Page 34 of 125
Posted: Sun Aug 12, 2007 9:37 am
Still a gutted cat. Yea, the tip option is the next option if this doesn't work. :wink:
There's something about saying I legitimately passed smug that's cool.
Posted: Sun Aug 12, 2007 11:02 am
by Toxcheap
audifreakjim wrote:Good to know, I guess they only printed out the things that failed, I was to high on CO in the 2500rpm test which just says I'm running to rich even at 14.7:1. I'll retard the timing 10 degrees and try 15.5:1
Seriously, I've taken the car from wow factor to blah factor. Still moves the same though :-D
I'll be interested to know if it passes at 15.5. Den's A4 is at about 15 at idle and people still say "smells like its a little rich" LOL
Posted: Mon Aug 13, 2007 10:17 am
by RSCoupe
Hey Jim, what size fuel lines were you running on E85?
Posted: Mon Aug 13, 2007 1:57 pm
by 90_Koop
Nice camoflage Jim. Very 8)
Posted: Fri Aug 17, 2007 7:09 pm
RSCoupe wrote:Hey Jim, what size fuel lines were you running on E85?
-6 feed with a stock return line.
So more drama at the smog shop, I got the CO to pass, but the HC was like 4x the legal amount. Feck, now I'm a GP or Gross Polluter. Sweet!
The car is misfiring and dumping fuel. It's not horrible in that the car runs rough, but you can hear it with fairly open exhaust. The 75 # injectors, 60 psi base fuel pressure, no cat and and the fact I've been getting a little wiff of oil every now make for a bad combo.
I just tried reducing my base fuel pressure to 40 psi and it has helped, enabling me to get up into the 1.3 ms range at idle. I think I'm going to make a run to San Diego and fill up on E85 to seal the deal. I can run at like 1.1 lambda with no miss fires. If that doesn't work, I'll pop in some tiny injectors.
Posted: Fri Aug 17, 2007 7:18 pm
by Longitudinal
I was just about to ask about E85. Would you be allowed to e-test on any fuel?
Posted: Fri Aug 17, 2007 7:36 pm
by JShadzi
Toxcheap wrote:I'll be interested to know if it passes at 15.5. Den's A4 is at about 15 at idle and people still say "smells like its a little rich" LOL
Just tell them, "you can't tell tuning from smelling the tail pipe, we tune by looking at the plugs!"
Posted: Fri Aug 17, 2007 7:43 pm
by SEStone
Jonathan wrote:I was just about to ask about E85. Would you be allowed to e-test on any fuel?
I think it's called, 'playing stupid'.
What kind of bad connotation does the GP designation give?
Sam
Posted: Fri Aug 17, 2007 7:47 pm
by JShadzi
SeStone wrote:What kind of bad connotation does the GP designation give?
Sam
Hafta go to a "special" smog only station with more stringent standards, its a real pain in the ass, like "microscope status" :x
Posted: Fri Aug 17, 2007 9:16 pm
by SEStone
JShadzi wrote:SeStone wrote:What kind of bad connotation does the GP designation give?
Sam
Wow, that blows. Time to move to MN!
Sam
Posted: Fri Aug 17, 2007 9:45 pm
by 90_Koop
Try the E-85 Jim. Test only stations are a pain. They are state run so the "tip" is out and now they're gonne give your car a sigmoidoscopy.
Posted: Sat Aug 18, 2007 8:25 am
We'll see about that :wink:
Posted: Tue Aug 28, 2007 11:33 am
by 90_Koop
So what's the word Jim? Did the E85 and leaning the crap out of it work? Inquiring minds want to know. :-)
Posted: Wed Aug 29, 2007 5:03 pm
Just got another 2 month temp extension, passing emissions is on hold for a while.
Posted: Fri Sep 14, 2007 6:34 pm
by SEStone
I was dumpster diving on YouTube for AUdi vids, and found this:
http://youtube.com/watch?v=BuFbwtXwo5A& ... ed&search=
Camera man seems stunned :woowoo: :woowoo:
Sam
Posted: Sat Sep 15, 2007 2:15 am
by Hank
oh my, that is good.. you would think that the camera man had just seen a UFO land on the end of the track!!! He is trippin out!! Well that was a good 3 am laugh!!
Posted: Sat Sep 15, 2007 7:08 am
by Toxcheap
http://youtube.com/watch?v=gwyoJH9Tc9Mcool vid sam, and it led me to this vid which i thought was a good race too
Posted: Sun Sep 16, 2007 9:56 am
by 90_Koop
Posted: Tue Sep 18, 2007 5:05 pm
:-D
Posted: Tue Sep 18, 2007 5:47 pm
Anyone think this is NHRA legal?
Apparently I've decided to relocate the battery under the seat.
Attachment ( 9123 ) : P1010599.JPG
Posted: Tue Sep 18, 2007 5:52 pm
by Audilard
Of course it is! It's strapped down with a seat belt!!!!!
Posted: Tue Sep 18, 2007 5:56 pm
by oldsklaudidub
nope, i think NHRA states that you can not have the battery that close to the fule source. LMAO reminds me of my car.
Posted: Tue Sep 18, 2007 8:20 pm
by Hank
Pretty good Jimmy!! Love it..
Posted: Wed Sep 19, 2007 8:01 am
by a_CQ
LOL! Good one!
Posted: Mon Oct 08, 2007 6:04 pm
Well, somehow CA plates have made it onto the car :-D :wink:
I had the day off and since I had to spend the day sitting down, (F'd up my foot yesterday) I figured I might as well sit down in the car and get it tuned for this thick air.
It's strange, on the same tune from Denver the car has felt generally slower on boost, eventhough it's easily boosting to 30 psi. I attributed it to the extra back pressure on the turbo after limited logging. I saw 12.3:1 AFR and assumed everthing must be fine, untill I looked at my EGTs. They were tapping on 1600 F right after the turbo. Too much boost, probably not enough timing = too hot for me.
After todays session, I've backed the boost down to 26 psi max on pump gas, 11.5:1 AFR, and added about 5 degrees of advance. Man, what a difference, the car is running like a top! The lowest timing dips to is 15 degrees, and I only saw 1495 after running through 3rd and midway through 4th gear. Sweet. I may have room for even more timing, but I think I'll leave that for the dyno, whenever that may be.
The battery box is pretty much done, I just need to strap it down and then I can re-install the rear seat.
