Page 10 of 45
Re: A tale of Rubí... Bottom End Assembly Commences w/PICS
Posted: Mon Jun 10, 2013 2:41 pm
by mushasho
Posted: Mon Jun 10, 2013 2:47 pm
by EDIGREG
Take a wider photo so we can see the top of the cam sprockets and the chain.
If you count 7 teeth up on each cam from the marks (teeth with marks being #1), there should be 10 links between those two teeth.
by EDIGREG
picture is worth 1000 words
Posted: Mon Jun 10, 2013 3:13 pm
by mushasho
Awesome!!! Didn't wanna search for that with dirty fingers on my phone, I know I had seen this before and a conversation regarding the possibility of having to time 7a's a but differently in an AAN application... I think it was a thread started by Dave in QW. I haven't seen mention of it since so im assuming it was more of a theoretical post...
Oh, and has anyone been able to spec out the wider washers needed for the ARP head studs... Trying to find those locally if someone has the measurements. Sort of wanna get that far today...
Thanks
Posted: Mon Jun 10, 2013 6:01 pm
by mushasho
Spot on?
Posted: Mon Jun 10, 2013 8:11 pm
by Mcstiff
mushasho wrote:7a & 7a it is... Assembling now..
how many open links should there be an on chain now?
Hold on, how are you setting the cam sync? I don't think, may be wrong, that it is as simple as 180* off.
Posted: Mon Jun 10, 2013 9:00 pm
by mushasho
I believe I have it like soo
EDIGREG wrote:picture is worth 1000 words
Posted: Mon Jun 10, 2013 9:04 pm
by Mcstiff
Right, that is the stock alignment.
I am saying, is this as simple as phasing the exhaust +-180* to make into a, properly performing, intake?
Re: A tale of Rubí... Top Assembly Commences w/PICS
Posted: Mon Jun 10, 2013 9:10 pm
by mushasho
Oh I think you're under the assumption that I mix and match my cams... I went 7A Intake and 7A Exhaust in there intended location.... none of that "AAN Exhaust Cam as the intake & 7A Exhaust" stuff... Ain't got time for that right now... lol
Posted: Mon Jun 10, 2013 9:15 pm
by Mcstiff
:lol: Yes, this post was misleading:
mushasho wrote:How about AAN exhaust cam on the intake side paired with 7a exhaust side?
:carryon: :police:
Posted: Mon Jun 10, 2013 9:37 pm
by mushasho
Then these guys quickly responded:
EDIGREG wrote:That will work just fine, but the most gains are with both 7A intake/exhaust
Hank wrote:Use 7a exhaust on both :) Some machining/degreeing required.
Since I don't have 2 sets of 7A's, I really couldn't go with Hanks suggestion... Since I DO have AAN Exhaust cams, I might modify that one at a later date and use it as on the intake...
Posted: Tue Jun 11, 2013 7:19 am
by mushasho
A little dress up...
Posted: Tue Jun 11, 2013 9:14 am
by Hank
7a intakes don't have enough duration to support power above 6800 on bigger turbos. By putting the exhaust in the intake slot, you can grab a bit more lift and a tad more duration. With the cost of 7a cams, it is coming close to what proper Cats or other cams are designed to do, with far better specs. Still, there are some really good dyno plots where the power does not drop off at 7000 like I am accustom to seeing on straight 7a cams. This is also why retarding the cams with a cam gear yields great results..
Posted: Tue Jun 11, 2013 10:59 am
by Mcstiff
Hank wrote:7a intakes don't have enough duration to support power above 6800 on bigger turbos. By putting the exhaust in the intake slot, you can grab a bit more lift and a tad more duration. With the cost of 7a cams, it is coming close to what proper Cats or other cams are designed to do, with far better specs. Still, there are some really good dyno plots where the power does not drop off at 7000 like I am accustom to seeing on straight 7a cams. This is also why retarding the cams with a cam gear yields great results..
Hopefully the costs keep increasing, good for the 07K fund :D
Posted: Tue Jun 11, 2013 4:47 pm
by mushasho
Posted: Tue Jun 11, 2013 6:59 pm
by 85oceanic
Looking really sharp man?
How does retarding the cams yield more power? Is it because the valves are opening "late" after TD help? Reason I ask is because as you know Hank, I'm going to be on 7a cams. If having an adjustable cam gear will help me achieve a better power band, I better start thinking about picking one up.
Posted: Tue Jun 11, 2013 7:13 pm
by da_trem
Retarded cam timing as been discussed here:
http://www.motorgeek.com/viewtopic.php? ... ng#p235352
Posted: Tue Jun 11, 2013 7:24 pm
by 85oceanic
Thanks man and holy frick, over a 50whp gain buy just adjusting the cam timing. That's crazy.
Posted: Tue Jun 11, 2013 8:52 pm
by mushasho
85oceanic wrote:Looking really sharp man?
Thanks!
Sent from my KFTT using Tapatalk HD
Posted: Wed Jun 12, 2013 10:48 am
by themagellan
Built to the hilt
Dress to impress
Posted: Thu Jun 13, 2013 8:49 pm
by mushasho
Posted: Thu Jun 13, 2013 9:04 pm
Is it done yet? What's the hold up? Driving impressions? Why don't you put a 07k in instead?
/dickmode
Posted: Fri Jun 14, 2013 6:23 am
by mushasho
chaloux wrote:Is it done yet? What's the hold up? Driving impressions? Why don't you put a 07k in instead?
/dickmode
Lol....
1) Done? Not done but getting there
2) Hold Up? Still waiting on parts ordered/paid over a month ago
3) Impressions? I think it'll be expensive at the pump once it's done (thinking of upgrading the fueling after break in)
4) 07k? I have one, but it's not going anywhere near here...
/earlymorningrushresponsemode
Re: A tale of Rubí... Break down w/PICS
Posted: Fri Jun 14, 2013 8:20 pm
by mushasho
Quick rinse out of hibernation..
Placed behind shop...
Commence break down...
Posted: Mon Jun 17, 2013 11:39 am
by mushasho
