Andy's 91' 80q
Re: Andy's 91' 80q
Postby rennenmsports » Sun Jul 18, 2021 11:02 pm
My new air filter box mold. Making it out of high quality fiberglass. But I think everyone cuts them out. If your interested in one let me know
rennenmsports
Re: Andy's 91' 80q
Postby PRY4SNO » Mon Jul 19, 2021 8:11 pm
Oh boy, that's a nice tactic. Adapting the Sport quattro concept has been on my mind a long while.
Is there ducting into the scuttle panel / rain tray?
Velocity stack?
Re: Andy's 91' 80q
Postby rennenmsports » Mon Jul 19, 2021 8:42 pm
Thanks bud! I made a plate with a 3 inch tube to cover the hole in the bottom of the battery tray. Then since I’m not running ac I attached a 3 inch silicone hose pushed through the firewall to draw air from inside the cabin. Found spectre 4 inch duct flanges. One on the inside for a 4 inch turbo gaurd air filter. There is a few slots going into the rain tray from factory making up for the 1 inch difference. There is room for a velocity stack as well.
rennenmsports
Re: Andy's 91' 80q
Postby rennenmsports » Mon Jul 19, 2021 8:47 pm
rennenmsports
Re: Andy's 91' 80q
Postby rennenmsports » Tue Aug 03, 2021 4:56 pm
The mold is coming along nicely. I’m still debating on what to make the real one out of. A lot of heat will be generated under it.
rennenmsports
Re: Andy's 91' 80q
Postby PRY4SNO » Sun Aug 22, 2021 8:14 pm
http://www.extremeheatprotection.com/hi ... satin.html
Something like this looks alright... I'd guess basically any fibreglass rated for high heat will do the job nicely. If you were so inclined you could use gold foil to reflect heat away from the airbox, and/or a thin OEM-like aluminum shield as well.
Re: Andy's 91' 80q
Postby rennenmsports » Fri Sep 10, 2021 8:36 pm
That looks good! I’ll look into it further. I have a bunch of different things on the car pending. I’m running aluminum fuel line from the front midway up the firewall to under the back seat right now. Almost done. But need about 5 ptfe lined flexible hoses to finish the fuel system to hopefully be able to idle it on its own now. I’m getting there. Got everything mounted. Just need to plumb everything up
rennenmsports
Re: Andy's 91' 80q
Postby rennenmsports » Sun Oct 31, 2021 10:07 am
Finally got the plug made. I’m about to make the piece that actually goes onto the car. It’s going to have a boost logic universal 4” air filter
rennenmsports
Re: Andy's 91' 80q
Postby rennenmsports » Mon Nov 01, 2021 2:28 pm
rennenmsports
Re: Andy's 91' 80q
Postby rennenmsports » Mon Nov 01, 2021 6:04 pm
It fits :) you can see the flange on the filter inside the first layer of glass
rennenmsports
Re: Andy's 91' 80q
Postby rennenmsports » Thu Nov 04, 2021 7:39 pm
rennenmsports
Re: Andy's 91' 80q
Postby rennenmsports » Sat Nov 06, 2021 2:52 pm
Now that I know everything will work out. It’s on to the next one made out of something I found that can handle up to 1100 degrees F and make it thicker.
rennenmsports
Previous
Return to Projects
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 16 guests
