07k main bearings
07k main bearings
Postby Afterthought » Sun Nov 07, 2021 1:04 pm
Got a question for anyone that had any experience building the 07k or Newer VW engines .
My goal is to figure out exactly what to order here to build this bottom end right .
I ordered a set of ACL race bearings , P/N :
6M5563H - STD , and a plastigauge Set.
I’m finding some info that says that the main bearings are color coded, I don’t see exactly where this is . So what I’m unsure about is if I can plan just using the set of king bearings I ordered for standard size - or if I need to take the block and have it line honed to do that .
I disassembled the engine and now I have a bare block, I kept track and marked all the mains and caps in order .
Re: 07k main bearings
Postby Afterthought » Sun Nov 07, 2021 10:17 pm
I guess a good plan might to be measure everything with the new bearings first and see where I’m at .
This reminds me I also need to do the 360 degree thrust bearing mod so sill have to verify I actually got the right bearing
Postby audifreakjim » Mon Nov 08, 2021 12:53 pm
There is a stamping on the block that shows what color(Size) bearings it requires. I've just been re-using the OEM bearings, they are almost always in very good shape.
But instead of doing this dance, it may be worth doing studs, and a line hone done to fit a standard size bearing.
07k main bearings
Postby Afterthought » Mon Nov 08, 2021 1:23 pm
audifreakjim wrote:There is a stamping on the block that shows what color(Size) bearings it requires. I've just been re-using the OEM bearings, they are almost always in very good shape.
Hey Jim, thanks for the reply. That's a good point, I guess I could also considering re-using these, this is a low mileage engine in great shape.
Alex found some info from a guy who builds TTRS engines that the factory tolerances are very tight and he said he likes to open them up. (see below)
I have a set of arp hardware for the mains I could use, I think they might require drill and tap.
Pistons, rods , bearings , flywheel and clutch. So in theory if I check with the local shop and see if they can do a line hone then I might as well have the whole assembly balanced at that time.
I wish I could just do all this myself. I hate dropping off my stuff at machine shops.
Postby Afterthought » Mon Nov 08, 2021 1:39 pm
Here’s what I could find
Postby Afterthought » Tue Nov 16, 2021 8:28 pm
Here are the numbers on the block
07k main bearings
Postby Afterthought » Tue Nov 16, 2021 8:42 pm
•modify the main cap to accept the old i5 (7a, aan) thrust bearing .
•measure with my new bearings and see what clearance is.
•drop off block to machine shop and have them balance the rotating assemble
For modifying the cap, I don’t know the depth or width of the recess that needs to be machined in . I guess I’ll start by first measuring the bearing and then maybe measuring an old i5 main cap or just the block side of the thrust bearing to get an idea .
This is what the parts looked like coming out :
Postby Afterthought » Sat Dec 18, 2021 4:24 pm
Still working on the thrust bearing mod . Cut it on the conservative side so I think one more Mod and I’ll be good.
I’ve measured axial play with the two new OEM “upper” stock bearings in place , and will shave enough off of the main cap to have the axial play be the same as that measurement with the new add thrust washers in place .
I also fit up the crank and main bearings and measured what I had for radial
Clearances and they’re all within factory spec with this bearing set .
Postby audifreakjim » Thu Dec 23, 2021 2:53 pm
Looking good!
Return to 07k Swaps
Users browsing this forum: No registered users and 0 guests
