Page 15 of 25
Re: Ed's 1991 CQ. Nitty Gritty
Posted: Sat May 26, 2012 6:47 pm
by Hank
Just the 7a flywheel?
Posted: Sat May 26, 2012 7:53 pm
by Mcstiff
ShavedQuattro wrote:Just the 7a flywheel?
That may be the issue; I rather redo a wire though. I've got ~3.4mm gap from the sensor but the pin only intersects 3/4 of the width of the hole, not sure if that's an issue.
Posted: Sat May 26, 2012 8:54 pm
by Hank
not *may* ....... IS the problem.
You need to strengthen the signal!! I don't think the 7a pin is wide enough to give the ecu enough of a signal.
Posted: Sat May 26, 2012 9:56 pm
by Mcstiff
Marc, seems to have either more confidence in the 7a flywheel or less in my wiring ;D Just got home from work, going to confirm everything is hooked up correctly.
Posted: Mon May 28, 2012 12:26 pm
by Mcstiff
So when I position the flywheel pin at the sensor I seem to be before TDC. I thought the pin was telling the sensor that the crank is at TDC? The "line embossed on the top surface of the Hall rotor immediately under the hot end of the dist rotor, and a mating line notched into the top edge of the distributor housing opposite the Hall connector and just above the Hall sensor unit" match up so that means the window is over the hall pickup right? The car drove into the garage and I have not touched the timing.
In the meantime I am going to f(x) check the wiring
(edit:wiring checks out).
Fiddlestickin paint pen!
Edit:
Found this:
yodasfro wrote:You definitely don't need that tool to set timing marks. You should always use the flywheel mark not the crank pulley mark as it moves over do to the rubber in the harmonic balancer. The FW only bolts up one way so now worries there. Set the Cam pulley to TDC check for the line or 0 on the FW to be lined up on the edge of the window in the bellhousing. Once you have cam and crank set then loosen the 13mm nut o n the clamp for the dizzy and rotate the body till the | on the shutter wheel and the | in the body line up done.
http://www.quattro123.com/TB440A.jpg" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
http://www.quattro123.com/TB439TimingMarkViewA.jpg" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
http://www.quattro123.com/Audi200Distri ... st184A.jpg" onclick="window.open(this.href);return false; ... st184A.jpg" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
But my pin is not at the sensor until before TDC so should I sync the Hall with the PIN?
Posted: Tue May 29, 2012 9:54 am
by Mcstiff
Ended up rotating the dizzy to match the hash marks with the location of the trigger pin (not sure how it was running before!) but I'm still not seeing signal :banghead: This is looking more and more like a size of the boat issue since I am, now, confident that everything else is correct.
Posted: Tue May 29, 2012 11:21 am
Does it run on motronic?
Posted: Tue May 29, 2012 11:27 am
by Mcstiff
It used to; no way to test that now #notplug&play
Anyone have a good way of telling wives that the car is not fixed yet because out of a 3 day weekend you've only snuck a few hours of work in? How about explaining that you can't estimate how long it will take because you have not fixed it yet?
Posted: Tue May 29, 2012 11:38 am
I am all ears on that one. My car has not moved all weekend and is parked in the middle of the garage. Out of the three projects I had planned on getting through, I got exactly .4 of one project done..
Posted: Tue May 29, 2012 11:49 am
by jbrentd
I was chasing a no-spark issue off and on for a couple of months and finally figured out I had (and possibibly still have) a bad connection at the ECU. Each time the issue has come back, it goes away after unplugging the ECU and plugging it back in. I had it in the service position twice tracking it down (I cracked the corner of my euro coupe bumper one of those time). Luckily, she still had room to park her car in the garage while it was sitting there.
I would just chalk it up to the age of the car. You start tearing into a 22 year old car and somethings bound to break when you put it back together. My wife seems to understand that one.
Posted: Tue May 29, 2012 11:58 am
by savagerocco
I would say your problem is probably the timing pin size. The pin is roughly 60deg btdc, so it won't line up with the TDC cam mark. The width of the AAN trigger is about 1/4" square peg, the pin on the 7A and 3B are more like 1/8" and round. You will get a much smaller and lower voltage signal from that then the signal produced by the AAN flywheel. Dave made a cool square plug that he drilled out and slid over the original pin, but spacing is critical, too far out, you smack the sensor, to far in, not enough signal. You can install the pin sleeve thru the starter hole, so at least the trans doesn't have to come out.
Posted: Tue May 29, 2012 12:21 pm
by Mcstiff
On my way to grab an oscilloscope and stock for pin girth enhancement.
Posted: Tue May 29, 2012 5:03 pm
by Mcstiff
No measurable signal on the scope, time for metallic pin enhancement; wish I had a drill press!
Posted: Tue May 29, 2012 6:17 pm
Take pics, I'm interested in how this plays out. Good luck!
Posted: Tue May 29, 2012 6:58 pm
by Mcstiff
I'm basically emulating what Hank and Dave did for Dave's car, just using some square stock with an offset hole slid over the pin and welded (I'm tempted to JB it lol).
Posted: Wed May 30, 2012 8:24 am
by Mcstiff
So pin enhancement, I drilled out a chunk of 1/4" square stock but the best I could manage in my ghetto garage was ~0.4mm crooked from side to side (centered at one face but 0.4mm off center of the opposing face).
Will this work or should I be concerned about a crooked pin? I can grab a drill press, just trying to save an hour of driving (I know, I know).
Posted: Wed May 30, 2012 8:46 am
by TheArchitect
Mcstiff wrote:So pin enhancement, I drilled out a chunk of 1/4" square stock but the best I could manage in my ghetto garage was ~0.4mm crooked from side to side (centered at one face but 0.4mm off center of the opposing face).
Forget a drill press, you need a lathe if you want the hole dead center.
From my own experience in decoding the TDC ref pin on those 135 tooth flywheels, the positioning of the pin is pretty important as it needs to occur squarely between the two flywheel teeth for a reliable decode.
Posted: Wed May 30, 2012 8:50 am
by Dave
with vems you can set it to trigger at the begining or end of the pin, and tell it how many degrees off TDC it is, that to me means it doesn't have to be super accurate, you just have to dial it in after the fact.
Posted: Wed May 30, 2012 8:58 am
by TheArchitect
Hybrid_Hatch wrote:with vems you can set it to trigger at the begining or end of the pin, and tell it how many degrees off TDC it is, that to me means it doesn't have to be super accurate, you just have to dial it in after the fact.
Oh but it does need to be accurate since if it occurs too close to either of the two teeth it is in between, noise on the signal will cause one to proceed the other signal in a spurious way with the result being that your timing error moves 2.667 degrees (one FW tooth time) when it happens.
Its problems like this that make the TDC reference pin a short lived method of triggering ECUs.
Posted: Wed May 30, 2012 9:10 am
by my2000apb
that pin is ugly
Posted: Wed May 30, 2012 9:27 am
by Mcstiff
my2000apb wrote:that pin is ugly
Ouch. To be fair I was actually not shooting for center, one side needs to be offset to clear the VR.
Posted: Wed May 30, 2012 9:33 am
by Mcstiff
TheArchitect wrote:Hybrid_Hatch wrote:with vems you can set it to trigger at the begining or end of the pin, and tell it how many degrees off TDC it is, that to me means it doesn't have to be super accurate, you just have to dial it in after the fact.
I'm not sure I'm not sure I'm following. If you are talking about the teeth that the separate speed VR is sensing I don't see how it would be a problem since this sensor is not currently seeing anything (teeth or pin) and <1v signals are, as I understand it, ignored. There is a good chance I'm missing something
Posted: Wed May 30, 2012 9:48 am
by TheArchitect
Mcstiff wrote:TheArchitect wrote:Hybrid_Hatch wrote:with vems you can set it to trigger at the begining or end of the pin, and tell it how many degrees off TDC it is, that to me means it doesn't have to be super accurate, you just have to dial it in after the fact.
I'm not sure about that. If you are talking about the teeth that the separate speed VR is sensing I don't see how it would be a problem since this sensor is not currently seeing anything (teeth or pin) and <1v signals are, as I understand it, ignored. There is a good chance I'm missing something
The ref pin is what tells the ECU the point where to begin counting flywheel teeth for its 360 degree reference.
If you look carefully at a 5 cyl flywheel, you will notice that the positioning of the ring gear puts the tooth between flywheel teeth because you must have a deterministic order in the ref pin VR sensor and the flywheel teeth VR.
Any error between the two from ideal reduces the noise immunity and effects the true accuracy of the ignition timing (be it VEMS, factory, 034 or otherwise). If the ref pin is supposed to lead the next flywheel tooth and suddenly it doesnt due to noise on either VR sensor, you will be off by 2.667 degrees for that 360 degree interval.
Trimming the pin to actual TDC is the easy part and a forgone assumption also in each ECU case.
Also, at low RPMs, you probably will only get a few hundred mv/pp (not volts) from the sensor.
Put a scope on the sensor to know for sure if its working.
VR sensors use a technique called "zero crossing" detection and the actual trigger will be on the point of greatest slope of the VR waveform at the zero volt point. IIRC its the rising edge on the TDC ref pin because audi did the polarity backwards compared to the flywheel VR sensor.
In any case the zero crossing technique will also use a minimum amplitude to enable triggering.
If the amplitude is insufficient, you wont get an output trigger from the VR amplifier.
I'd be surprised if it required greater than a volt since that could make it a no start condition if the signal amplitude is too low while cranking.
Posted: Wed May 30, 2012 9:52 am
by my2000apb
Mcstiff wrote:my2000apb wrote:that pin is ugly
ok touche, i didnt know you were going for that, i still be concerned about it being off center lengthwise, precision machining FTW
Posted: Wed May 30, 2012 9:54 am
File down one of the sides, I would do the one on the left in that picture. This will center the hole, and also allow you to clear the VR.
