eS2 evolution
Re: eS2 evolution
Postby FFF » Sat Jan 05, 2019 7:01 pm
Pulled the engine out of the crate, starting to bolt a few things on before dropping it in.
FFF
Re: eS2 evolution
Postby morris400 » Sat Jan 05, 2019 8:51 pm
Very nice!
1994 UrS4 - K24 7400 EFI Express tuned
morris400
Re: eS2 evolution
Postby Afterthought » Sat Jan 05, 2019 9:35 pm
Nothing would make me happier than to have one my projects with the engine finished in a crate and the body/paint done , like what you’re doing . Just installing and fabbing. You’ve got the right idea !
Which turbo is that ?
Re: eS2 evolution
Postby jbrentd » Sat Jan 05, 2019 11:02 pm
Beautiful engine! I really enjoy your updates.
Question: does the orientation of the two oil pressure sensors on the drivers side matter? Mine are the reverse of how your are installed.
jbrentd
eS2 evolution
Postby Afterthought » Sun Jan 06, 2019 12:16 am
jbrentd wrote:Beautiful engine! I really enjoy your updates.
I’m not 100% sure if this is true in the 7A too, but i think it is . You can check my theory by looking at your old engine you pulled.
I think that you can’t switch the sensors unless one is threaded into an adapter.
In the AAN you have actually two different size threads , one hole is m10 and one is m16x1.5 . The bottom / larger hole has a check valve inside . Some of the urS cars (either urs4 or urs6? ) came without a gauge so the pressure sender( bottom hole ) is plugged with a bolt . I used it for a gauge. The larger port with the check valve sees the pressure that is going to your head .
If you ever need or want to change your gauge to an auto meter or different brand all you need is a metric to auto meter gauge adapter - I think it’s PN 2268.
My engines both have gauge sender on the bottom and pressure switch on top .
Re: eS2 evolution
Postby FFF » Sun Jan 06, 2019 12:35 am
Afterthought wrote:Nothing would make me happier than to have one my projects with the engine finished in a crate and the body/paint done , like what you’re doing . Just installing and fabbing. You’ve got the right idea !
Well you know how long I’ve been gathering!! And yes, having a clean start is way easier - one of the primary reasons I didn’t do a URQ (I couldn’t find anything in my price range with a good body) - I just don’t have the time (or skills) to dive into major body work... I can do basic stuff, good at spraying but am way to picky with no budget for paint given everything else I wanted to do on this project.
It’s a Xona Rotor 8267, the 9567 has the same hot side so theoretically I can upgrade to that if I “need” some more power without buying the entire Turbo. Fuel system is being built so that I can do anything with the engine without having issues even on E85 (which we just got in the city so I may actually do a map for that as well).
The center section is very nicely done -
http://www.xonarotor.com/products/xrtur ... 153-xr8267
FFF
Re: eS2 evolution
Postby FFF » Sun Jan 06, 2019 12:43 am
I didn’t know that thank you (I assumed they could be reversed because the 3b in the car had them reversed, my built motor was an AAN so I left the sensors where they were.
You can zoom in and see them in this picture.
FFF
Re: eS2 evolution
Postby PRY4SNO » Sun Jan 06, 2019 12:57 am
Om nom nom, crate engine :drool:
|| Spare parts for sale
Re: eS2 evolution
Postby ringbearer » Mon Jan 07, 2019 8:05 pm
As previous stated, awesome build one of my favorites! Keep it up :)
Re: eS2 evolution
Postby FFF » Mon Jan 07, 2019 10:37 pm
ringbearer wrote:As previous stated, awesome build one of my favorites! Keep it up :)
Thanks!
FFF
Re: eS2 evolution
Postby FFF » Sun Jan 13, 2019 6:17 pm
Some good progress this weekend.
I keep thinking that I am close to done cleaning, then I find more grimy parts...
Then a couple of coats of paint slapped on... meanwhile still getting other stuff ready.
Tilton twin disc, 034 flywheel and throw out bearing..
I think that the factory exhaust manifold will do a good job of heat control... all the Iroz goodness gets hidden though!
Still needs to be cleaned up but function over fashion...
Some Iabed Ind bits... thanks to Issam for the development on these old engines!
Doing port injection for water/meth... measure and verified a lot before drilling!!! Needed some help holding while drilling so went to the boys shop...
Also needed to drill and re tap throttle body as my bracket is held by m6 bolts...
Don’t even know what these are called but it is a socket set that taps fit into, borrowed my sons. I won’t ever do another tap without using them. So much more control with them. You can see it on top of the tap.
Good clearance around everything, I’m pleased with the outcome.
FFF
Re: eS2 evolution
Postby DE80q » Sun Jan 13, 2019 6:29 pm
Very nice work! I kind of wish I had taken the time to clean everything the way you are.
Oh, and they are called "tap sockets". I use them regularly at work.
Re: eS2 evolution
Postby Afterthought » Sun Jan 13, 2019 7:00 pm
Nice. im gonna look into that socket set .
I get stressed out drilling into anything
Re: eS2 evolution
Postby DE80q » Sun Jan 13, 2019 7:09 pm
Lisle tools makes a nice set that doesn't cost too much.
Re: eS2 evolution
Postby jbrentd » Sun Jan 13, 2019 7:56 pm
That sockets makes it a little less stressful tapping into that nice IM. I need to find some of those too. Nice work.
jbrentd
Re: eS2 evolution
Postby FFF » Sun Jan 13, 2019 8:57 pm
And you can never have too many tools, regardless of what my wife says!
FFF
Re: eS2 evolution
Postby MikeB25 » Sun Jan 13, 2019 10:19 pm
Very inspirational (and humbling) project!
How does the Iabed breather puck thing mount to the block?
'93 UrS4 (organ donor)
'08 Q7 (lemon)
'12 S4 (Stage 1...for now)
MikeB25
Re: eS2 evolution
Postby FFF » Sun Jan 13, 2019 10:23 pm
Thanks - collected parts for several years!!
It is the same as the factory unit - it just “pressed” in, some gentle tapping with a mallet to set it in place.
FFF
Re: eS2 evolution
Postby FFF » Sat Jan 26, 2019 7:47 pm
Went to start putting my flywheel on and hit a wall...
The crankshaft center that the flywheel goes over is .006 inches larger than the flywheel. I would expect tight but not certain if that is too tight?
Thoughts?
FFF
Re: eS2 evolution
Postby DE80q » Sat Jan 26, 2019 8:47 pm
That's a significant screw up. I believe they are actually supposed to be around .002" slip not .006 press! It's going to have to be set up in a lathe and opened up a little.
Re: eS2 evolution
Postby FFF » Sat Jan 26, 2019 10:32 pm
DE80q wrote:That's a significant screw up. I believe they are actually supposed to be around .002" slip not .006 press! It's going to have to be set up in a lathe and opened up a little.
Yes that’s more in line with what I was thinking... pain in the rear...
FFF
Re: eS2 evolution
Postby FFF » Sat Feb 02, 2019 5:20 pm
Not sure if anyone has the part number handy or not. Went to put my speed sensor in the 01E and it is to long... anyone know the shorter sensor part number?
I’ve found a couple of numbers but would prefer to confirm which one I need.
FFF
Re: eS2 evolution
Postby FFF » Mon Feb 11, 2019 8:05 pm
This is the one out of my other 01e, way to long.
Looks like about 1/2 as long for the sensor...
FFF
Re: eS2 evolution
Postby FFF » Mon Feb 11, 2019 8:26 pm
Working on getting some engine plumbing done...
If you even think that you may continue doing hose construction I highly recommend having Kool tools AN assembly kit. I likely haven’t pulled these out in at least a couple of years but assembly is so much easier...
Little extra hose but I think I’ll route around a little to avoid going so close to the header.
FFF
Re: eS2 evolution
Postby PRY4SNO » Mon Feb 11, 2019 9:29 pm
Not going to use a fibreglass sleeve on the turbo lines?
PreviousNext
Return to Projects
Users browsing this forum: Google [Bot] and 10 guests
cron
