Re: A tale of Rubí... Block bolted up awaiting mounts...w/PI
Spent a good amount of time bolting it onto the bell housing... Had to cut this off we I had totally forgotten that UrS blocks need this dowlpin removed in order to mate up to the 6speed 01e...
Toph
Post by Toph »
Whooooops...oh well..
Did the snubber arrive?
90 Coupe Quattro - 3b + 01e
87 4000 - future trail rig
Toph wrote:Whooooops...oh well..
Not yet... I did pick these up locally in the meantime along with a rubber snub to compare...
UrSobsessed
Post by UrSobsessed »
Gonna be soo nice!
Quattro-JC
Post by Quattro-JC »
Man that's an ugly goopjob. How many bevs did Mage have before slathering those things together? Maybe not enough.
Actually I needta talk to him, I might do some Bimmer subframe bushings that have cavities and was thinkin of doing the SlaterMount/MageMount/AnybodyElseMount trick to 'em....
JC
2003 M3Cic TiAg
2002 540iT Sport 6MT LSD TiAg
1995.5 Audi S6 Avant (the turbobattlewagen - now with Moar RS2 Billety goodness)
haha fukhed.
The only improvement on this design would be if I had a welder capable of welding a face plate to completely lock in the rubber. Good news is those were wire brushed, and set with 3 separate layers over a period of 96 hours. The beautiful tinsel gloss is a nice 3M paint that is washable and will protect the actual 3M window weld through the snow and salt.
Run some neoprene/rubber washers under the nuts for silky idles!
but yeah... I was drinking.
Quattro-JC
Dropped in on to add my useless oversight to the process today... things comin' together!
Obes I suspect without the Mustang Mount side project you'd be drivin around tonight! :D
JC
2003 M3Cic TiAg
Quattro-JC
themagellan wrote: but yeah... I was drinking.
TJ: Hey Mager Rager - you gonna hit up the Wiillows GheyToGeth tomorrow? Matties been sextin' me and we might meetup there. I'd like to get more info on yer mount mods etc - I remember you tole me some stuff at Jackie's but I didn't exactly rite shit down... If yer lucks I might even drive the S6. Probably not but maybe.
JC
2003 M3Cic TiAg
One thing that's a must was to use 1" bolts as opposed to the supplied 3/4" that come with the mount...
Slight trimming...
urs6ville
Post by urs6ville »
mushasho wrote:Spent a good amount of time bolting it onto the bell housing... Had to cut this off we I had totally forgotten that UrS blocks need this dowlpin removed in order to mate up to the 6speed 01e...
you know it just pulls out with a big pair of channel locks right?
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
1995 UrS6 - Black/Ecru ~225,000mi
Rebuilt Engine - installed @ 223,379mi
AAN Build Photos http://goo.gl/a8YHd
Car Photo Stream http://goo.gl/czdLg
Not on this one for some reason...
Please let Mage ride shotgun in the RanchoWagon... He's lost some major mojo... Doesn't even drive his car on weekends... Leaves the doors open and trunk with parts and love notes... He's in a funk man... Maybe with the help of Motronic Launch Control, it's possible to save him (and the car...)..:smile:
Quattro-JC wrote:Dropped in on to add my useless oversight to the process today... things comin' together!
Hey, "no radiator in the way" shot for Ed... Didn't see snap that...
Quattro-JC
Ill blow smokeflames at him tomorrow...
And maybe even fire up the launch control too.
JC
2003 M3Cic TiAg
urs6ville
Post by urs6ville »
mushasho wrote:Not on this one for some reason...
Not enough muscle.. or big enough channel locks .. or both :D
Almost...
urs6ville
Re: A tale of Rubí... Coming along...w/PIC
Post by urs6ville »
Yes.... as we talked about on the phone... your dampener looks fine.. it is the "J", the holes on the face are closer together (what I noticed when I was standing in my garage at 11pm looking at the front of the car dumbfounded). The "H" holes are oriented differently. The "J" requires the washer.
notice how your serp tensioner when in the locked position isn't interfered with by the outer lip of the dampener... that means you have the washer back there (I assume so anyway). If you installed a "J" dampener without the washer you would find that the tensioner would be touching the outer lip of the dampener.
Ask me how I know all this ;)
These suck...
DuBistS4
Post by DuBistS4 »
lol I broke mine too by turning the motor over by hand without torquing it. I dont think the key way is meant to handle any load what so ever.....its purley there for locating it. My car survived the dyno without a proper keyway in it anyways. But im still looking for a replacement....
'94 UrS4 Red/Black
Vems
Lightly modded head
-Will
Ended up with this...
Toph
Post by Toph »
Bah, that's no good...but at least you have the replacement there, and it looks like the cam is ok...just a speedbump!
DuBistS4
Post by DuBistS4 »
It looks like the adjustable cam gear has no key way, is that correct?
'94 UrS4 Red/Black
Vems
Lightly modded head
-Will
DuBistS4 wrote:It looks like the adjustable cam gear has no key way, is that correct?
