Re: Jim Green's 90q 20vt - 600whp 07k build
Post by Afterthought »
audifreakjim wrote:I have never had fuel starvation issues if above 1/4 tank on the track, although I never actually logged fuel pressure so who knows. The surge tank is really there just to submerge the Walbro pump, you can't just place them inline because they leak. See above a few posts.
The jets are .5mm green banded. I run a 6th right before the air temp sensor to trick the ecu into adding more timing. My pump is either 150 or 200 psi. Can't remember. It's high enough I don't worry about pressure drop on high boost.
All controlled by an aquamist fast acting valve on a spare injector channel that is enabled by a Hobbs pressure switch around 15psi
I also have an AEM fail safe system that monitors flow I plan on having it disable high boost if flow falls outside the normal map.
I have a lot invested in this system so it would have been silly not to run it! Only a few extra evenings so far to get it installed completely stealth mode.
In regards to the fuel, I run one of these gauges (in addition to 5 other gauges) in my S4. Its a nice unit and stores your max, so at any point you can hit a button to see your max from the last pull you did, or hold the button down and reset. Kind of a nice feature, so if you're at 30 PSI you can focus on the road.
http://www.demon-tweeks.co.uk/motorspor ... dual-gauge
The AEM failsafe is a must! The only issue I have ever had with it is if the pump flow is somewhere in between low and high. I have seen a scenarios before when it was clogged where it was at about 200 ml/min and so it was enough to not trigger the failsafe but less flow than I want.
It's really a cool system when set up right!
I can't wait to get the Failsafe setup in dad's car. Definitely worth it IMO
looking fantastic Jim :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
LMAO
Randomly came across these. Kinda like finding $50 in your pocket. I was just starting to think about making some shrouds and how to cleanly fasten them all together.Image
Post by ChrisAudi80 »
Are those Dzus fasteners?
Yes, apparently I bought a value pack sometime ago. I should clean the garage more often!
Pic for progress. Image
type85
Post by type85 »
Funny how "great minds think alike"!!!
90quattrocoupe
Post by 90quattrocoupe »
nice.
Derale PWM fan control is in!
Spent all day wiring things up. No fire yet, but all wires are mapped out and ready on the VEMS side.
deaner
Post by deaner »
Wooohooo! Getting close!
pkw
Post by pkw »
it is practically doing a burnout already.
Post by dana »
im vicariously exited!
Cabin side..Image
maybe etch the numbers into those connectors as well as the magic marker? I have the cheap harbor freight electric engraver, works great.
Etching is so permanent. What happens when I have to swap in a hyper drive?
I have a label maker, you would think I would use it, lol. Sharpie FTW!
I borrowed my wife's for the CQ but I don't think it does heat shrink tube.
That's better. Image
90quattrocoupe
:thumbsup:
varia
Post by varia »
Cant wait to see this monster next week!
Greg is also coming over.
¯\_(ツ)_/¯
project 2226
Hey Jim... How are ya bud... was just wondering if I was already sorted out and ready for 1st Start Up :drive:
