TCombs UrS4, Coolant leak.
Re: TCombs UrS4, Possible misfire.
Postby morris400 » Sun Mar 31, 2019 12:57 am
I would not say it's a "performance" upgrade.
I'd say it's an upgrade from the side of , when one dies a quick run to VW and you can get one for $30 rather then #100+
And then wait for shipping.
They also offer a nicer look to the engine bay as well, a little modern touch to the old school look.
I'd advise running with the 20VT cover off, the 2.0 coils make some heat and can be damaged if not allowed to vent.
TCombs wrote:
PRY4SNO wrote:From my understanding any of the VAG COP will work. I've used a couple different variations with no ill effects.
It might have just been a sales tactic but even on 034’s website they say that the 2.0 coils aren’t a “performance upgrade” and they rec using the HO coils. But I thought I remember a ton of you guys running the 2.0 coils on higher end horse power UrS models?
1994 UrS4 - K24 7400 EFI Express tuned
morris400
Postby TCombs » Fri Jun 14, 2019 9:39 am
Has anyone replaced their oil filter housing gasket that EFI sells? The smallish green one? Think I might have a small leak from there was wondering if its as straight forward as it looks, or if there is something I need to worry about.
Also on a random note, if I were to add A/C back into my car is there anything I should be on the look out for? I only took out my condenser and the massive line going to it. Other than that everything is still in the car.
1994 Audi URS4 Emerald Green
2010 Audi A5 Meteor Gray
2006 Yamaha FZ6
TCombs
Postby MikeB25 » Fri Jun 14, 2019 10:48 am
TCombs wrote:Also on a random note, if I were to add A/C back into my car is there anything I should be on the look out for? I only took out my condenser and the massive line going to it. Other than that everything is still in the car.
Depending how long it's been open you might want to flush it both ways. Be sure to pull a vacuum on the whole system for awhile before recharging it. If you need a condenser I think I have one that you can have.
'93 UrS4 (organ donor)
'08 Q7 (lemon)
'12 S4 (Stage 1...for now)
MikeB25
Re: TCombs UrS4, Adding A/C back?
Postby PRY4SNO » Fri Jun 14, 2019 11:47 am
In addition to Mike's (good) advice have it done at a shop. I'm all for DIY but the quality of the equipment and refrigerant is higher at a reputable shop than the cans you can buy at your FLAPS.
|| Spare parts for sale
Postby ringbearer » Fri Jun 14, 2019 3:44 pm
Definitely get a new receiver drier
Postby TCombs » Fri Jun 14, 2019 8:29 pm
PRY4SNO wrote:In addition to Mike's (good) advice have it done at a shop. I'm all for DIY but the quality of the equipment and refrigerant is higher at a reputable shop than the cans you can buy at your FLAPS.
Thanks for the info. I currently work at a shop. Factory Audi A/C machine. Pulls vacuum for how ever long you want, I usually do 15 min and a leak test for 15min as well.
2006 Yamaha FZ6
TCombs
Postby TCombs » Fri Jun 14, 2019 8:31 pm
I might take you up on that. However my old one was cracked, thus I tossed it in the bin. I would prefer not to have to go down that route a second time. So I was looking at getting a new one. I will get a new drier for sure. They are pretty cheap. for a new Nissens one.
2006 Yamaha FZ6
TCombs
Postby ringbearer » Sat Jun 15, 2019 10:07 am
An AC nerd friend of mine swears by the variable orifices over the fixed. I have one in mine and it was cold until everything leaked out! Good luck keeping cool, I’m a big fan of working AC. It works in all my other cars and house, lol.
Postby PRY4SNO » Sun Jun 16, 2019 1:40 pm
Buyer beware with Nissens. You get what you pay for with them, oftentimes less.
I'd take a solid used core any day over Nissens, personally.
Postby TCombs » Sun Jun 16, 2019 6:12 pm
PRY4SNO wrote:Buyer beware with Nissens. You get what you pay for with them, oftentimes less.
I don’t remember exactly, but I’m pretty sure the one I took out was Nissens, what was the factory brand? Behr or someone else?
Well I will probably go with that new Nissan direr just because its new. But I guess I’ll try and track down a core.
Mike, is that condenser in good shape?
2006 Yamaha FZ6
TCombs
Postby MikeB25 » Sun Jun 16, 2019 9:51 pm
It's in my trailer but I'll grab it tomorrow and take a look.
'08 Q7 (lemon)
MikeB25
Postby TCombs » Thu Jun 20, 2019 10:27 pm
I am trying to add photos but something is not working properly. Is any one else having an issue as well?
2006 Yamaha FZ6
TCombs
Postby jbrentd » Fri Jun 21, 2019 8:06 am
I haven't had any issues. Are you trying to add them via the Tapatalk app, TPP attachments or [img] tags? I use the latter, hosted on imgur.
jbrentd
Postby TCombs » Sat Jun 22, 2019 4:25 pm
Trying to upload some pictures again. I got some work done on my fender. Sanded it down a bit and painted it. Turned out pretty dang well for only using a rattle can.
2006 Yamaha FZ6
TCombs
Postby TCombs » Sat Jun 22, 2019 4:32 pm
jbrentd wrote:I haven't had any issues. Are you trying to add them via the Tapatalk app, TPP attachments or [img] tags? I use the latter, hosted on imgur.
To be honest, I am not sure. I don't use the app. I just go down to add file and pick the picture from a folder and then hit add the file and it uploads. Never had an issue until now.
2006 Yamaha FZ6
TCombs
Postby TCombs » Mon Jun 24, 2019 3:29 pm
I’ll try it in sections.
2006 Yamaha FZ6
TCombs
Postby TCombs » Mon Jun 24, 2019 3:31 pm
Well I’m having issues. They are on Instagram @ eurocentraloregon.
2006 Yamaha FZ6
TCombs
Postby TCombs » Sat Jul 13, 2019 1:09 pm
2006 Yamaha FZ6
TCombs
Postby TCombs » Sat Jul 13, 2019 1:21 pm
2006 Yamaha FZ6
TCombs
Postby TCombs » Sat Jul 13, 2019 1:48 pm
Finally got around to getting my door cards done. Good buddy of mine help me out. After 24 years the beehive adhesive just wasnt doing it job anymore. Took the old vinyl off and used it as a template. Used 1/8" foam and 100% UV rated, aircraft leather. Scrapped the old stuff off, using a combo of plastic razor blades, sand paper, scotch brite pads (red/purple) and aircraft cleaner used to take carbon off of planes. My buddy did some great work, for not being able to wrap them around and only being able to tuck them into the pockets. I think the black really works nice with the tone of the dash and the carbon fiber. Really am a fan.
2006 Yamaha FZ6
TCombs
Re: TCombs UrS4, Pic heavy (Fender and Door cards)
Postby themagellan » Sat Jul 13, 2019 9:58 pm
Looks great and good job with the picture documentation - this car is steadily turning into a real gem - nice work!
Postby TCombs » Mon Sep 23, 2019 4:13 pm
Got my windshield replaced and threw some paint on the hood. Learned a lot by painting the hood. It no where near perfect or even good, but its protected and looks better than it did.
2006 Yamaha FZ6
TCombs
Postby TCombs » Mon Oct 14, 2019 9:47 am
Has anyone had a coolant leak possibly coming from the cool cap. I seem to be losing coolant and have dried coolant around the reservoir, even on the hood strut when I looked yesterday, but it doesn't look like its coming from a hose.
2006 Yamaha FZ6
TCombs
Re: TCombs UrS4, Coolant leak.
Postby Afterthought » Mon Oct 14, 2019 11:50 am
TCombs wrote:Has anyone had a coolant leak possibly coming from the cool cap. I seem to be losing coolant and have dried coolant around the reservoir, even on the hood strut when I looked yesterday, but it doesn't look like its coming from a hose.
Its possible yeah , I have had it due to either the cap leaking or the rubber gasket underneath leaking . Not sure if the pressure device inside fails over time or what .
that cap does fit a ton of cars and should be easy to pick one up
Postby TCombs » Mon Oct 14, 2019 1:25 pm
Awesome. Ill get a new one and start with that.
As a side note, what is your guys' average MPG? City or highway?
I moved an my commute went from about 3miles round trip to around 35ish, some days 60-70 if I have to go back multiple times. I am getting 20.0 mpg currently. 65-70mph.
2006 Yamaha FZ6
TCombs
Previous
Return to Projects
Users browsing this forum: Google [Bot] and 7 guests
