Page 109 of 125
Re: Jim Green's 90q 20vt - 600whp 07k build
Posted: Wed Aug 26, 2015 1:32 am
by Afterthought
audifreakjim wrote:I have never had fuel starvation issues if above 1/4 tank on the track, although I never actually logged fuel pressure so who knows. The surge tank is really there just to submerge the Walbro pump, you can't just place them inline because they leak. See above a few posts.
The jets are .5mm green banded. I run a 6th right before the air temp sensor to trick the ecu into adding more timing. My pump is either 150 or 200 psi. Can't remember. It's high enough I don't worry about pressure drop on high boost.
All controlled by an aquamist fast acting valve on a spare injector channel that is enabled by a Hobbs pressure switch around 15psi
I also have an AEM fail safe system that monitors flow I plan on having it disable high boost if flow falls outside the normal map.
I have a lot invested in this system so it would have been silly not to run it! Only a few extra evenings so far to get it installed completely stealth mode.
In regards to the fuel, I run one of these gauges (in addition to 5 other gauges) in my S4. Its a nice unit and stores your max, so at any point you can hit a button to see your max from the last pull you did, or hold the button down and reset. Kind of a nice feature, so if you're at 30 PSI you can focus on the road.
http://www.demon-tweeks.co.uk/motorspor ... dual-gauge
The AEM failsafe is a must! The only issue I have ever had with it is if the pump flow is somewhere in between low and high. I have seen a scenarios before when it was clogged where it was at about 200 ml/min and so it was enough to not trigger the failsafe but less flow than I want.
It's really a cool system when set up right!
Posted: Wed Aug 26, 2015 8:35 pm
I can't wait to get the Failsafe setup in dad's car. Definitely worth it IMO
Posted: Thu Aug 27, 2015 9:04 am
by EDIGREG
looking fantastic Jim :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
Posted: Thu Aug 27, 2015 10:38 pm
by Mcstiff
Posted: Thu Aug 27, 2015 11:28 pm
LMAO
Posted: Thu Aug 27, 2015 11:54 pm
Randomly came across these. Kinda like finding $50 in your pocket. I was just starting to think about making some shrouds and how to cleanly fasten them all together.Image
Posted: Sat Aug 29, 2015 8:49 am
by ChrisAudi80
Are those Dzus fasteners?
Posted: Sat Aug 29, 2015 9:48 am
Yes, apparently I bought a value pack sometime ago. I should clean the garage more often!
Pic for progress. Image
Posted: Sat Aug 29, 2015 10:00 am
by type85
Funny how "great minds think alike"!!!
Posted: Sat Aug 29, 2015 2:22 pm
by 90quattrocoupe
nice.
Posted: Sat Aug 29, 2015 6:25 pm
Derale PWM fan control is in!
Posted: Mon Sep 14, 2015 12:26 am
Spent all day wiring things up. No fire yet, but all wires are mapped out and ready on the VEMS side.
Posted: Mon Sep 14, 2015 8:26 am
by deaner
Wooohooo! Getting close!
Posted: Mon Sep 14, 2015 9:07 am
by pkw
it is practically doing a burnout already.
Posted: Mon Sep 14, 2015 10:45 am
by dana
im vicariously exited!
Posted: Thu Sep 17, 2015 4:59 pm
Cabin side..Image
Posted: Thu Sep 17, 2015 7:48 pm
by Marc
maybe etch the numbers into those connectors as well as the magic marker? I have the cheap harbor freight electric engraver, works great.
Posted: Thu Sep 17, 2015 9:09 pm
Etching is so permanent. What happens when I have to swap in a hyper drive?
Posted: Thu Sep 17, 2015 9:30 pm
by Mcstiff
Posted: Thu Sep 17, 2015 9:35 pm
I have a label maker, you would think I would use it, lol. Sharpie FTW!
Posted: Thu Sep 17, 2015 9:40 pm
by Mcstiff
I borrowed my wife's for the CQ but I don't think it does heat shrink tube.
Posted: Sat Sep 19, 2015 9:55 am
That's better. Image
Posted: Sat Sep 19, 2015 10:15 am
by 90quattrocoupe
:thumbsup:
Posted: Sat Sep 19, 2015 10:26 am
by varia
Cant wait to see this monster next week!
Greg is also coming over.
Posted: Fri Sep 25, 2015 10:08 am
by mushasho
Hey Jim... How are ya bud... was just wondering if I was already sorted out and ready for 1st Start Up :drive:
