speeding-g60
Re: Aarons Drag CQ: 7-4 vids up
Post by speeding-g60 »
still need to slip the clutch out on launching. if you put too small a pill in it you will get too much slip. its different. i think 1.67 was my best yesterday....
speeding-g60
timing belt tensioner loosened up, and it appears to have advanced the crank ~4-5 teeth.
we will see in a few hours if there is damage to valves. lets hope not.
but i have a fully built head with big hydro cams sitting here in wait, so i can get it running QUICK and go finish the licensing.
death 4kqt
Re: Aarons Drag CQ: 7-7 uh-oh....
Post by death 4kqt »
oh man aaron! hoping for the best!!
RSCoupe
Post by RSCoupe »
It'll be fine! :-)
*fingers crossed*
Mark Siggelkow
'90 CQ-R - NASA GTS-4
'12 TT-RS (Wife's DD)
'00 A4 1.8TQ (My DD)
'62 356B (vintage racer)
death 4kqt
i think so too, thats not TOO much slip....
speeding-g60
yeah, and that it went forward with the crank. remember, i took vids of the cyls and clearances.... and there is a lil bit of room in there. we will be doing this again today. and then compression tests after we re-time the TB.... and hope.
looking at the logs, and talking with Kevin, the car was "lazy" up top, not as responsive, and not as much boost either. that was the last pull. so it could have been off a tooth or two while running.
then loaded a different map, drove to staging lane, shut off to wait. my turn comes up, no start. we cranked it for a good deal of time, wouldnt catch or fire. leave fuel pump off and it would sputter like it wanted to catch but never did.
i hope its ok....
fingers crossed!!!
itll be fine, youve paid some hard dues in the last year and change
Toxcheap
Post by Toxcheap »
<fingers crossed>
speeding-g60
i took a quick peek with the 'scope.... i didnt see any contact and valves look like they close. have really good valve reliefs in the piston tops.
goin back shortly to get more in depth, with compression test and leakdown.
keep you'ns updated. i got everything i have in pairs crossed ;)
death 4kqt
speeding-g60 wrote: i got everything i have in pairs crossed ;)
balls crossed? I heard its hard to do, but worth the effort!
death 4kqt wrote:[/quote]
balls crossed? I heard its hard to do, but worth the effort![/quote]
hhahahaahhahahaahhahahahahahahahahahahahahahahahaha
speeding-g60
soooooo. a SOLID 5 teeth retarded the cam gear is compared to TDC on the crank gear.
compression test done. set timing back to spec, completely cold motor here.
145 - 145 - 145 - 145. good news there.
leakdown test.
12% - 10% - 7% - 6% leakdown. again, completely cold.
i find these findings in my favor, luck must have played a large part in this.
at any rate, i am happy not to have killed the thing.
new TB gear coming, Joey talked to Pete and they will custom make one for me to double pin it to the crank. getting a new head gasket just cuz, its cheap and good to have on hand.
YAY!!!!!
Re: Aarons Drag CQ: 7-7 test results......
Nice!!! I knew it. So what...cam gear slipped?
speeding-g60
the TB tensioner came loose i think from heat. i "think" it may have heated up and relaxed the nylon insert in the nylock nut. no more of that here. steel locknut now.
anyways, loose tensioner allowed belt to let some slip go by. just my theory. but it works for me. all else is tight and good to go.
Oh I see. So it slipped over some teeth because the tensioner allowed it to be loose.
Rocco16V
Post by Rocco16V »
:woowoo:
speeding-g60
and an update; put the TB gear back on, timed it, FIRES RIGHT UP! runs great!!
Toxcheap
Post by Toxcheap »
sweet, sigh of relief!
fasterthenrs2
Post by fasterthenrs2 »
Awesome dude woo, loctite everything under TB with blue stuff
speeding-g60
yup. finally a break. just lets us know to add the TB to our between rounds regime of inspection to the car. its alright, just one more thing is all.
speeding-g60
and yeah, Janis, we are doing it ALL with Blue Loctite. f-this loosening up crap.
death 4kqt
yes!!
YES!! finally some good luck!
wooooooh oooooooo phew so relieved
