derracuda
haha, you guys are funny
one little last update from last week while i was at the shop. the struts i have on the car now are built wrong. i relocate the steering arm too low and it causes bump steer, so.. i took a spare set i have, cut the steering arms off, dissassembled them for the the little metal plug with the tapered bit in it where the tie rod goes into it... and made up new, 1" shorter steering arms( for quicker turning ratio), rotated in just enough to be even with the tube itself, and the arm is located right where the stock one was, so all the stock geometries will be retained. i never had bump steer in my white car, and i never moved the steering arms on it.. so this was my solution.
removing the stock strut proved VERY labor intensive. it was quite corroded in place
good thing i was planning on keeping the steering arm!
the new steering arms...
tapered tie rod insert (not fun to remove btw)
here you can see the difference in steering arm length..
and this.. i am proud of... check out that weld bead!! i had to look at it for a minute when i was done and admire this stroke of luck!
i didn't have time to finish the second strut before we left CA, so this upgrade will have to wait a couple weeks yet. this one should be fun though since i won't have to do a double take on some of the tighter turns i'm used to driving on
all i need to do now is get the camber mount thing figured out with GC and then i'll be really having a ball!
Lt. Sarge
Wizard-of-OD
Jretal
inquiring minds would like to know.......
thickness of material used? did you keep the same angle of steering arm in relation to stock (when looking from top down w/ the assembly standing upright as if in the car)... and of course, wanna cut 2 more of those puppies for a fella?
looks good though, buddy. I'm guessing you just ground off the old steering arm w/ an angle grinder?
derracuda
i think the plate i used was .5" it's four times as thick as the metal used in the stock arms, just not boxed like the factory arms. it should be plenty strong though, even more so with the brace. i'm not worried about it
i did not keep the same angle... as i mentioned, they are rotated in just a bit, so that they don't stick out any further than the strut tube.... so in effect, i can fit a tire up to the strut tube, and the tierod/steering arm won't make contact. and with this set up i cleared 235's no prob. stock body work 8)
as for cutting them out... took me at least and hour to do the both. the hole saw i used isn't the exact size, so there there's a considerable amount of time using an air grinder and a carbide bit carefull enlarging the hole to fit it over the strut.
and yes, i just used a grinder to remove the stock steering arm.... do take your time and be careful not to cut into the tube... much. i get it kinda close, then take the hammer and start whacking the arm, tearing the welds. worked great on both struts.
HT Motorsport
200 Avant
Derek,
Great sewing skills.. BTW.. you may want to see if you know of anyone with a walking foot machine for the heavier materials. when you tackle your seats see if you can find a double needle machine for high stress seams.
Good luck..
I'm glad to see ya back on it.. I miss the regular updates..
Cheers...
Good luck..
Cheers...
The suede bits look good!! Were they in the car this weekend? I didn't notice... Guess maybe that syas something for the quality, looked factory.
Thanks for the long ride, the zermatt car drives nice and pulls decently for only driving at 7/10s. If something ever happens to my 200 it's 20v heart will definitely be living on in a lighter chassis..
derracuda
timmmy wrote:Nice work as usual man....I like it
Plus I had not thought about shortening the arms quickening the ratio, makes perfect sense as long as you dont mind 5 point turns instead of 3, and how often do we do those? Will you need to shorten the link rods to the rack a little?
H
my plan is to make stops for the rack so i can't over turn the wheels. why wouldn't i be able to make a 3 point turn? the car will steer just as sharp...and sharper
Jretal
Very cool. Guess it's time to start digging around and find myself some scrap 1/2" plate around work maybe :-P I'm sure we have some laying around not getting used!derracuda wrote:i think the plate i used was .5" it's four times as thick as the metal used in the stock arms, just not boxed like the factory arms. it should be plenty strong though, even more so with the brace. i'm not worried about it
dah, I missed that part... thanks!i did not keep the same angle... as i mentioned, they are rotated in just a bit, so that they don't stick out any further than the strut tube.... so in effect, i can fit a tire up to the strut tube, and the tierod/steering arm won't make contact. and with this set up i cleared 235's no prob. stock body work 8)
sounds good, thanks for the tips! Time to start hunting around. I was planning on doing something similar as well, but just cutting the strut tube under the steering arm and clocking the arm back a little bit and rewelding. Was kind of worried about the structural integrity of the tube though, which made me hesitant about doing that, though.as for cutting them out... took me at least and hour to do the both. the hole saw i used isn't the exact size, so there there's a considerable amount of time using an air grinder and a carbide bit carefull enlarging the hole to fit it over the strut.
Thanks for the tips, though! Much appreciated!
a_CQ
derracuda
i thought about the holes... but honestly, they aren't that heavy.
here's some vids and pics i took today of a drive i went on. this is one of my many roads to enjoy. as you can tell, the car is pretty quiet inside. the main noises are the old tires which create a lot of the white noise in the background, and then there's the drivers seat.... :frustrated: sounds like a grandpa's rocking chair
sorry for the auto leveling of the camera, it seems when i go around corners, my hand seems to tilt
. also i pretty much drove it in 4th gear the whole time.
part 1
http://myspacetv.com/index.cfm?fuseacti ... d=22092719 ... d=22092719
part 2
http://myspacetv.com/index.cfm?fuseacti ... d=22082306 ... d=22082306
part 3
http://myspacetv.com/index.cfm?fuseacti ... d=22095243 ... d=22095243
part4
http://myspacetv.com/index.cfm?fuseacti ... d=22097501 ... d=22097501
the bridge is a giant grate!
part 1
part 2
part 3
part4
WAUG0806
D3R3K - car looks great, I love those rims on it... perfect for the project OE look.
Assuming you have 15 x 7.5's with 225/50... stance and offset look sweet!
Nice to see you on the road again.... 8) love to see pics of our old cars in the garage being rebuilt/modded/fixed but better to get happy reports from the road in the nice scenery, or better yet, the track!
Shame you did not whittle out a 3rd steering arm prototype, somebody coulda found a cnc waterjet to blast out 12 pairs so we could all be running D3R3K Struts! Guess we should wait for you to figure out the stops...
How does the ratio feel... did it make the car twitchy or just right? I was guessing 20-25% quicker just by shortening arms 20-25%.... :? :?
