PRY4SNO wrote:Any reason you're using a plug range colder with the 7s on spring pressure? What's not ideal with the BKR6E to not use them?
audifreakjim wrote:Here are the things to check when you have trigger errors
-swap sensors
-swap sensor wires around. I know vems can be picky about this
-adjust sensor depth
-make sure the sensor wires are well shielded
Afterthought wrote:G28 is not new but I never hear of them failing (maybe they do?)
DE80q wrote:I know your running VEMS, not MS like I am, but try adding a heavy ground cable from the block to the chassis, as well as the transmission to the chassis. This cleaned up guite a bit of odd issues I had with my setup.
audifreakjim wrote:So you are running Audi Trigger? I’m not a big fan of that, seems pretty prone to errors. Do you have an oscilloscope for your laptop you can use to make sure all of the pins and sensors are lined up? I was lost trying to get a car running on vems until I ordered one.
carl wrote:I wouldn't move the coil grounds to body, old oem wires sounds like a good idea, shot in the dark but maybe lower ignition dwell a little.
If the sensor is aftermarket it could be giving you issues, I've tried one of those and the spikes were lower than oem on the scope, so pretty useless.
Like everybody else said, try getting them closer, pretty sure that's the problem.
Could also be some chipped tooth on your ringear.
I've had issues with hall signal window being too much at the edge, I'd get some random missed triggers due to belt slop. Doesn't seem to be your case but worth a look.
Another idea, unplug the alternator for a quick test, could be a noise source too.
Unlikely but have you talked to Marc about the reversed pins on sensor, just in case?
varia wrote:
Last resort a 60-2 on the rear
85oceanic wrote:I hate dealing with trigger errors! I run the Audi trigger with VEMS in my 4k. I used to have severe issues with it at times and ultimately didn't get them fixed until I purchased a harness from EFI express along with switching out of the NGK to Bosch plugs. Before, I ran the NGKs with a modified URS4 engine harness to VEMS Econoseal.
Afterthought wrote: If I move them I’d have to verify that they are close but not hitting .
Users browsing this forum: No registered users and 11 guests
