i graduate to a slick as well.
Re: Aarons RWD car - 2-8-15 random update 3rd member
That's a really nice starting point!
In an effort to keep you posting I just want to say this is awesome. Now show us the turbo!
- speeding-g60
i cannot show it to you until i get it in my hands.
suffice it to say it is a little larger than my current one. and it shall require nitrous to spool up but will be a monster when up on the converter/transbrake.
i can say its in the GTX snail family....
- speeding-g60
Tunnel is officially completed now on to the rear of the hoop.
More tin work today. Tunnel is officially FINISHED! !!
On to the rear part aft of the hoop now. Made some ledges for the tin to bolt to and support inner and outer tin while also giving flanges for the tubs to bolt to.
Pulled the drive shaft enclosure to mark holes for dzus tab it comes out relatively quickly. I think I can have the passenger side and tunnel opened up in well under a minute. All panels pulled wide open work space.
Re: Aarons RWD car - 2-16-15 tunnel done now rear sheet meta
Really starting to take shape now, looking really good!
Any chance of your buddy doing carbon fibre bumpers? *nudge*wink*hint
- ringbearer
I like the serviceability aspect too. Being able to get to what you need to makes all the difference.
- speeding-g60
So the turbo arrived. And it's not small.
GTX 4508R. 80mm.
Will use nitrous to get it spooled up on to the transbrake. Maybe a 50 shot for 1 second or a little more.
A fair bit larger than the BORG Warner 67mm billet I use now on the AWD car.
GTX 4508R. 80mm.
Well... since you're using nitros for spool you should have just went ahead and bought the big turbo
Lol holy fuck
Re: Aarons RWD car - 3-4: GTX4508R content. 80mm yeah that
Hell yes, I was wondering when this was going to get a man size turbo.
- speeding-g60
i shall be running a dual rail setup with staged injection as well as nitrous.
if i am going to go, i may as well go all fucking out.
does this qualify for YOLO???
Yes, yes it does. Let me know when you need those injectorsspeeding-g60 wrote:i shall be running a dual rail setup with staged injection as well as nitrous.
- speeding-g60
i will. it wont be for quite some time though, i dont plan on this car this year, hopefully 2016. this shit takes tons of money and i am a simple working man.loxxrider wrote:Yes, yes it does. Let me know when you need those injectorsspeeding-g60 wrote:i shall be running a dual rail setup with staged injection as well as nitrous.
Indeed it does. I can see that even on my lowly revver build!
- speeding-g60
well shit. i skipped you guys a couple updates.
todays work.
Starting to look like a car now.
Has a firewall now and all.
And now cleaning up some dash sheetmetal in prep for tin.
todays work.
- speeding-g60
only a little work. did some cleanup then assisted with the first fire up of the latest Cobra. 427 small block Windsor based motor.
Very cool, it's starting to look like a car again!
- ringbearer
Das one big terbo!
Nice Cobra, not much sidewall on those wheels though.
- speeding-g60
yeah. rears are on a 12 or 13" wheel, one-off custom built set of wheels and tires. 345/25-ZR20's.
- ringbearer
25 series, wow. I do love cobras, what kit is it? I drove a Superformance cobra with a Ford motorsports 514, was fun to put it politely
