Ed's 1991 CQ: Progress!
Re: Ed's 1991 CQ. Injection is nice but I'd rather be blown.
I need to look into that. May save some time. I could also look into making one but it probably is not worth the time.
PRA4WX
Post by PRA4WX »
Mcstiff wrote:I need to look into that. May save some time. I could also look into making one but it probably is not worth the time.
T into the oil pressure port= done!
Yeah, yeah, yeah; you know how I like different :D
If all goes well I could have boost before 2012! That would, basically, be bolting everything onto the stock 7a and ghetto fab'd 3" downpipe to current exhaust :D
I also should perform a flywheel trigger pin augmentation, just in case.
Regarding the TPS plug, is it the same size as the MAF plug on a 20020v?
Still need to hunt down, or order, the TPS plug and sort out a few other loose ends but I am prepping to start tearing into the turbo install starting Monday (need to clean the garage, borrow a car, and do Christmas this weekend)!! I'm not sure if I have the willpower to set up the VEMS without bolting on the Holset but it is most likely a good idea to deal with one change at a time.
Finally a bit of progress! I should have all day tomorrow :lol: to work. I need to get the manifolds on and figure out how to connect the dots.
Of course the coolant hose is in the way so that is not the final position. Before anyone says anything, I wiped off the valve cover but it is pretty bad :lol:
PRA4WX
Post by PRA4WX »
Is it done yet?! ;-)
Wow. At first glance I thought you painted the valve cover black . ;)
You should have seen it before the degreaser and brushing ;)
Ok, once the family was alseep I had a beer and decided to get to work. I toyed with the thought of getting it running on VEMS with the new intake but no risk no reward! So I threw caution to the wind and started pulling the exhaust manifold. The first nut either had a basically broken stud or I didn't know my own strength :D Oh well, I only broke one more stud but the rest of the nuts were not too bad (the back lower two are a bitch but I got the whole bottom row with a combo wrench). So, at this point the next step is pulling the downpipe so that I can get everything out of the way. This involves jacking up the car and laying on the ground so I decided to mock up the EM and Holset!!
Looks good from over here
And up here
From the Right Lane
Downpipe Clearance
Artsy
A broader view of the work space showing why it needs to be bigger :D
So to be clear, the EM and turbo are just resting in place above the stock manifold. This means that the package will be ~3" lower and 5+ mms closer to the head. My AC lines are in the way bigtime (the turbine is sitting on them in the pics) but other than that I think it looks pretty good. The downpipe and charge air pipe with be tight but it is a German car. I am concerned about fitting the 7a coolant pipe (head to radiator) clearing the IM. Hopefully clearancing the runners will make it fit.
varia
Post by varia »
good progress to start the new year!
Thanks! I've pretty much committed to not driving it without boost in 2012 :D
ian4455
Post by ian4455 »
Looking good Ed, thanks for the link from the S2 forum. I'll be following this project ! Ian
Ah, what a befitting home for my old turbo. Looks great in there!
(4x5)v=20v
Post by (4x5)v=20v »
I see you have depot lights. Did you have any fitment issues with the 7aT intake elbow? Mine is resting on the back of the light with the cover removed. I don't have close to enough room to put the cover on it.
Those are Bosch but will soon be swapped for B4 H1/H4s. I have not set up the intake yet but will most likely use a cobra head 90° setup.
(4x5)v=20v
Good idea, any good sources for cobra head elbows?
84urq20v
Post by 84urq20v »
Nice Ed! Looking good! Hopefully we'll see it (and I guess you, too :D ) at a dinner soon. And I'm jealous of _your_ garage - gives you an idea how bad mine is!
Racepartsolutions.com should have them, 034 of course.
I'll make a dinner one of these nights! The downer of my new schedule is that I work tues-sat which makes fri&sat nights difficult! Oh well, not exactly permanent.
The garage is a 1 SUV/ 2 Coupe (lol, I told the wife if we had another CQ she could park inside :D) so the problem is all the kids stuff and other shed fodder that I would build a shed for if I had flat ground for it! I've seen worse for sure but I'm jealous of my buddy with >1k sqft and an upstairs (in Highlands of all places). I've always wanted a carriage house as a shop :D
ian4455
Post by ian4455 »
What size is the hotside you've used 12cm3 ?
Quattro v1.0
Post by Quattro v1.0 »
Does this thing blow yet?
HA, you'll see a vid when it does!
I just started my work week so progress will be slow until Sunday.
ian4455 wrote:What size is the hotside you've used 12cm3 ?
Correct. This is Chris's (loxxrider) old H1C with HX35 turbine housing.
haven't clicked on your project in a while, looks great!! :woowoo:
