PM me an address and I'll hook you up with the correct clampderracuda wrote:yeah, i couldn't find any clamps small enough for now, and i need like 20 of themzip ties will suffice for now. i'm not going to run 30-40psi
it held a few hoses on my white car for a few years with no issues.
Corey
derracuda
i made a last minute decision to bite the bullet and make some irreversable changes
you know how when you get the bug to do something for really... no good reason at all? that's pretty much what i did. i've had this cool idea of using a 5kt dash cluster and dash housing to replicate the Sport Quattro dash. the benefits are multi-fold. #1. i get a 160mph speedo. #2. i get the nice backlit gauges. #.3 it has the neat little door open indicator light. #4. it has a higher redline in the tach #5. it has a speedo that goes to 160 mph. and finally #6. it resemlbes a SQ dash for cryin out loud!
it all went down like this...
start off with removing a 5kt dash and cut it to more useable sizes and test fit over the existing dash
then remove the stock 4kq steering column as it's way wrong
stupid non-tamper bolts! i'll show you!
now, you'll need the 5kt steering column for the key and the stalk mounted switches. if you haven't noticed by now, the 5kt dash pod has no provisions for the headlight switches and stuff. so why not use the column mounted
you have to remove the lock ring and spring on the column
and lay everything out like this (it looks more professional that way
then once the 4kq column is out of the way, hold the new column up in place to get a feel
you'll also have to cut the cluster dog house down quite a bit
it's a pretty good fit to the 4kq's dash contour
that's a spare test dash for seeing how much i'd have to cut before digging too far into the job
stock dash in..
stock dash out..
you can see the difference in mounting here. the 4kq has two bolts that hold it up from the bottom
the 5kt steering column has cross bolts
a lovely surprise though... the width is about perfect for the 5kt piece
a reminder of where it was destined 8)
here goes nothin'!!
no turning back now
oooooh, that fits nice 8)
more test fitting
there is some clearancing needed for the back of the cluster. i'm working on a reinforcement for it, but initially it's proven to be pretty stinkin' stout
holes must be drilled
bolts in place
this is the bracket for supporting the cluster
stock dash one last time
i used the stock 4kq holes for holding the dog house in place, just put grommets in it
and made brackets for which to hold the upper side of the dog house in place
i also had to trim into the back of the dash for clearance on the wiring plugs for the cluster
getting closer
i had to make a couple brackets for the outer portion of the cluster brace. i'll further reinforce them with a piece under the column that's tied to the column itself
here is it mostly finished.
and the last thing i did today was hook up the new ignition switch setup. the plug is different, but the wiring is the same and the terminals pop out and plug into the 5kt plug 8)
i'm not entirely finished. i still have to wire up the lighting, turn signals, cruise control, and a couple other things. but overall i'm very pleased with it
i also have to do some either foam or bondo work on the bottom section of the cluster housing where it meets the dash and then recover the whole housing so it's mucho nice 8)
stock dash in..
stock dash out..
here goes nothin'!!
no turning back now
more test fitting
bolts in place
getting closer
Ive always loved the 5kt clusters over the 4k ones so this is a pretty interesting idea.
Jason M. had put a 7A and pretty much a slew of B3 stuff into his former 4kq did something similar with the B3 cluster, came out pretty snazzy.
Clouse
s2 on the way
derracuda
derracuda
oh, btw guys... i forgot the mention the last benefit to this swap.... with the later 200 style turn signal combo switch... i can now run one of these..
we have a customer car here at the shop that has one.... man, it's nice! i feel special just touching it as the leather is really soft and the suede is a great touch.
quattrostyle
derracuda
Wizard-of-OD
derracuda
the stock 4kq dash pod isn't molded into the dash... it just sits on top. i'm going to work the sides with probably some bondo or something to give it the right shape, and then recover the whole housing.Wizard-of-OD wrote:Looking good Derek but how are you going to mold the 2 into 1?Wouldnt it have been better to just try and fit the stock 5000 dash in the 4000's place?
it was be kind of the wrong way to go with putting the 5kt cluster in the 4kq housing as it's not even close to designed for it.
seiche
Very nice. I like that you used the 200 combination switch. I thought of doing this swap, but couldn't think of what to do for the light switches. The 5k combi switches are junk, and I never thought of using the 200 stuff. Great idea! Can't wait to see how it turn out. Bet there will be more of these happening. Personally, I'd like to do it with a B5/C5 cluster. FWIW, you can code them to work with a five cylinder engine. BTDT...
MilesR
derracuda
man, i dunno. i think i'll be happy if i can get everything ironed out and working like it's supposed to for a good long whileseiche wrote:Very nice. I like that you used the 200 combination switch. I thought of doing this swap, but couldn't think of what to do for the light switches. The 5k combi switches are junk, and I never thought of using the 200 stuff. Great idea! Can't wait to see how it turn out. Bet there will be more of these happening. Personally, I'd like to do it with a B5/C5 cluster. FWIW, you can code them to work with a five cylinder engine. BTDT...
and Miles... man, Rich's car is sooo nice. i think the steering wheel fits it quite nicely
Wizard-of-OD
derracuda
HT Motorsport
mhb_1323
