Pete's Project Creep
Re: Pete's Project Creep
Postby DE80q » Sun Oct 29, 2017 12:58 pm
The 034 bracket is designed to use the OEM VR sensor. I made an adaptor to use a 12mm threaded body hall sensor in it's place. Elaw is working on a chip to use my sensors in place of the OEM flywheel sensors for MS. I believe it translates to a 34-1 trigger. As for the harmonics, mine has held up so far, on Jim's race 20v, and my MC1. The attached pic is the current setup I am running. Works really well with my MS3X.
Postby Noisy Cricket » Sun Oct 29, 2017 3:01 pm
I am confused about something - there's a box that divides the OEM 135 tooth flywheel trigger by three to make a virtual 45+1 wheel. That has nothing to do with addon trigger wheels.
MS3-Pro will read any kind of sensor you want, all config is done in software. And the circuitry for reading the sensor is way more robust than on the kit boards, you don't have to fart around trying to make a VR sensor read well at low and high RPM. Downside is they don't make the MS3-Pro anymore, they have something else that is like $200-300 more.
Fortunately, we have a leftover system that hasn't been installed yet and probably never will be since everyone who wants standalone seems to REALLY want XFI or BigStuff3 since that is what everyone else uses.
Anyway, how did you mount your wheel? When I put mine on, it sits so far back that I had to go Texas Sawzall Massacre on the timing cover, and I had to do some heavy relief of the oil pump housing for the weld bead to clear.
Pete, that rallycross guy
'06 Volvo S60 R (Swedish GTR)
Noisy Cricket
Postby DE80q » Sun Oct 29, 2017 3:10 pm
Mine I believe is one of the early 034 setups. The damper was machined on the backside to make it have clearance to the timing cover before the wheel was welded on.
Postby Noisy Cricket » Sun Oct 29, 2017 3:58 pm
I hear you, but I couldn't see how to do that without the wheel having a co-spatial event with the inner belt sheave. When I welded mine up, I set the wheel on thin washers. There's going to be relative motion between the outside of the damper and the inside, so I figured being in hard contact would be Bad. At any rate, even if I'd welded it right to the pulley section, it would still be in hard contact with the cover.
Very curious. And it occurs to me now that I never actually have had accessories on the engine yet. I should probably do that sooner than later.
Noisy Cricket
Postby DE80q » Sun Oct 29, 2017 4:46 pm
In the first pic, you can see that the trigger wheel is pretty much tight to the damper wheel. I thought I had a better pic of this, but can't seem to find it. The second pic shows the trigger wheel is TIG welded to the inner hub portion. It's also in line with where the original back of the pulley ring was.
Postby Noisy Cricket » Fri Nov 17, 2017 6:56 pm
Noisy Cricket
Postby Noisy Cricket » Mon Dec 24, 2018 9:09 am
Pete last seen mumbling about getting more engine setback with a low mount rack, separate front diff, and a Skyline GT-R transmission...
Noisy Cricket
Postby Noisy Cricket » Sun Apr 07, 2019 9:18 am
A conversation with a non-Audi speaking friend of mine brought up a very interesting engine management possibility, that will be one heck of a lot less expensive and more robust than any kind of standalone. Looks like it will work just fine with the existing sensors.
Combine that with a new job and better prospects, and I may actually make some headway on this car again. But I may want to pull the engine back out and pull the head to make sure everything is still okay in there.
Noisy Cricket
Postby PRY4SNO » Sun Apr 07, 2019 3:56 pm
Congrats on the job upgrade! But don't be so stingy on these new engine management details!
|| Spare parts for sale
Postby Noisy Cricket » Sun Apr 07, 2019 4:37 pm
I'll be stingy because right now it is just an idea. I'll know more when I can beg/borrow/buy a 2 channel lab scope and measure some things. Right now, I have a lot of accrued debt from unemployment that I need to pay down before I can think about spending more money on things.
Noisy Cricket
Postby Noisy Cricket » Sun Apr 14, 2019 12:30 am
2-channel Picoscope acquired.
Noisy Cricket
Previous
Return to Projects
Users browsing this forum: No registered users and 7 guests
cron
