Page 3 of 5
Re: Audi S4000 - Alaska
Posted: Sat Dec 20, 2014 11:40 am
sexy stuff for sure! can't wait for vids. woo wooo
Posted: Sat Dec 20, 2014 7:49 pm
by UrSobsessed
Nice! Those Iroz EM's are a work of art. They flow great too.
Posted: Sat Dec 20, 2014 8:36 pm
by Namreg Rac
Making "headway"
Posted: Sun Dec 21, 2014 9:10 am
Nice! Getting right at it, I like your style. Running by Monday? lol.
You will love that turbo. If you thought it was fast before, you're in for a treat. What fuel pressure regulator are you using, an AAN one? You'll need that slight bump in fuel pressure for all the fuel you can get. I was at 86% DC with a 4bar 7a and the 60lb Siemens. Oh, and are you using a bigger fuel pump? 044?
Posted: Sun Dec 21, 2014 12:21 pm
by Namreg Rac
chaloux wrote:Nice! Getting right at it, I like your style. Running by Monday? lol.
I have a new 4 bar FRP. I also got those 60lb Siemens. From what I have read the stock Bosch fuel pump will work well beyond my needs so I am just putting a new one in as well as a filter.
I have a question for you: How do you know which connections on the GTX housing are the oil supply/return and coolant supply/return? I need to get this thing oriented right and can't even figure out what hole in the turbo goes to what.
Posted: Sun Dec 21, 2014 12:54 pm
Oil inlet is the smallest and should have a restrictor fitting, oil drain is largest and needs a flange, use -10 hose at least.
Posted: Sun Dec 21, 2014 1:17 pm
by Namreg Rac
Is this the oil inlet? What is that little piece on the inside? It's not a built in restricted is it?
This is the smallest hole on the turbo
Posted: Sun Dec 21, 2014 1:19 pm
by Namreg Rac
And then the opposite side would be the drain. It has provisions for a little flange
Posted: Sun Dec 21, 2014 1:27 pm
by Namreg Rac
Like this
Posted: Sun Dec 21, 2014 2:13 pm
Posted: Sun Dec 21, 2014 2:26 pm
by Namreg Rac
Yeah I got the kit for the lines when I got the turbo.
Posted: Sun Dec 21, 2014 10:31 pm
by Namreg Rac
Boom
Posted: Sun Feb 01, 2015 8:00 pm
by Namreg Rac
chassis work starts tomorrow, we will see how Taco's bushings and mounts work out...
Posted: Sun Feb 01, 2015 8:04 pm
by Namreg Rac
Posted: Sun Feb 01, 2015 8:05 pm
by Namreg Rac
Posted: Sun Feb 01, 2015 8:07 pm
by Namreg Rac
https://www.youtube.com/watch?v=ZHdbKgq ... rSrf_AXx_g
I am an idiot... "That's a pretty good idle"
All suspension/bushings/and mounts being done starting tomorrow.
Posted: Sun Feb 01, 2015 9:07 pm
Lol
Hell yeah, looks and sounds great. As I said on the other forum, post up a log if you'd like any help tuning. Now we need some vids of full throttle!!
Posted: Sun Feb 01, 2015 9:15 pm
by Namreg Rac
It is going to be a while before I get those logs posted but will do.
Posted: Mon Feb 02, 2015 2:34 am
by AngryTaco
PICZ OF MOUNTZ AND SUBFRAME BUSHINGZZ!!!!
Posted: Mon Feb 02, 2015 5:05 am
by Namreg Rac
AngryTaco wrote:PICZ OF MOUNTZ AND SUBFRAME BUSHINGZZ!!!!
ZOON
Posted: Wed Feb 04, 2015 5:39 pm
by Namreg Rac
Subframe bushings and tranny/diff mounts ala HERSH performance. Subframe bushing were a dream to install. 2 piece setup, awesome.
Installed a rear sway bar and replaced everything that can be replaced under the car.
Installing my coil overs tomorrow then I'll report how awesome this thing drives.
THUGLIFE
Posted: Wed Feb 04, 2015 6:29 pm
Nice. Sometimes having a long cold winter can have it's benefits. My 4k was so ridiculously responsive with all the solid stuff and coilovers. Every little input yielded an output. You'll love it.
Posted: Sun Feb 08, 2015 1:07 am
by AngryTaco
Posted: Sun Feb 08, 2015 8:34 am
by DE80q
AngryTaco wrote:Image
Marking your territory now? :lol:
Posted: Sun Feb 08, 2015 9:49 am
Love the handwritten L
